Author Topic: testing teensy 2.0 download error  (Read 5801 times)
Offline laoadam
« on: Mon, 14 November 2016, 10:31:26 »
Hi, a newbie, try to load program to teensy 2.0, got message let to press button on board, i did, then stopped on the half way, then I cannot do any thing about, no erasing, no reboot...
signed int xanal;
signed int yanal;
int mouse_l;
int mouse_r;
unsigned int i = 0;
#define x_t_low    190
#define x_db_low   480
#define x_ctr      123
#define x_db_hi    505
#define x_t_hi     772
#define y_t_low    222
#define y_db_low   520
#define y_ctr      133
#define y_db_hi    550
#define y_t_hi     831
void setup() {
 pinMode(8,INPUT_PULLUP);
 pinMode(7,INPUT_PULLUP);
void loop() {
  signed int xmove = 0;
  signed int ymove = 0;
  xanal=analogRead(0);
  yanal=analogRead(2);
//  linear - low speed
  if (xanal < x_db_low && xanal > x_t_low || xanal > x_db_hi && xanal < x_t_hi) {
    xmove = ((xanal / 4) - x_ctr)/18;
  if (yanal < y_db_low && yanal > y_t_low || yanal > y_db_hi && xanal < x_t_hi) {
    ymove = (-1*((yanal / 4) - y_ctr))/18;
//  linear - turbo
  if (xanal < x_t_low || xanal > x_t_hi) {
    xmove = ((xanal / 4) - x_ctr)/12;
  if (yanal < y_t_low || yanal > y_t_hi) {
    ymove = (-1*((yanal / 4) - y_ctr))/12;
  Mouse.move(xmove,ymove);
// click and drag
  // right click
  if(digitalRead(7) == HIGH)
  { if(digitalRead(7) == LOW)
    mouse_r = 1;
     } else {
    mouse_r = 0;
  } else {
    mouse_r = 1;
  // left click
  if(digitalRead(8) == HIGH)
  { if(digitalRead(8) == LOW)
    mouse_l = 1;
    } else {
    mouse_l = 0;
  } else {
    mouse_l = 1;
  Mouse.set_buttons(mouse_r, 0, mouse_l);
Offline Tactile
Re: testing teensy 2.0 download error
« Reply #1 on: Mon, 14 November 2016, 13:42:43 »
Here are a couple of test programs from PJRC. They just blink the LED. See if you can flash with either of these programs to get back to a known state.
https://www.pjrc.com/teensy/blink_both.zip
REΛLFORCE
