Author Topic: TX-series keyboards  (Read 526294 times)
Offline Asbrodeus
Re: [IC] TX-75 (best 75% of the year) trust me
« Reply #650 on: Mon, 16 January 2017, 15:50:05 »
Is it an option to get these films CONUS or only really worth the shipping hassle with a TX order?
im interested in the films too and an extra plate + pcb so might be worth for me at least.
Offline Tally810
« Reply #651 on: Mon, 16 January 2017, 18:20:30 »
I would also like the films and a brass plate when kin gets more in (if he gets more in) for my tx-75
Offline jal
  • I can't believe it's not gravy!
Lame pics ahoy
« Reply #652 on: Mon, 16 January 2017, 19:04:58 »
So I built the Txpad today.
157811-0
Was planning on doing the 84 as well, but then hit a snag. I'm installing Holtite sockets in these, did the pad first, and then ran out on the 84. This was entirely predictable by any not entirely stupid turnip that had been paying attention, owing to the fact that I only bought 250. Somehow, I failed to think about that. So, need to order more.
157813-1
Figured this is the board set on which to use the Zeal screw-in stabs.
157815-2
157817-3
I adore this thing, and can't wait to get the main board built.
Offline Tally810
Re: Lame pics ahoy
« Reply #653 on: Mon, 16 January 2017, 19:30:09 »
I like that green so much.  I like the black one I picked but if he makes more green boards one day I want one.
Offline Jeu
Re: Lame pics ahoy
« Reply #654 on: Mon, 16 January 2017, 22:00:52 »
that wave top row is purrrrrty
Offline bciamny
Re: Lame pics ahoy
« Reply #655 on: Tue, 17 January 2017, 00:49:44 »
can you talk about how you went about doing the holtite installation/which holtites you used? i think i want to do something similar... :)
Offline wodan
« Reply #656 on: Tue, 17 January 2017, 01:37:31 »
More TX love for y'all ... Here's the highlights:
Here's the full log with some comments on the build process:
http://imgur.com/gallery/pFXLv
Offline Jumie
« Reply #657 on: Tue, 17 January 2017, 01:52:47 »
get in my pants
Offline renzpwns
  • I didn't like money in my wallet anyways.
« Reply #658 on: Tue, 17 January 2017, 04:37:46 »
Almost everything (except the key to push to get into flash mode, and some minor stuff) is explained here https://www.dropbox.com/sh/v24vygvyl4mvqrm/AABUNcm0BDioYE5QbArje0Kba?dl=0&preview=Leeku+L3+Software.pdf
To flash the new firmware you download the latest one, extract it, connect the keyboard while pressing Esc and then run the .bat file. Also try a different USB port and USB cable, I've had wonky stuff happen with half broken cables once.
Still didn't work unfortunately, I've tried multiple usb cables/ports, and a couple of different PCs. Tried holding Esc or U when plugging it in but it still comes up as a unrecognizable device. The only thing it does is have the RGB lighting cycle clockwise and the switch leds turn on after half a minute from plugging it in.
Will try other PCs and ports to test it out some more.
Offline jal
Re: Lame pics ahoy
« Reply #659 on: Tue, 17 January 2017, 06:58:42 »
I used these: http://www.digikey.com/product-detail/en/8134-HC-8P3/A114359-ND/1151726 .
They're tiny. I used tweezers to place them in the holes, and pressed them in with a soldiering iron. The heat didn't seem helpful until I tried with it cold, but it does.
You can see them sticking out of the back of the board in the second picture. You'll note I'm using a PCB vice. When I was putting them on the Tx84 board, the ones in the middle of the board tended to snap in with a slight click I could feel. I got the feeling this is what is supposed to happen - I think it was because in the middle, the board could flex. I'm not sure if using the correct tool would get that 'snap' everywhere.
I also placed the switches twice because of stupidity. When pulling them out, a couple switches pulled sockets out. I just reseated those, but it is probably a sign that I wasn't using enough pressure the first time around. In the future, I intend to make sure I pull switches over a clean, bright surface. They're very easy to lose.
Finally, specific to these PCBs - there are several bottom-row holes in which these won't fit, as well as a couple that overlap other holes enough as to make them unsocketable.
Offline Asbrodeus
« Reply #660 on: Tue, 17 January 2017, 06:59:55 »
Mine did that when I first plugged it in but when I connected it in jigon and updated the settings it was fine.
Offline vegs
« Reply #661 on: Tue, 17 January 2017, 08:27:09 »
Do you have any b-stock black TX-75? ;D
hhkb 4 life
buy less
Offline Unforgivable
« Reply #662 on: Tue, 17 January 2017, 10:05:24 »
Wodan! Why must you do this!
What kind of plate did you get for your TX84 and Numberpad? They both look fantastic!
Offline kin25
    • TXKeyboards
« Reply #663 on: Tue, 17 January 2017, 10:35:24 »
try connecting the cable with push 'U' key
Offline kin25
    • TXKeyboards
« Reply #664 on: Tue, 17 January 2017, 10:47:59 »
Thank you, I'm waiting here  ;)
I found tx87 cyan.
as you see.. there is a line like ADIDAS in front.
« Last Edit: Tue, 17 January 2017, 10:55:25 by kin25 »
Offline oatmicro
« Reply #665 on: Tue, 17 January 2017, 11:33:59 »
I found tx87 cyan.
I will contact you through the Telegram.
Should be the best way to talk about this.  :thumb:
Offline Tally810
« Reply #666 on: Tue, 17 January 2017, 14:53:33 »
Just picked this baby up from the house on my lunch break.  Will put some photos of the final product once I'm done building it.  Thanks Kin  :thumb:
Offline kin25
    • TXKeyboards
« Reply #667 on: Tue, 17 January 2017, 20:04:34 »
Gap film
Color : black, white, transparent
Quantity : 105~110pc / set
Price : $5
Shipping In envelope by Airmail : $1 (no tracking, 15 days)
I will make google doc..
Plz give me a few days
« Last Edit: Tue, 17 January 2017, 20:48:24 by kin25 »
Offline Funnblox
« Reply #668 on: Tue, 17 January 2017, 20:49:16 »
Yes Please!
Offline neon_tom
« Reply #669 on: Tue, 17 January 2017, 20:58:43 »
Gap film
Price : $5
I definitely want in on this!
Offline kin25
    • TXKeyboards
« Reply #670 on: Wed, 18 January 2017, 04:27:56 »
There is no airmail envelope in my city.
So I order them in internet shop.
Plz wait for a few days.
Offline kin25
    • TXKeyboards
« Reply #671 on: Wed, 18 January 2017, 12:33:53 »
This is TX Gap Film Order Form.
https://goo.gl/forms/UonCCCsRJCQGFWzH3
Offline Captainbuttmonkey
« Reply #672 on: Wed, 18 January 2017, 20:11:53 »
Offline gandroider
« Reply #673 on: Wed, 18 January 2017, 21:26:01 »
Anyone can assist me for the dimension (length x widht x height) in cm for these TX-75 and TX-CP?
Thanks
Offline kin25
    • TXKeyboards
« Reply #674 on: Wed, 18 January 2017, 22:09:47 »
Thanks
Txcp
390×140(bottom 139)×22(low)41(high)
Tx75
322×137(bottom 134)×22(low)39(high)
« Last Edit: Wed, 18 January 2017, 22:46:57 by kin25 »
Offline renzpwns
« Reply #675 on: Thu, 19 January 2017, 01:12:32 »
Still no luck. Now I wonder if I actually messed up any of the soldering job when I did the switches, cause I've tried connecting it to multiple PCs, USB ports and cables with the end result being same "USB Device Not Recognized."
Offline kin25
    • TXKeyboards
« Reply #676 on: Thu, 19 January 2017, 04:24:11 »
Why don't you contact me? :(
Offline renzpwns
« Reply #677 on: Thu, 19 January 2017, 04:44:08 »
Oh right, my fault! I probably shouldn't flood the thread with this. I will do that some time tomorrow.  :thumb:
Offline kin25
    • TXKeyboards
« Reply #678 on: Fri, 20 January 2017, 22:36:02 »
158164-0
Envelopes for switch gap films arrived.
I will send ordered films on Monday.
« Last Edit: Fri, 20 January 2017, 22:37:43 by kin25 »
Offline ctrlX
« Reply #679 on: Sat, 21 January 2017, 02:05:39 »
Noob question here... What are switch gap films? :)
Offline wodan
« Reply #680 on: Sat, 21 January 2017, 03:23:01 »
It's just the stainless steel plate. I really like solid plates. But Kin25 convinced me that brass plate is better so when I have the choice I prefer brass over steel!
Offline wodan
« Reply #681 on: Sat, 21 January 2017, 03:23:57 »
They have the same function as "switch stickers". But they are much easier to apply!
Offline kin25
    • TXKeyboards
« Reply #682 on: Sat, 21 January 2017, 06:33:38 »
Because I hate switch stickers.
It took 2 hours to put them into switches.
So I made them. :)
Offline hatran87
« Reply #683 on: Sat, 21 January 2017, 06:53:46 »
So I made them. :)
Hi kin, can non-tx ppl buy those films :)
I submitted entry but still no response!
Compact SQ by Leeku
Offline yuktsi
  • Colour my life with the chaos of trouble
« Reply #684 on: Sat, 21 January 2017, 07:52:13 »
So I made them. :)
PC films make life so easy ;D
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline kin25
    • TXKeyboards
« Reply #685 on: Sat, 21 January 2017, 08:17:04 »
So I made them. :)
I will send an invoice tomorrow.
Offline ctrlX
« Reply #686 on: Sat, 21 January 2017, 12:50:23 »
So I made them. :)
Ah, now I know what those are (I think). I wonder how they feel/improve Zealios.
Offline aznreaper
« Reply #687 on: Sat, 21 January 2017, 12:56:54 »
Iirc I think they were only originally supposed to help with housing wobble which is a cherry mx problem, not stem wobble which is the gateron problem. But also if you open up your switch housing a couple times it can warp causing housing wobble which the stickers can help.
Offline kawasaki161
« Reply #688 on: Sat, 21 January 2017, 13:00:15 »
So I made them. :)
Imo they don't, I'd advise you to not use them with any tactile or clicky switch.
They move up the top housing a bit, which causes the stem to also sit a little higher. This moves the tactile bump further down the keystroke which imo is not a good thing.
Also, Gateron tops have a really tight fit, which makes it harder to correctly assemble the switch with switch films.
Offline ctrlX
« Reply #689 on: Sat, 21 January 2017, 13:02:14 »
Got it. Thank you for the info and advice.
Hopefully my Zealios arrive soon so I can start building one of the TX boards.
Offline finalarcadia
« Reply #690 on: Sun, 22 January 2017, 04:51:10 »
Got bored so made a TX-75 wallpaper  ;D
Offline kin25
    • TXKeyboards
« Reply #691 on: Sun, 22 January 2017, 04:57:48 »
Wow.. It looks awesome.
Offline hatran87
« Reply #692 on: Sun, 22 January 2017, 05:39:13 »
So I made them. :)
Yeah, thank you :) I'm still looking for it :P
Compact SQ by Leeku
Offline bocahgundul
  • a seal
« Reply #693 on: Sun, 22 January 2017, 05:46:09 »
ok I think its time for seal to try to get his hands on one of this TX Keyboard.
plz sell
Offline stoic-lemon
« Reply #694 on: Sun, 22 January 2017, 08:18:58 »
Hi Kin, I submitted an order, so I'm waiting for an invoice. Cheers.
Offline Tally810
« Reply #695 on: Sun, 22 January 2017, 16:19:39 »
plz sell
Just msg kin I bought one last week.  He literally packed up the order before I paid .  Then once paypal hit he shipped and a few days later I had the board
Offline kin25
    • TXKeyboards
« Reply #696 on: Sun, 22 January 2017, 23:46:18 »
158303-0
Gap film envelopes before going to post office..
« Last Edit: Mon, 23 January 2017, 03:10:34 by kin25 »
Offline stoic-lemon
« Reply #697 on: Mon, 23 January 2017, 00:16:32 »
Great! But not sure everyone wants their home address posted on the internet.
Offline kin25
    • TXKeyboards
« Reply #698 on: Mon, 23 January 2017, 03:15:11 »
Sorry..
I didn't know address were showed..
It was my fault. So I changed image.
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #699 on: Mon, 23 January 2017, 08:01:25 »
Just paid for some film!
