Author Topic: What are the most popular space bar key sizes for split keyboards?  (Read 2840 times)
Offline DanD3n
« on: Thu, 01 December 2016, 08:22:53 »
I'm thinking building a custom split kb and was wondering what people prefer as keys used for the two small space bars, from an ergonomic perspective, but also from a key set availability point of view (DSA types excluded, since you can use any key imaginable).
Re: What are the most popular space bar key sizes for split keyboards?
« Reply #1 on: Thu, 01 December 2016, 08:42:10 »
People seem to prefer space bar profile but because that is not very available, custom split keyboards have most often used 2.75 and 2.25 ANSI-layout Shift keys. The downside is that the front edge is often perceived as begin too sharp.
If you use 2.25 spacing then you could use ANSI Enter keys as Space bars, which are flatter.
When we have had surveys on how people press the Space Bar, the results have been widely divergent. Some always use the left thumb, others always the right thumb (and Chyros is known to use his right index finger...).
BTW. On many ergo keyboards with fixed tenting, the space bar (clusters) is level where as the alphanumeric keys are tented. This is the case on the Kinesis and the MS "Natural" line, anyway.
Offline DanD3n
« Reply #2 on: Thu, 01 December 2016, 10:06:14 »
What about numpad 0?
