Author Topic: [GB] GMK HONEYWELL (In Production)  (Read 481642 times)
0 Members and 7 Guests are viewing this topic.
Offline handcraftedbits
Re: [GB] GMK HONEYWELL (In Production)
« Reply #300 on: Mon, 08 May 2017, 13:11:50 »
Yeah if you were in the GB you should get all the red accent keys.  I did.  Ping Oco, I'm guessing they just made a mistake.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #301 on: Mon, 08 May 2017, 13:28:13 »
Just got my set. Only got one red accent key (iso enter) with the base set. I was under the impression that the original group buy participants would get the whole red accent kit as shown in the pictures.....
It's a great set but those red accent keys really set it off and it's not the same without them. It's odd because the GMK box lists the base as having the full 155 pieces and Originative doesn't have the accent kit listed as a separate item.
If I can't get the red accent kit then I may off load my order.
Responded to you in the email!
Offline tron
« Reply #302 on: Mon, 08 May 2017, 14:00:40 »
Thanks for getting back to me Sherryton. It was probably the add on items (stabs, tactile sampler) I recently bundled in that shipment that caused the order date confusion.
Offline Zanduby
« Reply #303 on: Mon, 08 May 2017, 18:32:20 »
The grey is spot on! BUT, i should have looked sooner, a second 1.5u ALT (ignore, there is a second 1.5u ALT GR)and possible another 1u R4 FN or blank key would have been nice.
« Last Edit: Mon, 08 May 2017, 18:54:22 by Zanduby »
Offline frostylove
« Reply #304 on: Mon, 08 May 2017, 19:41:00 »
Just got mine. RO2 red is waaaaaaay much better than classic RO1, it's so VIBRANT!  :p
168036-0
Suhr Custom Standard Carve Top
Manson DL-1 Matt Bellamy Signature
Marshall JVM410H + 1960A
Lovepedal Kanji Enternity
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #305 on: Mon, 08 May 2017, 20:17:10 »
Ceresia (RO1) is better :)
Offline livingspeedbump
    • KeyChatter
« Reply #306 on: Mon, 08 May 2017, 21:14:53 »
It was my opinion that users could use the CODE keys for that if needed, there was an extra at one point, but we def had to trim the fat on this to reach a good price for the GB! Those BOOPs are amazing!!
<- My Collection (so far)
Offline Zanduby
« Reply #307 on: Mon, 08 May 2017, 21:22:04 »
Yeah, and honestly i'm not sure i'll need them when I put this set on my next board. You have it covered. Thanks again for making an awesome set.
Offline a_ak57
« Reply #308 on: Mon, 08 May 2017, 22:18:49 »
Honeywell HHKB:
First Cherry/GMK set and I have to say I'm very pleased.  I now understand what the hype is about;'; besides the profile being nice, the extra thickness of the caps seems to give a bit weightier feeling which I'm fond of.  Also Honeywell looks great, as others have said it even looks better in person.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #309 on: Mon, 08 May 2017, 22:19:52 »
Honeywell HHKB:
I'm glad you are enjoying it! There's another key in there for the backspace, "Delete". It looks much better.
Offline a_ak57
« Reply #310 on: Mon, 08 May 2017, 22:32:09 »
I went with the Backspace since that's what I use it for but you're right about the Delete, just looks cleaner.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #311 on: Mon, 08 May 2017, 22:32:55 »
:D In Sync!
Offline Jumie
« Reply #312 on: Tue, 09 May 2017, 03:24:06 »
Is this out of stock already?
Offline GreyAmbience
  • I can stop when ever I want
« Reply #313 on: Tue, 09 May 2017, 03:47:59 »
Yup
    • KeyChatter
« Reply #314 on: Wed, 10 May 2017, 00:30:51 »
Yeah, "Delete" is the standard GMK key for that simply because they can't fit "backspace" onto a single line. I also prefer the "Delete" as well though  :thumb:
At the end of the day, without a nav cluster like on a TKL you don't have multiple deletes. That would be the only thing that would really drive me nuts, if I had duplicate keys haha.
Offline Orca
« Reply #315 on: Sat, 13 May 2017, 13:40:17 »
R the accent keys still available if i order now?
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #316 on: Sat, 13 May 2017, 13:55:18 »
Yes sir!
Offline Petch
« Reply #317 on: Sat, 13 May 2017, 16:04:22 »
Yes sir!
Did you put my order as a gift as I asked? I sent the PM and got the shipping info
Offline moonmaster
  • big bumps, beautiful boards
« Reply #318 on: Tue, 16 May 2017, 17:11:58 »
Got my tripleshot Honeywell Fugu!
So beautiful... thanks Sheraton!
168548-0
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #319 on: Tue, 16 May 2017, 17:45:36 »
Great picture :) etf is the one who made them, I'm just trying to share as many of them as much as possible!
How do you think it compares to Honeywell?
Offline blighty
« Reply #320 on: Tue, 16 May 2017, 17:47:02 »
168550-0
I love having compatible sets for custom boards.  Thanks for running another smooth buy! :thumb:
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #321 on: Tue, 16 May 2017, 18:06:27 »
Thanks! <3
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #322 on: Tue, 16 May 2017, 18:14:42 »
Did that come separately from the set?
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #323 on: Tue, 16 May 2017, 18:19:12 »
Yes sir!
    • WTB/WTTF Thread
« Reply #324 on: Tue, 16 May 2017, 18:22:30 »
Yes sir!
That means I could still get one! Here is to hoping I do!
Offline buthidae
« Reply #325 on: Tue, 16 May 2017, 20:45:06 »
My set arrived on Monday. Expected it to take longer to get to me half-way across the world!
Love it :thumb: :thumb: :thumb:
http://imgur.com/a/dgEXt
Offline moonmaster
« Reply #326 on: Tue, 16 May 2017, 21:00:16 »
It's a great match. To my eye, the colors are 100% on point!
168564-0
« Reply #327 on: Tue, 16 May 2017, 23:45:17 »
Wow! Where did that come from?!
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #328 on: Wed, 17 May 2017, 20:46:19 »
Damn, that looks sweet :cool: :thumb:
Offline moonmaster
« Reply #329 on: Wed, 17 May 2017, 21:56:37 »
Sheraton gave people who bought the set a chance to buy one. He did the same with Sky Dolch.  I hope this become a pattern; I want that Miami Nights fugu!
Offline richard912
« Reply #330 on: Thu, 18 May 2017, 06:12:43 »
My set arrived today. The actual set looks awesome. However, I hope you guys are aware of this https://geekhack.org/index.php?topic=89508.0
« Last Edit: Thu, 18 May 2017, 20:24:40 by richard912 »
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #331 on: Thu, 18 May 2017, 14:11:38 »
My set arrived today. The actually set looks awesome. However, I hope you guys are aware of this https://geekhack.org/index.php?topic=89508.0
Thanks for letting us know! I'll definitely follow up with the manufacturer.
« Last Edit: Thu, 18 May 2017, 15:01:25 by sherryton »
Offline roostrc0gburn
  • its just plastic
« Reply #332 on: Thu, 18 May 2017, 22:55:16 »
after comparing honeywell against penumbra and originative cryllic, i see that honeywell and penumbra both have issues with stem supports, and a couple stems look like they have been burned or something. just a wild guess that this has something to do with the custom colors, because cryllic has no issues. i will look at a couple more sets this weekend when i move everything to trays
Offline Dreamre
    • kbdlife
« Reply #333 on: Fri, 19 May 2017, 11:05:26 »
Here's a picture of my set!
168752-0
Offline moonmaster
« Reply #334 on: Fri, 19 May 2017, 11:36:00 »
Love the all grey! Love how versatile this set is, with the three options for Esc and the options for arrows and enter.
Offline Endeavour1934
« Reply #335 on: Sat, 20 May 2017, 08:48:23 »
Got my set, it's great!. The gray keycaps are really beautiful. I'd love to have that shade of gray on Hyperfuse instead of CC. It matches better the cold tones of Hyperfuse.
Offline chuckdee
« Reply #336 on: Sat, 20 May 2017, 09:03:21 »
On my clueboard I just built.
« Last Edit: Sat, 20 May 2017, 22:14:18 by chuckdee »
Offline Mr_Grandis
« Reply #337 on: Sat, 20 May 2017, 13:59:44 »
Looks great on my 980m :)
Leopold FC980M w/ GMK Honeywell
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #338 on: Sat, 20 May 2017, 15:33:08 »
saw this picture on reddit! super awesome, and i like that bottom row.
Offline Petch
« Reply #339 on: Wed, 24 May 2017, 11:38:59 »
I'm in love! Wish I ordered a second set
Offline frostylove
« Reply #340 on: Thu, 25 May 2017, 00:21:02 »
169168-0
« Last Edit: Thu, 25 May 2017, 00:22:40 by frostylove »
« Reply #341 on: Fri, 26 May 2017, 15:20:37 »
    • WTB/WTTF Thread
« Reply #342 on: Fri, 26 May 2017, 15:27:05 »
On another not my top two rows have the same issue as most other with the broken cross supports. Also Sherry what should we do about scratched caps?
Offline Petch
« Reply #343 on: Fri, 26 May 2017, 19:59:06 »
Didn't even notice all the broken cross supports... is that normal with GMK?
    • WTB/WTTF Thread
« Reply #344 on: Fri, 26 May 2017, 20:02:04 »
It is not normal at all
Offline Petch
« Reply #345 on: Fri, 26 May 2017, 20:16:58 »
Pretty much all of mine have at least one missing, roughly half of them have all 4 parts of the cross broken
Offline moonmaster
« Reply #346 on: Sat, 27 May 2017, 09:16:40 »
This is really disappointing and I believe it affects the resale value substantially. Sheraton,  is GMK planning to do anything to make this right?
Offline richard912
« Reply #347 on: Sat, 27 May 2017, 09:38:30 »
Some of us posted our findings here https://geekhack.org/index.php?topic=89508.0
Offline kmba
  • Formerly tameone
« Reply #348 on: Sat, 27 May 2017, 10:25:21 »
Another recent set had issues with the cross supports as well. GMK must be having production issues.. and QC issues.  This certainly falls solely on GMK.
keyboards.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #349 on: Sun, 28 May 2017, 02:02:22 »
I'll be speaking more to GMK this week. I'll let you guys further know the issue when we discuss about it!
