Author Topic: 96 keys keyboard  (Read 5099 times)
Offline albin
96 keys keyboard
« on: Wed, 14 December 2016, 20:58:24 »
Hi guys, any recommendations for 96 keys keyboard with arrow keys and numpad together?
Offline Potatomonkey
  • Tsangan best row
Re: 96 keys keyboard
« Reply #1 on: Wed, 14 December 2016, 21:04:25 »
If your budget is near infinity, the Duck lightsaver. If it is ~200 ZZ96/RS96/AMJ96. If ~100 there is a kit on aliexpress.
Offline albin
« Reply #2 on: Thu, 15 December 2016, 04:40:48 »
how much would the light saverr be?
Offline moh18one
« Reply #3 on: Thu, 15 December 2016, 20:50:58 »
Leopold FC980M/C
Offline albin
« Reply #4 on: Fri, 16 December 2016, 06:17:06 »
i don't really fancy the separation between the numpad
Offline FrostyToast
  • Litshoard
« Reply #5 on: Fri, 16 December 2016, 08:17:21 »
Always state your budget when asking about a keyboard recommendation.
And never say you don't have a budget.
Quote from: elton5354
Offline albin
« Reply #6 on: Fri, 16 December 2016, 09:44:16 »
I'm looking at 250-ish
  • Tsangan best row
« Reply #7 on: Fri, 16 December 2016, 20:43:45 »
Get a zz96 imo
Offline FrostyToast
  • Litshoard
« Reply #8 on: Fri, 16 December 2016, 20:51:42 »
Your affordable options are the Leopold FC960M, the ZZ96, and the Red Scarf III. The Leopold has a plastic case, the ZZ96 is full aluminum and the Red Scarf is aluminum top wth acrylic bottom. Leopold is the most affordable and the ZZ96 is the most expensive.
The Lightsaver V2 would be out of your budget and goes anywhere between 3-400.
Offline albin
« Reply #9 on: Sat, 17 December 2016, 05:32:11 »
thanks guys. i missed the red scarf 3 in massdrop earlier and wondering when would be the next appearance of the zz96
Offline Mavarina
« Reply #10 on: Tue, 20 December 2016, 10:19:55 »
$1000+ I believe for resale
Offline FrostyToast
  • Litshoard
« Reply #11 on: Tue, 20 December 2016, 10:52:07 »
Considering the Lightsaver V3 will be out for roughly $400 quite soon, that is ludicrous.
Offline albin
« Reply #12 on: Wed, 21 December 2016, 18:45:22 »
When will the v3 be out?
Offline Mr_BeastQuake
    • Reddit
« Reply #13 on: Mon, 26 December 2016, 11:29:46 »
After Duck Viper/Eagle GB is done I'm guessing (just had payment deadline). Have a few months to save up some moolah.
It was a couple weeks after last Blackbird got delivered that the Eagle/Viper GB started. Blackbird GB started in July/June (?) And ended in November but was a month or so behind I believe.
Offline albin
« Reply #14 on: Tue, 27 December 2016, 07:01:59 »
thanks bro. so should be around march april?
