Author Topic: Leopold FC660C moding  (Read 1458 times)
Offline Harms
« on: Mon, 26 December 2016, 01:08:14 »
Hi everyone
I was thinking about shaping my novatouch stems to a FC660C. I was wondering if I can do it without doing anything to the stabilizers.
Because I hears the Leopold space bar is a different size compared to the novatouch. So is it possible to swap the stems? What size would the space bar be if it is possible?
Thank you for any input.
Offline sony
  • Formerly ultraidiot
Re: Leopold FC660C moding
« Reply #1 on: Mon, 26 December 2016, 12:23:08 »
You'll have to use a Topre spacebar. I recommend using one of the Topre pbt spacebars. Other than that you can just swap the other stabilizers and sliders.
