Author Topic: What should be the thickness for mounting plate.  (Read 4656 times)
Offline hgoel89
« on: Wed, 28 December 2016, 12:23:21 »
I need to know the thickness of the mounting plate for a PLANNED tkl build.
PCB is phantom
Plate material is stainless steel
Switch is brown gateron
Sent from my ONE A2003 using Tapatalk
Offline joey
Re: What should be the thickness for mounting plate.
« Reply #1 on: Wed, 28 December 2016, 12:29:35 »
1.5mm is the 'standard' thickness.
Offline xondat
  • i'm not a star
« Reply #2 on: Wed, 28 December 2016, 12:31:17 »
1.5mm is the standard as it allows the switches to clip into the plates.
Offline Tactile
« Reply #3 on: Wed, 28 December 2016, 12:32:11 »
The specs from Cherry are 1.5mm plus or minus 0.1 mm (1.4mm - 1.6mm). I'd expect Gateron switches to match that.
REΛLFORCE
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #4 on: Wed, 28 December 2016, 13:10:28 »
Or .06" +/- 0.004" (1/16 inch).
Click the Dimensions tab here: http://cherryamericas.com/product/mx-series/ and scroll down.
 - Ron | samwisekoi
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #5 on: Wed, 28 December 2016, 13:22:53 »
I usually stick with 1.5mm or 1/16" with my designs. You can go thicker (for example, if you're using like 3mm acrylic for your plate) but you'll have to glue the switches in.
