Author Topic: Where can you buy Kailh's new ML switches?  (Read 2147 times)
Offline LifeIsOnTheWire
« on: Thu, 29 December 2016, 23:53:44 »
Anyone know where to buy Kailh's new ML switches?
Also, anyone have any data on pinout positions, and dimensions?  I'd like to design a PCB that utilizes them
Offline davkol
  •  Post Editing Timeout
Re: Where can you buy Kailh's new ML switches?
« Reply #1 on: Fri, 30 December 2016, 09:52:08 »
I'd wait for keycaps… Anyway, matt3o knows.
« Reply #2 on: Fri, 30 December 2016, 10:07:12 »
Right now I just want to know if they're available, and Id like to see some design specs so I can start designing a PCB.  Ill definitely wait for keycaps before I spend any money
Offline davkol
« Reply #3 on: Fri, 30 December 2016, 10:21:36 »
There's this datasheet, but it's supposedly slightly outdated.
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #4 on: Fri, 30 December 2016, 10:21:45 »
I tried to find the data sheet that was posted but I think it was removed. I don't think that they will be publicly available for a while yet.
Your bet bet would probably be to contact matt3o. He has a connection with the distributor.
« Reply #5 on: Fri, 30 December 2016, 16:44:36 »
Nah, I'll just be patient.  I'm going to design a 40% PCB, and hopefully make a bunch of them.  However, I wouldn't mind getting an updated data sheet.  I'd like to get a head start on designing it.  I'd really like to figure out if the pin layouts can accomodate a combination MX/ML PCB design.
Offline hanya
« Reply #6 on: Fri, 30 December 2016, 20:47:17 »
PFU HHKB JP, Sanwa MA-TB38 trackball
