Author Topic: Does gons tkl pcb support pcb mounted switches?  (Read 2051 times)
Offline hgoel89
« on: Fri, 30 December 2016, 03:05:46 »
Can anyone confirm, if tkl pcb has the holes for 5 pin switches
Sent from my ONE A2003 using Tapatalk
Offline TalkingTree
    • My projects
Re: Does gons tkl pcb support pcb mounted switches?
« Reply #1 on: Fri, 30 December 2016, 04:03:01 »
Yes, it supports switches with fixations pins.
Check the picture.
