Author Topic: GH-122.2017 Mods, features, and additions  (Read 84761 times)
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
Re: GH-122.2017 Mods, features, and additions
« Reply #250 on: Wed, 21 June 2017, 00:25:04 »
The longer the better for me right now. *opens wallet* *cries*
Offline Giorgio
« Reply #251 on: Sun, 06 August 2017, 13:00:24 »
Would it be possible to make this compatibile with the g80-3000 case? Or even better to make this PCB compatible with the standard 100% layout (removing the top function row). What other full size PCB are can we buy? Not many.
RGB underglow is very interesting.
Alps? More holes and the PCB Will collapse under any weight and then self destruct.
I think that many could benefit from a presoldered controller and diodes, and why not, under glow leds.
Thanks
« Last Edit: Sun, 06 August 2017, 15:25:32 by Giorgio »
Offline Giorgio
« Reply #252 on: Sun, 06 August 2017, 13:57:35 »
I'll just leave this here...
 - Ron | samwisekoi
Auto-typed by my GH-122 keyboard.
This case is really nice. I would improve it a little by offering a matte finish, flathead screws recessed into the plate by widening - with an angle - the hole, and smoothing a little the edges of the layered plates (maybe only the top and the bottom one need this. Also... Cutouts for switch removal.
In a sandwich case, is the plate indispensable? I mean, the PCB is "suspended" from the top plate, and it does not touch the bottom one? In other words, are the "mounting holes" enough to support the board, without a plate?
About the firmware, yes it would be nice to reassign keys without having to reflash.
A final word about the keycaps: blank gmk keycaps are about 40% cheaper than doubleshots. So we could have the alphas doubleshots, and the rest of the keys blank.
Finally, a word about the layout, I'm happy that you offer this layout for the function keys, because having them staggered, with empty speces in between, is the only way to find touch type also up there...
« Last Edit: Sun, 06 August 2017, 15:16:56 by Giorgio »
Offline Giorgio
« Reply #253 on: Sun, 06 August 2017, 15:03:55 »
Only 180 degree orientation changes are allowed for alps.
Alps vertical numpad 2u positions do need the stem rotating 90 degrees (like you have it), but in not sure if this is an absolute rule or just the general case. A seasoned Alps user will have to verify.
Can someone authoritative weigh in on this point?  I can rotate the numpad vertical either way, but not both
Like so?
All of my alps boards are like this btw, With the exception of one with the 2x1u's in the numpad which are placed normally
what a nice case! who did it for you?
Offline Spaceman1200
« Reply #254 on: Mon, 07 August 2017, 08:33:33 »
The case is from the Monarch Keyboard seen here https://geekhack.org/index.php?topic=75786.0
Offline Giorgio
« Reply #255 on: Mon, 07 August 2017, 09:21:35 »
Thanks for you answer!
I'm very impressed by the plate recesses, that allow the switch to clip in, overcoming all the thickness limitations.
I think that such a thick plate could make the difference in an enormous keyboard like the gh-122. BTW, does the gh122 ping? Adding some mass and supports can surely help.
175251-0
175253-1
175255-2
full build log
https://imgur.com/a/AeGHW
« Last Edit: Mon, 07 August 2017, 09:23:52 by Giorgio »
Offline THX1138b
« Reply #256 on: Sun, 08 October 2017, 01:44:21 »
A feature request I'd like in such a keyboard is a couple of usb sockets to plug in flash drives or whatever.
Offline semajsiwel
« Reply #257 on: Wed, 26 June 2019, 17:17:00 »
Anyone know if this is officially dead or long term hiatus?
Been lurking for a while in hopes of an update.
Offline ErgoMacros
« Reply #258 on: Wed, 26 June 2019, 21:59:16 »
I keep hoping, but samwisekoi was last Active: Mon, 19 February 2018.
I keep watching, but it's not looking promising.
I'm 1/2 tempted to try and replicate his work, but there are so many details he clearly knows, that I don't...
And I've never designed a PCB... or a keyboard, or a case...
just seems very unlikely that I'd succeed at it.  :(
Today's quote: '...“but then the customer successfully broke that.”
Offline semajsiwel
« Reply #259 on: Sun, 07 July 2019, 19:36:43 »
I agree. I've never done something as intricate as designing a keyboard PCB.
The manufacturing portion itself I'm confident I could do/have done, but the most complex thing I've designed in this regard was an 8x8 switch matrix for a chess game.
Offline ErgoMacros
« Reply #260 on: Thu, 11 July 2019, 00:20:16 »
Here's another possible option for a large board...
   CueBoard 2x1800. 131 keys,  4 rotery encoders, 2 num pads. Only available on April 1st  :(
   https://clueboard.co/parts/clueboard-2x1800
No guarantee's it will be available next year, of course.
Offline hottrout
  • I'd Hit Dat Key
« Reply #261 on: Thu, 11 July 2019, 05:22:57 »
I'd rock this layout hard
Never expected to see split stuff, but will be interesting making cases for them.
I would 2nd that big time.  My all time fav layout and if this was possible I am in in in.  Sign me up and take my money.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
