Author Topic: [GB] M65-A | Made with RAMA.WORKS (Complete)  (Read 1784925 times)
Offline duynguyenle
  • Personal text? What personal text???
Re: [GB] M65-A | Made with RAMA.WORKS
« Reply #1250 on: Fri, 02 June 2017, 12:12:46 »
Went with 7u so I can go with 1.5u across the bottom, arrows, split l shift, split backspace (bar, delete), and hhkb delete/bs. No need for win key on programmable board, especially with qmk. Thinking either double tap on FN or maybe ctrl+alt for win.
Do you, like, hate stabilised keys or something?? :P
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline kmba
  • Formerly tameone
« Reply #1251 on: Fri, 02 June 2017, 12:56:14 »
:D na just want dedicated arrows, delete key, page and home/end keys.
keyboards.
Offline kmba
  • Formerly tameone
« Reply #1252 on: Fri, 02 June 2017, 13:02:00 »
Although I just realized my layout doesn't​ provide a key for function. I'll have to make right alt/ctrl into win and FN keys. I don't use them for anything. 1.5u life ain't easy.
keyboards.
Offline fishpod
« Reply #1253 on: Sat, 03 June 2017, 01:42:45 »
was the weight already included or we need to get it later?
thanks m8! got it!
Offline atomicus
« Reply #1254 on: Sat, 03 June 2017, 11:06:55 »
Novice question, but why would one want the GMK screw in stabs?
Offline bciamny
« Reply #1255 on: Sat, 03 June 2017, 11:42:01 »
the screw in stabs fix the stabs on to the board and should lower the possibility of pulling out a stabilizer when changing keycaps.
Offline kmba
  • Formerly tameone
« Reply #1256 on: Sat, 03 June 2017, 12:54:31 »
Plus the base is super secure and provides better stabilization
keyboards.
Offline doooostin
« Reply #1257 on: Sun, 04 June 2017, 01:41:45 »
- Emails replied to.
- Addresses updated.
- Requesting to see if we have extra units at the manufacturer that we can receive.
Have a good day everyone!
Hey Jchan, not sure if my email was seen?
M65-A-247
Just double checking! Wouldn't want the package to ship to wrong location :o.
Offline atomicus
« Reply #1258 on: Sun, 04 June 2017, 09:18:40 »
Bit confused which stabs I need... 6.25U or 7U. I will have ISO UK layout.
Offline kustom3
  • bonjour
« Reply #1259 on: Sun, 04 June 2017, 09:38:19 »
6.25 is the most common size, but you can use the ISO UK layout with 7U stabs as well. Look at the bottom rows available on the M65-A on the first page of this thread, and maybe check your keyset for compatibility as well if you already have one. It's mostly a matter of personal preference and keyset compatibility.
Offline atomicus
« Reply #1260 on: Sun, 04 June 2017, 09:39:28 »
Don't have keyset yet, but sounds like 6.25U might be safer bet?
Offline kustom3
  • bonjour
« Reply #1261 on: Sun, 04 June 2017, 09:47:56 »
In theory it is. Although unless you're going for the cheap stuff (such as Tai-Hao), a lot if not most keysets nowadays offer a 7U spacebar and some 1.5U mods.
Offline KINGPIN
« Reply #1262 on: Sun, 04 June 2017, 13:23:40 »
This question might be already answered but when will shippings to UK ship?
Levia Makes
Offline duynguyenle
« Reply #1263 on: Sun, 04 June 2017, 15:02:03 »
Same time as all US/EU orders, which is to say, not yet (the shipment hasn't even reached jchan yet)
Offline Faux
« Reply #1264 on: Mon, 05 June 2017, 18:05:48 »
Just realized that JC65s are supposed to ship later this month. Looking forwards to building and posting pics.
Offline pixelpusher
« Reply #1265 on: Mon, 05 June 2017, 23:39:22 »
What are you planning to do with the PCB?  Curious.  I thought he never released the case or plate for it.
Offline Faux
« Reply #1266 on: Tue, 06 June 2017, 02:45:36 »
What do you mean? I'm planning on putting vint blacks on the PCB. The case is the M65-A and the plate is the brass plate. Hopefully that answers your question.
Offline kmba
  • Formerly tameone
« Reply #1267 on: Tue, 06 June 2017, 06:33:50 »
M65a comes with a PCB. You are confusing us
keyboards.
Offline rioc
« Reply #1268 on: Tue, 06 June 2017, 08:45:31 »
Hey jchan, can't remember which Size Stab I ordered in the latest form. Can you look that up or shall I send you a mail with my order number?
Offline jchan94
  • Keyclack Inc
  • * Moderator
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #1269 on: Tue, 06 June 2017, 13:48:06 »
Email support@keyclack.com with your email used + order ID thanks!
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #1270 on: Wed, 07 June 2017, 15:16:05 »
Hi everyone,
This is a friendly bump to make sure you fill out the form.
Other than that, I hope that the shipment arrives soon.
Fun question while we wait
If the shipment is 4 pallets, what is the estimated total weight for 450 M65's ?
Offline ambalek
  • Pizza tonight/Threat neutralized
« Reply #1271 on: Wed, 07 June 2017, 15:23:42 »
1575 kg/3472 lbs?
Offline Zanduby
« Reply #1272 on: Wed, 07 June 2017, 15:38:32 »
Hi everyone,
somewhere close to 2700lbs.
Offline kustom3
  • bonjour
« Reply #1273 on: Wed, 07 June 2017, 15:59:22 »
Offline Kavik
« Reply #1274 on: Wed, 07 June 2017, 16:05:23 »
I'm really looking forward to getting my M65-A so that I don't have to go to the gym to lift weights. I'll just curl my keyboard.
Offline Tally810
« Reply #1275 on: Wed, 07 June 2017, 16:16:19 »
3000lbs
Sent from my SM-G928V using Tapatalk
Offline forevermadrigal
« Reply #1276 on: Wed, 07 June 2017, 18:53:56 »
I'm gonna guess 2250
Offline kawasaki161
« Reply #1277 on: Thu, 08 June 2017, 02:32:43 »
I'll guess 1423kg
« Last Edit: Thu, 08 June 2017, 02:42:10 by kawasaki161 »
Offline Dominathan
  • Too many keyboards? Not enough hands.
« Reply #1278 on: Thu, 08 June 2017, 03:22:51 »
1750kg
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #1279 on: Thu, 08 June 2017, 04:14:47 »
With packaging, about 1200kg
Offline rioc
« Reply #1280 on: Thu, 08 June 2017, 04:15:29 »
1337 kg
« Reply #1281 on: Thu, 08 June 2017, 07:34:03 »
2600 lbs
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #1282 on: Thu, 08 June 2017, 07:52:34 »
It's at least 40...
Offline giHefca
« Reply #1283 on: Thu, 08 June 2017, 16:40:53 »
The right weight
Offline eksuen
  • Ambassador of explosions.
« Reply #1284 on: Thu, 08 June 2017, 16:59:03 »
Yo mama so fat....
Offline Vadurr
  • Valar Morghulis
« Reply #1285 on: Thu, 08 June 2017, 17:07:31 »
Yo mama so fat....
dat when she jump fo joyy
Offline eksuen
« Reply #1286 on: Thu, 08 June 2017, 17:09:21 »
Yo mama so fat....
she got stuck. okay fank you.
#sheweighsasmuchasapalletofM65s
Offline shinz0
  • i was told there would be cake
« Reply #1287 on: Thu, 08 June 2017, 17:12:55 »
i'm gonna guess 2400 lbs
Offline yokken
« Reply #1288 on: Thu, 08 June 2017, 19:12:32 »
Hm, what have we here? http://www.dhl-usa.com/content/dam/downloads/g0/express/shipping/weights_and_dimensions/weights_and_dimensions_en_lm.pdf
Jchan/RAMA posted a picture showing 4 kits per box a few weeks ago. 450 / 4 = 112.5 boxes, so let's say 113 boxes with one kit all by itself in the 113th box. If we assume each kit is between 6 and 8 pounds, let's go with 7, then 450 * 7lb = 3,150 pounds, or 1,432kg. This is far under DHL's maximum pallet weight. The boxes seem to take up quite a bit of space (38.5x34.5x32cm) and DHL's maximum pallet dimensions for Express are 120x100x160cm. We can fit 3 x 3 x 4 per pallet, or 36 boxes per pallet. This puts us at 458kg per 36 boxes (4kits*3.18kg*36 boxes) which would mean that 4 pallets are needed for 113 boxes. The thing is, with 36 boxes per pallet, that's 108 boxes across 3 pallets, leaving... 5 boxes... on pallet 4. Not likely. 30 boxes per pallet makes the most sense. 30, 30, 30, 23. But I digress!
I'm going to say 3200lb or 1500kg all told, which ever is closer ;)
« Last Edit: Thu, 08 June 2017, 20:49:52 by yokken »
Offline Aperture_Sci
  • ZZ96 / 65g Zealios / GMK Sky Dolch
« Reply #1289 on: Fri, 09 June 2017, 13:40:02 »
I'm going with 3201lbs, Bob
« Reply #1290 on: Fri, 09 June 2017, 13:59:55 »
1 dollar, Bob!
Offline catweewee
  • SINGA | singakbd.com
  • Yellows
« Reply #1291 on: Fri, 09 June 2017, 14:03:47 »
For the full Build log: http://imgur.com/a/gVfcT
The board weighs about 1.5kg with GMK caps.
Offline delivery
« Reply #1292 on: Fri, 09 June 2017, 14:08:43 »
Chitttttttt!!! Nice!
Offline stand.geek
« Reply #1293 on: Fri, 09 June 2017, 14:09:48 »
Wow. Nice build man!
Offline purrito
  • mmm...spicy
« Reply #1294 on: Fri, 09 June 2017, 14:12:08 »
Wow! The matte black looks incredible! Awesome build  :thumb:
GMK Carbon Zealios B.mini | Matias QC Let's Split | Overcast DSA Zealios Planck | DangerZone MX Red Pok3r
Offline jjwax
« Reply #1295 on: Fri, 09 June 2017, 14:15:21 »
Anyone of you lucky asians order the desk mat?  I'd love to see a pic (maybe one has already been posted and I missed it???)
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #1296 on: Fri, 09 June 2017, 14:24:31 »
I didn't take a picture of the whole thing, but here's an album of it close up.
http://imgur.com/a/7tAAU
Also, thank you Catweewee. Hope you enjoy that box.
Offline catweewee
  • Yellows
« Reply #1297 on: Fri, 09 June 2017, 14:37:57 »
best box, its in my cupboard marinating.
Offline Kavik
« Reply #1298 on: Fri, 09 June 2017, 15:52:37 »
Damn, every time I see a picture, I wish I'd ordered black instead of space gray. That looks amazing.
Offline BAS1C
« Reply #1299 on: Fri, 09 June 2017, 18:06:56 »
1723.5 kg :O
I hope they get there sooooon! I'm itching with anticipen15land
