Author Topic: EXENT 65% Custom Keyboard (most exciting community project of 2017)  (Read 235729 times)
Offline ironpup
  • Good feeling of oneness with cup rubber
Re: EXENT 65% Custom Keyboard (most exciting community project of 2017)
« Reply #50 on: Sun, 08 January 2017, 13:32:57 »
With Originative involved does that mean Mod switches?
The correct question is 'With Originative involved does that mean GMK Penumbra?' :P
stop that right now  :eek:
Offline poolside
« Reply #51 on: Sun, 08 January 2017, 13:37:39 »
Looks good with that oversized lateral bezel, and easy on the wallet as well.  :thumb:
Offline kmba
  • Formerly tameone
« Reply #52 on: Sun, 08 January 2017, 14:55:33 »
No support for all 1u bottom row right?
keyboards.
Offline kiwi99
  • that's a gnarly dookie
« Reply #53 on: Sun, 08 January 2017, 15:34:50 »
+1 for 16 x 1u key bottom row support
/s
ps: I get what you're sayin it was just a joke
Offline BAS1C
« Reply #54 on: Sun, 08 January 2017, 15:45:45 »
I just died and went to heaven. Can also confirm, Mei is not in heaven. We are safe.
Offline The_Skynacho
« Reply #55 on: Sun, 08 January 2017, 16:23:17 »
This looks amazing! Now I know where my Christmas Bonus is going!  ;D
Offline el_mechacontext
  • You can find my body in the mechacontext.
« Reply #56 on: Sun, 08 January 2017, 16:59:02 »
I know I haven't been in the mech game for very long, so saying this may not have much weight, but this is one of the best things I've ever seen. I didn't know that pricing was even possible. I cannot WAIT to join the GB. Hail king RAMA, Originative, and everyone involved.   :eek:
Pok3r MX Clears | CM Storm Stealth MX Blues | Dell AT101W Alps Blacks | Happy Hacking Keyboard Uni 45g | Ortholinear Planck Gateron Blacks
Offline Captainbuttmonkey
« Reply #57 on: Sun, 08 January 2017, 17:01:24 »
Incredible, take my money. I very much hope this won't be limited.....
Offline muten-roshi
« Reply #58 on: Sun, 08 January 2017, 17:25:04 »
one question. when?
Offline BAS1C
« Reply #59 on: Sun, 08 January 2017, 18:07:45 »
one question. when?
Indeed! I hope this jumps to GB quickly
Offline Pwner
  • soon™
« Reply #60 on: Sun, 08 January 2017, 18:12:37 »
one question. when?
This was posted on the Keyclacker IG yesterday and it said 1 week away.
I'm just hoping it's not a raffle.
Offline Data
« Reply #61 on: Sun, 08 January 2017, 19:26:02 »
Well, this is refreshing.
Any chance for a bottom row with 3x 1u caps instead of the 2x 1.5u to the right of space bar?  Otherwise loving the layout options.  That oversized case is just...   :eek:
Offline Traveler
« Reply #62 on: Mon, 09 January 2017, 09:54:36 »
Someone from Originative Co has been answering questions on Reddit, and has provided the following info:
- They are planning to release details on the GMK set soon, and are currently working on some of the finer details of the set. It was implied that the included set will be just enough caps to cover the board.
- The switches that will be offered in the Premium kit will be Gaterons. It looks like MOD switches will also be available for an extra fee.
- EDIT: This will be a classic GB, not raffle.
I will update this if I see more info. Someone asked if this will be a classic GB or raffle style, so I'll be keeping my eye on that question for an answer.
« Last Edit: Tue, 10 January 2017, 09:47:22 by Traveler »
Offline Vigrith
« Reply #63 on: Mon, 09 January 2017, 11:01:58 »
I appreciate that very much, I'm also curious to know of more updates - especially if it's classic GB or raffle, which set will be included and when the buy will start.
Offline ironpup
« Reply #64 on: Mon, 09 January 2017, 11:08:07 »
one question. when?
1 week!?
Offline menuhin
« Reply #65 on: Mon, 09 January 2017, 11:13:33 »
...PCB: $35 (pre-assembled with diodes/resistors, controller parts and RGB led)...
Does it mean that the PCB has underglow integrated already?
Or there is some LED like how the Zeal60 PCB implemented it?
Also what is the diameter of the switch pin holes?
I am looking for PCB that can do some easy hotswappable mods and 1.5mm pin hole size is compatible for some receptacles (forgot those for LEDs):
https://www.reddit.com/r/mechmarket/comments/5lybs5/gb_holtite_sockets_switches_leds_for_ch_eu_limited/
« Last Edit: Mon, 09 January 2017, 12:11:13 by menuhin »
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Saiph
« Reply #66 on: Mon, 09 January 2017, 11:32:33 »
It mostly likely means the former. It looks like they plan on having a Polycarbonate/nylon base to support it
« Reply #67 on: Mon, 09 January 2017, 11:51:56 »
Looks great!  :thumb:
Offline juahenza
  • DoSmallThingswithGreatLove
« Reply #68 on: Mon, 09 January 2017, 12:53:37 »
Great design here, gents. Really like it.
What am I missing on the pricing...? For $70 more than 'basic' you get switches and GMK caps?? Amazing.
I am not sure if I'd made it clear enough in the thread. But yeah, you are getting a set of GMK caps with the premium bundles
When will this happen? I want it now :)
Now is unlikely. We have planning to launch the GB in about a week time.  :D
So is the plate part of the top piece (so alu plate)? I'm so in ❤
You are right Sir, the plate is mounted to the top ❤❤
Interesting idea, few questions,
What will be plate material and options?
Where will it be shipped from?
I assume the GMK set will just be enough compatibility for this board?
It says steel feet in materials, but under extras is steel feet. Are those just larger feet?
What are the roles of each of the people helping you with this project?
That's a lot of questions. The plate is made of aluminum, what do you mean by plate options? Yes, you will have enough keys to support the proposed layouts. And yes, the feet is made of steel. Standard kit comes with a feet that raises your board at 8 degree angle. While you can purchase the "taller" feet, to raise your board at 12 degree angle. I just obtained a 456gt recently, I must say I enjoy 12 degree angle very much. They are my friends, it's really hard for me for to explain here since there are too many of them. We are working together to bring a proper custom board to the community.
this is amazing.
is this going to be unit limited? i feel like i'd want more than one... :X
You can have two. Let know if you need more than that... :X
Alexa, order me an EXENT
Hi NTW, the weather today is...  :-\
/s
Not possible.
Yes. It supports 3x 1u.  :thumb:
« Last Edit: Mon, 09 January 2017, 13:00:26 by juahenza »
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline BAS1C
« Reply #69 on: Mon, 09 January 2017, 13:01:47 »
Thanks for the info, very awesome..
I am beyond excited to hear what the GMK set will be =o
Offline Data
« Reply #70 on: Mon, 09 January 2017, 13:11:00 »
Offline muten-roshi
« Reply #71 on: Mon, 09 January 2017, 13:15:12 »
Wow. I don't know but I think this will be better than ramabae because I don't have that much money. 250 for pcb case and switches aaaand caps. That's so cheap there has to be a downside...  But i hope not ;-)
Gesendet von meinem E5823 mit Tapatalk
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #72 on: Mon, 09 January 2017, 13:22:41 »
Is this going to be a one time thing, or are there going to be more rounds in the future?
kinda though that the M65-A started this week and then we have the EXENT next week, rip wallet.
Offline shinz0
  • i was told there would be cake
« Reply #73 on: Mon, 09 January 2017, 15:23:05 »
2017 starting to shape up to be an epic year in keyboards.
Offline kittenpolice
  • mods are asleep, post logitech
« Reply #74 on: Mon, 09 January 2017, 16:05:14 »
Woah this looks cool!
Sent from my SM-N920P using Tapatalk
Offline gartentisch
« Reply #75 on: Mon, 09 January 2017, 16:47:12 »
Now for the price question: M10-A with M65 or M67. What would you say?
Gesendet von iPhone mit Tapatalk
Offline BAS1C
« Reply #76 on: Mon, 09 January 2017, 16:48:17 »
BOTH!
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #77 on: Mon, 09 January 2017, 16:48:23 »
This is truly the KOAT and it's only January.
Is the Vantablack option just a gimmicky name or are you planning on using the famous paint/material?
Same thing I want to know.
pleaseohpleaseohpleaseohpleaseohplease!
Offline BAS1C
« Reply #78 on: Mon, 09 January 2017, 16:50:10 »
At this price point, I'm gonna go with a big nope. If you read up on it, you will see why.
"The nanotubes that make up Vantablack must be grown in the Surrey NanoSystems lab using a complicated (and patented) process involving several machines, a few layers of different substances, and some extreme heat. From start to finish, applying Vantablack to an object can take up to two days, according to Northam. “I had an inquiry yesterday asking how much would it cost for a kilo of Vantablack pigment,” Northam says. “First of all, I can’t sell you a bucket of Vantablack, but if I could, I don’t think there’d be much on the planet that would be more expensive.” He says that, ounce for ounce, Vantablack is a lot more expensive than both diamond and gold. "
« Reply #79 on: Mon, 09 January 2017, 17:22:28 »
Never even heard of it before but from having a quick read of the FAQ on their website I would imagine there is 0% chance of that: https://www.surreynanosystems.com/vantablack/faqs
Seems to be quite a few restrictions around it and very difficult/costly to manufacture.
Offline Photoelectric
« Reply #80 on: Mon, 09 January 2017, 18:23:33 »
Will the bottom polycarbonate block be that smaller rectangle?  Matte translucent?  Is that text on the bottom going to be engraved in the plastic or will there be a plate covering the plastic where the text will be engraved?  Just trying to visualize what it will look like, since your sketches are not indicating what materials will be used where.  Thank you.
Offline Perfex
« Reply #81 on: Mon, 09 January 2017, 18:47:08 »
I hope these renders represent the base of the keyboard. https://rama.works/#/m67a/
I really don't understand the whole glowing keyboard fad, the smooth finish on the render is tasteful... the nylon cutting board texture of the M65-A isn't in my opinion.
« Last Edit: Mon, 09 January 2017, 18:55:27 by Perfex »
Offline Saiph
« Reply #82 on: Mon, 09 January 2017, 19:15:42 »
I think the renders are different just based off of how the EXENT text looks from the picture that was posted. The M65-A does have an aluminum base option btw if you don't care for the nylon with underglow.
Offline ntw
« Reply #83 on: Mon, 09 January 2017, 19:41:25 »
and a kick to our wallets (or purses, I'm not judging)
Offline slickmamba
« Reply #84 on: Mon, 09 January 2017, 19:44:19 »
yes a board I finally have enough space to put my ketchup on!
Hi :)
Offline ntw
« Reply #85 on: Mon, 09 January 2017, 20:09:39 »
there should be enough space to put a can of cola on the left n pizza on the right.
and good amount of place to grip when I want to bash in someone's skull
« Reply #86 on: Mon, 09 January 2017, 20:19:22 »
I see it as a sushi board: sushi on the right, wasabi on the left.
(but I keep thinking a row or two of additional modifier switches would have been useful instead).
Offline slickmamba
« Reply #87 on: Mon, 09 January 2017, 21:18:38 »
thats true, now when I go to Mackers and get chicken nuggets I have space for the soda, sweet and sour dip(no bbq scrubs), fries, ketchup, and my extra 5 piece
Hi :)
Offline jal
  • I can't believe it's not gravy!
« Reply #88 on: Mon, 09 January 2017, 21:19:02 »
If you get it wet after midnight and say its name five times, it turns in to a Microsoft Comfort Curve.
Offline clacktalk
  • circa 2015
« Reply #89 on: Mon, 09 January 2017, 21:44:04 »
joke's on u the sides aren't even ribbed your chicken nuggets and pizzas are gonna slip right off dat ano
diary of a clacktalk
radio_killah: too much frank
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #90 on: Mon, 09 January 2017, 21:45:21 »
need speaker grill on the side and it would be perfect.
speaker grill with google assisntant integrated. Imagine that. You can talk to your keyboard. wew
jokrik and I been telling him that. Hmmm =/
"I'm sorry, I couldn't find any results for 'CLACKTACKCLACKCLACKTHOCKCLACKTHOCKSMACKCLICKCLACK'"
Offline kmba
  • Formerly tameone
« Reply #91 on: Mon, 09 January 2017, 23:41:36 »
/s
Not possible.
That's what I was asking in my OP.  not 16u :)  basically 5x 1u right of space (3 modifiers + arrows)
keyboards.
Offline nocturalowl
« Reply #92 on: Mon, 09 January 2017, 23:43:47 »
PLS start the buy already and take my money!
Offline ntw
« Reply #93 on: Tue, 10 January 2017, 00:22:31 »
right into my mouth :p
Offline Jedi
« Reply #94 on: Tue, 10 January 2017, 07:49:36 »
Holy FS, is there anything esle you wanna kills us with on this GB?  Lets see, space man's keyboard - Check, GMK keyset available at purchase - Check.  What's next BBV2?  :eek:
Offline merutz
  • @merutz
« Reply #95 on: Tue, 10 January 2017, 07:56:41 »
Also the first person to enter the GB wins a romantic date with @bocahgundul. Lady and tramp style, eating meatballs of the first EXENT prototype.
QFR R-i/DSA Dolch   |   MX Master
     + yellow Esc
Offline sachin3767
« Reply #96 on: Tue, 10 January 2017, 08:07:33 »
stoked to see this happening and can't wait.
Hoping for something vintage apple related for the GMK set. I love the AEK64s recently posted on r/mk
Q: where does the kb name Exent stem from?
 Whitefox|Granite    Tex Yoda II     Exent | dev/tty      MX Master       Planck|Big Bang
Offline Jedi
« Reply #97 on: Tue, 10 January 2017, 08:42:09 »
Offline pixelpusher
« Reply #98 on: Tue, 10 January 2017, 08:44:59 »
I've always wanted to try split spacebar because I never press it with my left thumb, and having an extra key in close range seems quite beneficial. It looks like the split spacebar gap will be really close to where I press and could cause issues.  Anyone have feedback that has tried a split spacebar?
I almost always hit it with my right thumb just to the left edge of the "N" key, but sometimes drift over to between the "B" and "N" key.
Offline raymogi
« Reply #99 on: Tue, 10 January 2017, 08:54:06 »
pls
Please feed my addiction.
