Author Topic: [GB] FJELL (Closed for Orders)  (Read 286899 times)
Offline E3E
Re: [GB] FJELL
« Reply #200 on: Sun, 15 January 2017, 15:11:36 »
I haven't tried top mounted yet when it comes to 60%. It's hard to say which I'd prefer more, though I do really like the compatibility and solidness of the one piece tray style. In my experience with plates that are "suspended" from being top-mounted, both in vintage designs and customs, there's a bit more springiness to the typing feel. A bit more flex because of there being that floating area of plate around the mounting points.
I notice, with my Orion v2, now using carbon fiber for the plate material, but with stainless steel as well, that you can feel the energy of the bottoming out being transferred through the plate. Like I can feel vibrations in my left hand through the keys when I'm using my right for typing and vise versa.
With the tray-mounted version, the case pretty much deadens all that, especially if you use something like a shelf liner mat or sorbothane.
I haven't dampened my Orion though, mainly because  Alps SKCM Blue would become pretty muted. I'm sure if there was pressure beneath the PCB, it would deaden those vibrations.
It's actually something I've seen a lot of vintage top-mounted Alps boards do. There's usually some kind of dampening device in between the PCB and case supporting it. Usually some kind of rubber pad.
It does kind of feel nice though. :P
With tray-mounted, it feels like you're typing on a brick, haha. Which can be good for certain things, like linears. Very solid feel there.
Offline menuhin
Re: [GB] FJELL
« Reply #201 on: Sun, 15 January 2017, 15:43:37 »
This is what I've heard too: use a very solid construction for linear switches, and a softer construction for tactile and clicky switches.
The question is, what kind of plate mounting is softer and which is more solid.
Some say is top-mount, some say is tray-mount.
I think top-mounting for 60% and 75% perhaps will not be as springy (how you described it) as in a TKL.
p.s. I'm now using a switch-to-PCB mounted capacitive rubber-dome board, when my left hand types, my right hand doesn't feel much.
« Last Edit: Sun, 15 January 2017, 15:45:22 by menuhin »
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline E3E
Re: [GB] FJELL
« Reply #202 on: Sun, 15 January 2017, 15:51:59 »
Being that I want to use SKCM Browns with this case, I'm not sure. Tray-mounted, imo, is obviously the more solid option because of the PCB being screwed into the bottom like that. You could argue that the plate itself isn't mounted at all... Hmmm. Still, the PCB has tons of support and contact points.
I just don't want the tactility to be too harsh, but I think it'll be fine. I like the springiness on the Orion v2 though.
I think the seamlessness of a one-piece style is more attractive, but I'll keep a look out for the two piece top mounted design too
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #203 on: Sun, 15 January 2017, 16:40:44 »
Sent from my Nexus 5X using Tapatalk
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: [GB] FJELL
« Reply #204 on: Sun, 15 January 2017, 16:46:06 »
The X60 is an example of a top mounted 60%.
Offline fublamchu
  • ㅋㅋㅋ
Re: [GB] FJELL
« Reply #205 on: Sun, 15 January 2017, 16:47:20 »
LZ-CE VBlacks
910-CE
Offline Unforgivable
Re: [GB] FJELL
« Reply #206 on: Sun, 15 January 2017, 16:48:45 »
Offline aaron6301
  • Pixel Pusher
Re: [GB] FJELL
« Reply #207 on: Sun, 15 January 2017, 16:50:23 »
What switches in the FJELL? It's so quite
Sent from my SAMSUNG-SM-G925A using Tapatalk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #208 on: Sun, 15 January 2017, 16:51:35 »
Mx silents. Lubed 68g.
Offline aaron6301
  • Pixel Pusher
Re: [GB] FJELL
« Reply #209 on: Sun, 15 January 2017, 16:53:17 »
Nice! How's the decreased travel? Or am I thinking if different switches...
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #210 on: Sun, 15 January 2017, 16:53:53 »
You are thinking of the right ones. It is definitely noticeable, but I kinda like it now.
Offline E3E
Re: [GB] FJELL
« Reply #211 on: Sun, 15 January 2017, 17:12:57 »
My good sir, I beseech thee to stop the hype. It is too much for my feeble heart.
God damn, that thud though. I'm hyped!
Offline nmur
  • ಠ_ಠ
Re: [GB] FJELL
« Reply #212 on: Sun, 15 January 2017, 17:13:35 »
ha ha ha jokes on you winners, i get to keep money in my bank account
grats tho, i'm real jelly
Offline aaron6301
  • Pixel Pusher
Re: [GB] FJELL
« Reply #213 on: Sun, 15 January 2017, 17:15:07 »
My good sir, I beesch thee to stop the hype. It is too much for my feeble heart.
Right?! The despair is insurmountable but I am happy for the lucky winners. Can't wait to see some awesome builds.
Offline E3E
Re: [GB] FJELL
« Reply #214 on: Sun, 15 January 2017, 17:15:28 »
True, true. There's also the KMAC Happy, but that's about all I can think of. The OTD 356 Mini has an interesting mounting method too.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: [GB] FJELL
« Reply #215 on: Sun, 15 January 2017, 19:44:18 »
NEVER stop the hype about this product.  Keep it going  :thumb: .
Offline E3E
Re: [GB] FJELL
« Reply #216 on: Sun, 15 January 2017, 19:48:22 »
Did you manage to win a spot in the raffle, Elrick? :D
Offline Elrick
  • Hype Master
Re: [GB] FJELL
« Reply #217 on: Sun, 15 January 2017, 20:08:41 »
FVCK NO, but it still doesn't mean I don't go cheering on from the sidelines for this Baby.
Great design always needs it's fanboys and you can put me down as one of them.  Just because I didn't win anything doesn't mean I park the hype and forget about this product.
The lucky ones who have this, treasure it forever because you won't get another one like this from any other person.
Offline Jedi
Re: [GB] FJELL
« Reply #218 on: Sun, 15 January 2017, 21:27:55 »
^^^ preach bb :*
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #219 on: Sun, 15 January 2017, 22:45:06 »
Sorry you didn't get one this time elrick , thanks for the support!
Offline nathanrosspowell
    • nathanrosspowell.com
Re: [GB] FJELL
« Reply #220 on: Sun, 15 January 2017, 23:17:35 »
When you have the 'Hype Master' in your thread, you know you've got something good on your hands! Congrats to the winners!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #221 on: Sun, 15 January 2017, 23:36:37 »
Thanks ! :D
Offline fublamchu
  • ㅋㅋㅋ
Re: [GB] FJELL
« Reply #222 on: Sun, 15 January 2017, 23:50:27 »
What will the deposit be?
LZ-CE VBlacks
910-CE
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #223 on: Sun, 15 January 2017, 23:51:47 »
Not decided yet, but the idea is that the money is with you as long as possible.
Offline braidn
Re: [GB] FJELL
« Reply #224 on: Mon, 16 January 2017, 07:44:04 »
Hmm. Did the winnings go out as PayPal invoices or PMs here? Not sure if I won a spot or not and am quite excited
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #225 on: Mon, 16 January 2017, 07:49:06 »
If you win you should have got a mail by now.
Offline hanoipho
Re: [GB] FJELL
« Reply #226 on: Mon, 16 January 2017, 10:47:28 »
Congrat the winners! Will join Fjell r2 GB again  :))
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #227 on: Mon, 16 January 2017, 11:34:57 »
Thanks for the support!
Offline roostrc0gburn
  • its just plastic
Re: [GB] FJELL
« Reply #228 on: Mon, 16 January 2017, 11:38:45 »
is there an estimate as to when invoicing will begin?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #229 on: Mon, 16 January 2017, 11:40:14 »
No, but we are going into a waiting period where we wait for samples, so it won't be before February, probably.
Offline Marvellion
Re: [GB] FJELL
« Reply #230 on: Mon, 16 January 2017, 11:46:50 »
Quote from: LeandreN link=topic=86822.msg2340937#msg2340937 date=
 You can actually see desk breaking in half thanks to the heft, but seriously its awesome really good job with it!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #231 on: Mon, 16 January 2017, 14:47:17 »
I haven't got an answer from all the buyers yet, so I may be in contact with you if they drop out. :)
Offline aaron6301
  • Pixel Pusher
Re: [GB] FJELL
« Reply #232 on: Mon, 16 January 2017, 15:12:12 »
The hope lives!
Offline JDragon
Re: [GB] FJELL
« Reply #233 on: Mon, 16 January 2017, 15:48:33 »
Will the non-responsive slots be replaced via RNG also?
I think I'm on a 10 raffle losing streak... hoping R2 comes fast.
Offline Elrick
  • Hype Master
Re: [GB] FJELL
« Reply #234 on: Mon, 16 January 2017, 16:58:50 »
Just hold the faith, something like this doesn't occur too frequently but if the OP isn't getting any responses naturally move it on over to people who will lay down the money instantly.
This is exactly like throwing dice against the wall, most of the time you will lose so you always try it again and again until you get the golden 12  :thumb: .
Offline pixelpusher
Re: [GB] FJELL
« Reply #235 on: Mon, 16 January 2017, 20:06:17 »
Hmmmmm.... I'll just keep checking my paypal email address.  I don't suppose you sent the winners an email under the subject of "discount viagra"?  If so, I may have won several spots!
Offline Elrick
  • Hype Master
Re: [GB] FJELL
« Reply #236 on: Mon, 16 January 2017, 20:10:47 »
NO that's just you visiting several Pron sites and clicking on sample videos to view  8) .
Offline E3E
Re: [GB] FJELL
« Reply #237 on: Mon, 16 January 2017, 20:51:18 »
This case is pretty much discount viagra enough. Congrats!
Offline XG3njiX
Re: [GB] FJELL
« Reply #238 on: Mon, 16 January 2017, 23:07:59 »
Anyone know how many slot will be opened for round 2?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #239 on: Mon, 16 January 2017, 23:44:30 »
More, but I haven't decided yet. Depends on how this round goes.
Offline Elrick
  • Hype Master
Re: [GB] FJELL
« Reply #240 on: Tue, 17 January 2017, 01:57:48 »
Takes time, although LZ always has a STRONG cut off date for all payments otherwise the recipients will drag it on for weeks or even months, before a single cent is handed over.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #241 on: Tue, 17 January 2017, 15:22:11 »
There will be a strict cutoff date for payment, but it isn't announced yet. Need to get finished with the prototyping stage first.
Re: [GB] FJELL
« Reply #242 on: Tue, 17 January 2017, 15:38:01 »
Has everyone replied to an email yet? If not, do we still have a chance?  :'(
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] FJELL
« Reply #243 on: Tue, 17 January 2017, 15:43:06 »
Not yet, but I will be contacting people this week
Offline pixelpusher
Re: [GB] FJELL
« Reply #244 on: Tue, 17 January 2017, 16:25:10 »
Oh, you must have misstyped my email address.  I'm sure I'll bet getting in soon.  :-*
Offline Elrick
  • Hype Master
Re: [GB] FJELL
« Reply #245 on: Tue, 17 January 2017, 20:11:15 »
LeandreN you have to have mercy for this poor fellow, he wants it so BADDDD  ;) .
Offline keyit
Re: [GB] FJELL
« Reply #246 on: Wed, 18 January 2017, 02:06:51 »
I need that purple.  :-X
boop
Offline Elrick
  • Hype Master
Re: [GB] FJELL
« Reply #247 on: Wed, 18 January 2017, 02:38:55 »
We all do, just have to wait for R2 in the future  :thumb: .
Offline mrboovn
Re: [GB] FJELL
« Reply #248 on: Wed, 18 January 2017, 02:54:22 »
No invoice.I will wait for R2   :(
Offline ticktwo
  • -kbdfan
Re: [GB] FJELL
« Reply #249 on: Wed, 18 January 2017, 07:09:09 »
not participate R1 and will wait for R2  ;)
HHKB | Leopold FC750R | Mech27 (soon) | TX-75 (soon)
