Author Topic: Any recommendations for a wall mount keycap display?  (Read 4192 times)
Offline Cocopah
  • Lurker Extraordinaire
« on: Fri, 13 January 2017, 12:29:40 »
Hey I've been looking for an option to wall mount a keycap display. Does anyone know of any options?
Re: Any recommendations for a wall mount keycap display?
« Reply #1 on: Fri, 13 January 2017, 13:00:18 »
If you have got a Cherry MY keyboard, snap off all the switches and sand the bottoms. Then you could glue those onto a flat sheet. They are not perfectly 1×1 key sized at the base, but almost.
I have flattened quite a few of Cherry MY switches myself for building keyboard prototypes and testing out layouts.
I have also got a couple of fridge magnets made from MY switches as a gift from another member.
I also seem to recall a special contraption that was one piece of plastic with lots of stems on them but I can't recall what it was, sorry. Hopefully, me mentioning it will jog someone else's memory.
Offline menuhin
« Last Edit: Fri, 13 January 2017, 13:23:17 by menuhin »
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
« Reply #3 on: Fri, 13 January 2017, 13:11:03 »
I never got anywhere but I asked the same thing once
https://geekhack.org/index.php?topic=44102.0
Offline menuhin
« Reply #4 on: Fri, 13 January 2017, 13:17:15 »
Similar thread but for artisan caps and not really wall-mounted.
https://geekhack.org/index.php?topic=72253.0
IBM M13 black
HHKB Pro 2 HasuBT
Offline Cocopah
« Reply #5 on: Fri, 13 January 2017, 13:18:47 »
Hmm those are all options. What I had in mind was acrylic similar to the taobao with stems.
https://world.taobao.com/item/523182869340.htm#detail
