Author Topic: [IC] DSA Basic - 60% Keyset for ALPS Switches  (Read 4416 times)
Offline jjanssen1
« on: Mon, 16 January 2017, 19:22:13 »
Hi all,
With the latest round of TMK Alps 64 available, I designed this keyset for alps keyboards in a 60% form-factor.
So, I present to you:
DSA Basic
Please feel free to leave any comments/criticism/suggestions  :)
-Josh
EDIT: 17 Jan 2017, 12:52:03 Updated Kit contents
« Last Edit: Mon, 16 January 2017, 19:52:52 by jjanssen1 »
IBM Model M 1386303
Offline Captainbuttmonkey
Re: [IC] DSA Basic - 60% Keyset for ALPS Switches
« Reply #1 on: Mon, 16 January 2017, 19:42:06 »
Was hoping somebody would do this. Looks good mate, only possible thing I would suggest is maybe including a black on white backslash? I realise it's not a mod but some people like the symmetrical look. Might be nice to have the option? I'm down to buy it anyway =].
Offline jjanssen1
« Reply #2 on: Mon, 16 January 2017, 19:47:59 »
only possible thing I would suggest is maybe including a black on white backslash?.
I'll go do that now  :thumb:
IBM Model M 1386303
Offline jjanssen1
« Reply #3 on: Mon, 16 January 2017, 19:53:15 »
Here you go:
-Josh
IBM Model M 1386303
« Reply #4 on: Mon, 16 January 2017, 19:55:48 »
Here you go:
-Josh
Nice one :thumb:
Offline entr0py33
« Reply #5 on: Tue, 17 January 2017, 04:32:49 »
« Last Edit: Mon, 18 January 2021, 11:46:29 by entr0py33 »
Offline jjanssen1
« Reply #6 on: Tue, 17 January 2017, 05:02:42 »
Looks great!  :thumb:
Maybe add a black "~ `" 1U key?
A few questions:
(1)-What are the PMK color codes for this set?
(2)-Have you considered symbol modifiers, or do you prefer text modifiers?
(3)-Are you planning on supporting some of the other 60% layouts that the Alps64 PCB supports (i.e. Infinity, Winkeyless, HHKB, AEK, etc)?  Here's a quick keyboard-layout-editor of some of the keys that might be needed if you wanted to go that route: http://bit.ly/2iC7lD4
"Maybe add a black "~`" 1U key?"
Good idea, I will defiantly do that.
1. NN & WA
2. I prefer text modifiers but if there is enough interest I will do symbol modifiers.
3. Yes, this Interest Check was more for the colorway, the set is no where near final. And thanks for the KLE link, that will help me out a lot  :thumb:
Hope this helps
-Josh
IBM Model M 1386303
Offline stoic-lemon
« Reply #7 on: Tue, 17 January 2017, 06:16:51 »
Support for AEK would be great.
Offline BAS1C
« Reply #8 on: Wed, 18 January 2017, 19:02:59 »
Ooooooh looks like this was meant for me ;)
Nice! :thumb:
Offline smithyithy
  • a l p s
« Reply #9 on: Mon, 17 April 2017, 12:31:04 »
Been a while, but any movement on this? I'd definitely be up for it, I think a sharp black/white DSA set for Alps would be sweet.
KBD75; Alps64 trio; some other stuff
