Author Topic: Upside down cherry switches  (Read 4537 times)
Offline JackieOReally
« on: Wed, 18 January 2017, 02:37:14 »
Hi, I bought a new filco and some of the switches are upside down, what do I do ?
Re: Upside down cherry switches
« Reply #1 on: Wed, 18 January 2017, 02:58:08 »
Does it work fine? I'm pretty sure some switches are upside down just because of the way the pcb is designed.
Offline ghostjuggernaut
« Reply #2 on: Wed, 18 January 2017, 04:42:46 »
Yep I have had the same thing. It doesn't make a difference.
« Reply #3 on: Wed, 18 January 2017, 04:46:09 »
If it works, then don't worry. Keyboards with Cherry MX switches and backlighting have all its switches "upside down".
The switch design allows keyboards to have switches oriented up, down or even left or right.
Offline smithyithy
  • a l p s
« Reply #4 on: Wed, 18 January 2017, 06:13:18 »
MX Browns on my MagicForce are upside down. They're the white LED version, perhaps the reason why?
KBD75; Alps64 trio; some other stuff
Offline pixelpusher
« Reply #5 on: Wed, 18 January 2017, 10:35:41 »
Yes, the switches are upside down so that if you add LEDs the light will be at the top of the key (where the legends usually are).  All is normal.
« Reply #6 on: Wed, 18 January 2017, 13:15:36 »
Thanks guys. Hadn't seen one upside down before.
« Reply #7 on: Wed, 18 January 2017, 13:16:43 »
A lot of companies do that to make the LEDs at the bottom. Doesn't affect anything else.
Offline sems
« Reply #8 on: Wed, 18 January 2017, 13:50:50 »
My atreus has some switches sideways, I don't think that would be a problem at all.
