Author Topic: Swappable switch mount  (Read 2000 times)
Offline tototoru
« on: Fri, 20 January 2017, 19:31:06 »
Hi,
I came across the Team Wolf ZhuQue keyboard (probably have other names), it has an interesting feature which is a mount for switches, so you can plug and unplug switches easily.
I was wondering if this mount is available somewhere.
« Last Edit: Fri, 20 January 2017, 19:33:23 by tototoru »
Offline Entropia
Re: Swappable switch mount
« Reply #1 on: Sat, 21 January 2017, 10:35:05 »
I've heard Tesoro is introducing a new keyboard at CES 2017 which has a sort of optical MX clones switches that are not soldered to the board and can be hot swapped easily.
Offline tototoru
« Reply #2 on: Sat, 21 January 2017, 11:06:23 »
A solution that can work for any standard switch will be better, these parts look very cheap and are very likely available in China.
