Author Topic: DIY USB cable materials  (Read 5014 times)
Offline mniels
« on: Sun, 22 January 2017, 18:37:56 »
Not sure if this is the right sub-forum, but does anyone know of a good distributor for raw USB cables and connectors?  I have purchased kits and what not in the past from places like 1UP, but you are obviously paying a premium in those circumstances.  Could be solderless connectors or the regular kind.  Heat shrink is easy enough to find, but it is a jungle out there just looking for other parts.
Any point in the right direction would be appreciated!
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: DIY USB cable materials
« Reply #1 on: Mon, 23 January 2017, 10:51:50 »
i ordered all my connectors from aliexpress. As for the cable itself, the only place i've found that sells it in bulk is i'm sure the same place you found.
-Dana
Offline cicada
  • Formerly iamacicada
« Reply #2 on: Mon, 23 January 2017, 11:33:26 »
I ordered my connectors from taobao and paracord sleeves from paracordplanet. Just put USB DIY or something similar in the search box and you will see plenty of options.
