Author Topic: [GB]GMK Dolch(Fill in the form for address changes)  (Read 288193 times)
Offline longtran1568
Re: [GB]GMK Dolch, Dolch AddOn & x-CMYW
« Reply #150 on: Mon, 27 February 2017, 14:51:11 »
Full icon modifiers, maybe?
Personally not a fan... :blank:
Offline ideus
  • Björkö.
« Reply #151 on: Mon, 27 February 2017, 15:21:22 »
But, this set has icon already??
« Reply #152 on: Mon, 27 February 2017, 16:22:43 »
I mean not 100% all icon mods :)
Offline poolside
« Reply #153 on: Mon, 27 February 2017, 17:34:30 »
Update on kits, please leave down your feed backs.
Changes on 3rd revision compared with 1st revision:-
  • Dolch Icon
    • Added 2 Iso Keys
    • Added 1.25u Alt Gr
  • Dolch Add-On Kits
    • Added 1u Backspace
    • Added 2u Shift
    • Added 1.75u Control
    • Added 2u Blank
  • Dolch Color Kits
    • Added Backspace(s) 1u, 1.5u, 2u
    • Added NumLock
Expected Price Increased:
1. Dolch Icon -> $2.40
2. Dolch Add-On  -> $3.50
3. Dolch Color Kits -> $4.00
** Please note that these are just my assumption, I will get the exact amount after I get the latest quote from GMK.
Nice additions.
A few more ISO compatibility options. Thanks for including the keycaps suggested by ideus! :thumb: I must not forget to place my order.
Edit: An small detail, I suggest you to consider the down arrow instead of the hand bag for the caps lock, it goes far better in a full icon mod set than the hand bag. All the European OG Cherry sets featuring Icon only mods carries it instead of the hand bag.
Please compare this two, it seems to me that the first is more elegant, simple and graphically sound than the second.
Down arrow.
Hand bag.
I like the two options. The down arrow being more uncommon has its charm. I have not developed a preference for one over the other yet, I guess.
Kudos to Kekkon for the additions, it keeps on improving.
This GB is going to increase a lot the possibility of the Dolch set.  :thumb:
I also second the suggestion of ideus about split space bar addition to boost sales, but I am not sure if it is possible to have the split space bars in real space bar profile or are just blanks in R4 profile.
For your information, two current IC/GBs (GMK HADapter kit Round 2 & GMK Yuri) have included a split space bar kit, and this is how they look like:
For the Forum kit.
If I remember correctly, in the original request of the addition of Forum keys, we were not asking to add a forum kit but to have the forum keys replace the GMK and Q keys that exist in the current templates of both the base kit and the color kit.
I am sure 99.99% of the users will not use the GMK and Q keys - even if GMK gives us free of charge, and it's not like we don't like GMK as a company. It is okay to let us know if these two keys are in fact sponsored by GMK.
Please see if the two forum keys can replace the two GMK and Q keys in the base kit and the color kit.
We will all thank you for this.  ;)
1.5u R4 Diamond keys for HHKB.
The diamond icons are the meta-key icons of HHKB and Sun MicroSystem keyboards, and addition of this design is feasible possibly in a lower cost because GMK has recently acquired this design also, i.e. it exists already as an R4 key:
There are quite some HHKB (or the layout) followings, and this addition will make the Add-on kit more complete and special for the HHKB users out there.
P.s. Ah.... can there be LED caps? How much will the inclusion of say 2 to 3 LED caps increase the cost of a kit?
Some of these diamonds keycaps would be great. I think they would be a pretty replacement to those, which look like Windows 8/10 keycaps too much:
Offline kekkon
« Reply #154 on: Wed, 01 March 2017, 02:09:26 »
Thanks for all the input, I have made a final adjustment to the Add-On Kits. These will be finalize and I will get quote from GMK, expect invoicing to begin soon.  :thumb:
As for the split spacebar kits, I think we should wait for the new GMK mold to come out and see what they are going to offer, because those are real "spacebars" profile, unlike current one which is in "shift" shape.
Offline ricyuyc
« Reply #155 on: Wed, 01 March 2017, 04:23:17 »
Is it possible to keep both the 1.5u boxed Del & the simple arrow Backspace, at the add-on kit?
Offline ideus
  • Björkö.
« Reply #156 on: Wed, 01 March 2017, 05:42:35 »
I concur that actual space bars are required not blank shift keys.
Is the GB original dead line the same? Current OP's date is March 10.
What would be the payment period? Current OP's date is March 10 - 24.
Are original dates still firm? If not, please update the OP accordingly.
« Last Edit: Wed, 01 March 2017, 05:48:09 by ideus »
Offline menuhin
« Reply #157 on: Wed, 01 March 2017, 06:01:54 »
 :p :)) :cool:
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline mniels
« Reply #158 on: Wed, 01 March 2017, 06:15:16 »
Is there a spreadsheet anywhere to doublecheck our orders.  I apologize in advance if I am blind and missed the link....   :eek:
Offline soilheart
« Reply #159 on: Wed, 01 March 2017, 07:07:23 »
Well, the first "reply" seems to be what you're after =P
Please verify if your order information is correct : Check your entry here.
(K70 -  Brown) --- Pok3r - Clear --- Ducky Shine4 - Clear --- WKL B.face X2 - 67g Zealios --- CP-SQ - 78g Zealios --- RS68 - 62g Zealios
(Sold/retired - To be built)
Offline mniels
« Reply #160 on: Wed, 01 March 2017, 07:08:24 »
Yep. Definitely blind.
Offline poolside
« Reply #161 on: Wed, 01 March 2017, 17:19:52 »
Shiny diamonds! I hope the add-on and color kits will both reach MOQ.
Offline ihalatch
« Reply #162 on: Thu, 02 March 2017, 03:05:23 »
On Forum kits, it will be around $11. Initially I have been wanted to fit them into the Icon and Color kits respectively, but not everyone buy them so I think it is best for us to keep them separate.
I will make a separate form for it.  :))
Where is the order form for the forum keycaps?
Offline kekkon
« Reply #163 on: Thu, 02 March 2017, 21:02:12 »
I have yet to received latest quote, hopefully I can get it by tonight and start invoicing over the weekend.
I have also updated the latest count, it seems the base has already made it, while other are not far behind, hopefully they will be 80% paid invoices.  :thumb:
« Last Edit: Thu, 02 March 2017, 21:57:23 by kekkon »
« Reply #164 on: Fri, 03 March 2017, 13:00:26 »
Definitely plan on ordering the child kits; just haven't done so yet.  :p
Offline menuhin
« Reply #165 on: Fri, 03 March 2017, 14:26:50 »
@kekkon
If I want to change my order or add something to the order, do I post it here or can I just PM you?
IBM M13 black
HHKB Pro 2 HasuBT
Offline ideus
  • Björkö.
« Reply #166 on: Sat, 04 March 2017, 10:36:26 »
Is there a spreadsheet anywhere to doublecheck our orders.  I apologize in advance if I am blind and missed the link....   :o
Is the table updated? It shows 102 orders for the base set, only.
Offline codedisorg
« Reply #167 on: Sat, 04 March 2017, 12:35:39 »
@kekkon
Same question here as well.
« Reply #168 on: Sat, 04 March 2017, 12:41:58 »
@kekkon
I PM him about modifying my order too, and every thing turned out fine, so you guys could just drop him a message :)
Offline mindxthinker
« Reply #169 on: Sun, 05 March 2017, 11:39:39 »
 Is base font color white? or bluish white?
Offline lunr
« Reply #170 on: Sun, 05 March 2017, 19:45:47 »
wish I can just buy the icon mods but i can't go wrong with more dolch.
Offline kekkon
« Reply #171 on: Sun, 05 March 2017, 22:10:39 »
I have done update all orders changes/cancellation from PM/Email, please check the response sheet. For those who want to make changes, please PM me and I will update it accordingly.
I am still waiting for GMK on the latest quotation, hope to get it soon. Since the invoicing only started this week, the GB closing date will be extend 1 or 2 more weeks depend on the payments.
Regarding the MOQ, it is actually combination on both GH and Taobao orders.
Offline gojira54
« Reply #172 on: Mon, 06 March 2017, 01:36:43 »
I have PMd you requesting to add 1x CMYW pack but haven't heard back? Would like to add it pls =]
Offline loud_asian
« Reply #173 on: Mon, 06 March 2017, 02:28:27 »
check the spreadsheet
kekkon didnt reply, but he updated the spreadsheet with my order
Offline Giorgio
« Reply #174 on: Mon, 06 March 2017, 03:31:37 »
No bar on the numpad 5?
Can't we replace the uniqey Q with the 5 with an homing bar?
« Last Edit: Mon, 06 March 2017, 04:14:50 by Giorgio »
« Reply #175 on: Mon, 06 March 2017, 10:30:53 »
Actually, I think it would be best to add more GMK "Q" logos in different sizes. It wouldn't add much and will let people know the set is made with modern layouts in mind, since the "Q" layout is a modern logo.
A modern logo for a modern design.
Offline TalkingTree
    • My projects
« Reply #176 on: Mon, 06 March 2017, 11:35:57 »
I wouldn't mind winkeys with the Q logo, granted that they are 1u R5 of course.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #177 on: Mon, 06 March 2017, 15:08:10 »
Just joined for a full kit! Excited for the turnout of this revival of GMK Dolch.
Offline kmba
  • Formerly tameone
« Reply #178 on: Mon, 06 March 2017, 23:54:43 »
how close is the color kit to MOQ?
keyboards.
Offline Giorgio
« Reply #179 on: Tue, 07 March 2017, 05:03:33 »
You can have how many Qs you want, but they need to have an homing bar.
Modern homing bars for a modern design, that bars ancient dots and scoops on new homing concepts.
« Last Edit: Tue, 07 March 2017, 06:26:58 by Giorgio »
Offline kekkon
« Reply #180 on: Tue, 07 March 2017, 08:57:11 »
Let me get the latest quote from GMK before deciding to add homing numpad 5, I personally feel dot is good enough.  :))
I have actually done the "Q" in R4 before this, but it is better in R1 as Esc  :p
Offline kekkon
« Reply #181 on: Tue, 07 March 2017, 09:01:00 »
I would say it was very close, let's see what is the outcome when the invoicing begin. :)
« Reply #182 on: Tue, 07 March 2017, 09:15:33 »
kekkon did my order went through??
« Reply #183 on: Tue, 07 March 2017, 09:19:45 »
You're right. :eek:
Offline need
« Reply #184 on: Tue, 07 March 2017, 09:40:33 »
Let's put in a cherry logo to replace one of the QQQQQ
Offline ideus
  • Björkö.
« Reply #185 on: Tue, 07 March 2017, 12:43:20 »
This set is really way too special, to let it to pass. Ordered.  :thumb:
Offline kekkon
« Reply #186 on: Tue, 07 March 2017, 20:00:19 »
We can't use the new GMK Cherry Logo anymore, other than one specific company.
Offline YH YOON
Re: [GB]GMK Dolch(Check your orders at Reply#1)
« Reply #187 on: Tue, 07 March 2017, 20:22:17 »
Checked it. !!
« Reply #188 on: Tue, 07 March 2017, 20:39:25 »
Gonna place an order for Add-on and Color this week. :thumb:
Offline kekkon
« Reply #189 on: Wed, 08 March 2017, 08:21:11 »
I have got the latest price, will send out invoice batch by batch this week. :p
A separate form had been made for the Forum Kits, it will be billed separately.  :p
https://goo.gl/forms/NdetA8YfIiWjOqWl2
The front page and order has also been updated with latest price change, and currency change, which result in price reducing/small price increase for all the sets.  :thumb:
« Last Edit: Wed, 08 March 2017, 08:47:33 by kekkon »
Offline need
Re: [GB]GMK Dolch(Added Forum Kits)
« Reply #190 on: Wed, 08 March 2017, 08:54:12 »
Wait, so is this the add-on kit? I'd be surprised if this costs $40.
Offline diiiP
« Reply #191 on: Wed, 08 March 2017, 09:07:52 »
First post and order form shows this:
Offline kekkon
« Reply #192 on: Wed, 08 March 2017, 09:11:02 »
Yeap, this is the one. Do you mean it is too expensive?  :-X
This is the old 3D rendering, newer one will be updated after this.
Offline ideus
  • Björkö.
« Reply #193 on: Wed, 08 March 2017, 09:15:46 »
I´d like to get my invoice as soon as possible. I know that I ordered late, though, exchanges rates fluctuate a lot where I live.
Offline need
« Reply #194 on: Wed, 08 March 2017, 09:31:00 »
Sorry I was just surprised there's no price increase after having the added support for 68, 75%, Minila. It's still $40 right?
Offline kekkon
« Reply #195 on: Wed, 08 March 2017, 09:34:41 »
There are actually $2~$3 price increase.  :))
Offline t0rk
  • Still waiting on a Topre Planck..
« Reply #196 on: Wed, 08 March 2017, 10:40:46 »
Not looking great for anything but the Base and Spacebar kits hitting MOQ.
Offline KHAANNN
« Reply #197 on: Wed, 08 March 2017, 12:09:45 »
Not having a paypal stings, that 1.75 Stepped Ctrl is a must have
Offline ideus
  • Björkö.
« Reply #198 on: Wed, 08 March 2017, 12:11:29 »
+1
That key is one of the reasons I am buying this.
Offline -musubi
  • Spam rice 'n eggs
« Reply #199 on: Wed, 08 March 2017, 13:19:50 »
Will shipping costs be combined for multiple kits (base + others)?
