Author Topic: [GB] LZ CLS (Classic TKL) : Finished  (Read 384143 times)
Offline HappyCatFish
Re: [GB] LZ CLS (Classic TKL) : Finished
« Reply #1150 on: Sun, 08 October 2017, 08:41:14 »
What switches do you guys use polycarb with?
I am a huge fan of the ergo-clears on the plastic plate that I built my Orion V2 with, but at the end of the day it's all personal preference. Build it how you want it.
Offline gadzkun
« Reply #1151 on: Thu, 19 October 2017, 10:16:54 »
hi LZ i finished build my alps CLS, but something wrong with it.
at first i was think it maybe my switch was broken, so i try to change it with another one, but it still wont work,
so i try to change diode too but it still wont work too.
can you help me with it? i got so many problem with my LZ-CLS to be honest :(
« Last Edit: Thu, 19 October 2017, 10:19:46 by gadzkun »
Offline loud_asian
« Reply #1152 on: Thu, 19 October 2017, 11:07:34 »
Did you test the PCB before you soldered?
Offline alienman82
« Reply #1153 on: Thu, 19 October 2017, 19:03:36 »
removed.
« Last Edit: Thu, 01 March 2018, 00:02:25 by alienman82 »
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #1154 on: Thu, 19 October 2017, 19:29:17 »
I'm guessing some of those barrel resistors arent right... they were pretty tricky to solder.
« Last Edit: Thu, 19 October 2017, 19:30:51 by OfTheWild »
-Dana
« Reply #1155 on: Thu, 19 October 2017, 19:32:27 »
looks weird with no centerholes
« Last Edit: Thu, 19 October 2017, 19:50:45 by Puddsy »
Offline alienman82
« Reply #1156 on: Thu, 19 October 2017, 20:59:20 »
removed.
« Last Edit: Thu, 01 March 2018, 00:02:20 by alienman82 »
« Reply #1157 on: Thu, 19 October 2017, 21:25:50 »
diodes?
shoulda got the ones packaged in plastic.  those glass ones look scary like they will break
it's what's included with the PCBs
i got the same ones from kin when i got my 3000 pcb
Offline gadzkun
« Reply #1158 on: Thu, 19 October 2017, 22:28:06 »
DSA on alps is something I'd like to try.
you like that?
Hmmm i still dont know yet how it feels its my first time build alps xD
But its quite good i still try adapt to it.
I ask my friend who really good at soldering so i will ask him again to check it.
I dont know how to check pcb xD. I'll ask my friend to check it.
Offline zimo
« Reply #1159 on: Sun, 22 October 2017, 06:27:18 »
Is there any tutorial about firmware?
I don't know how to set it, I don't even know how to get into it
Offline DreLLin
« Reply #1160 on: Sun, 22 October 2017, 06:33:08 »
The PCB is Designed/Developed by Leeku
The PCB is Programmed with JigOn firmware : http://kbdlab.co.kr/index.php?mid=board_sw&document_srl=2702787
PCB S/W (JigOn)
 English language documentation for Leeku's L3 Boards
https://geekhack.org/index.php?topic=83950.msg2236885#msg2236885
Are the plate files for the CLS available? Would love to get a brass and/or pc or carbon plate.
Offline mech0nly
« Reply #1161 on: Sun, 22 October 2017, 06:35:17 »
PCB S/W (JigOn)
LZ CLS Self Tunning   :D
For CLS MX switch plate(1.5mm)
https://goo.gl/a2w2o3
For CLS Weight plate(5mm)
https://goo.gl/DB6JTd
I might be interested in pc plate, its too expensive to cut for myself alone.
356mini | 360C | G81-3000SAT | G81-3000SAU | G80-3000LPCXY-2 | G80-3485LWNUS-2
Diamond Polished Cherry Switches!
Offline zimo
« Reply #1162 on: Sun, 22 October 2017, 06:53:39 »
PCB S/W (JigOn)
Thanks!!
Offline zimo
« Reply #1163 on: Sun, 22 October 2017, 07:07:58 »
PCB S/W (JigOn)
How to into the USB mode,I cant conect keyboard
Offline DreLLin
« Reply #1164 on: Sun, 22 October 2017, 09:37:59 »
PCB S/W (JigOn)
Ok, here is another step by step manual:
- Download L3_170419.zip (http://kbdlab.co.kr/?module=file&act=procFileDownload&file_srl=4320094&sid=ebbdca3c12b3174f582b4c8dc470ecce)
- Download JigOn_170419.zip (http://kbdlab.co.kr/?module=file&act=procFileDownload&file_srl=4320093&sid=a2dfd681007fec4c849850a5530a4df9)
- Unzip both files go
- Open loadfw.bat in L3_170419
- It will then flash the Leeku L3 keyboard with that version of the firmware.
- If you get a “communications error” when flashing, try a different USB cable and/or port. For me, it turned out using a different port worked, even though the keyboard could *type stuff* using the first port, it couldn’t flash the board.
- Open JigOn.exe in JigOn_170419 Folder
- Download and follow the guide Leeku L3 Software.pdf from https://www.dropbox.com/sh/v24vygvyl4mvqrm/AABUNcm0BDioYE5QbArje0Kba?dl=1
Hope this helps.
Offline zimo
« Reply #1165 on: Sun, 22 October 2017, 10:30:51 »
PCB S/W (JigOn)
Hope this helps.
Very detailed, thank you for your patience!
Offline megaforce
« Reply #1166 on: Mon, 30 October 2017, 18:20:39 »
Promised someone photos of my cerakote'd TX-84 here (better late than never): https://imgur.com/a/tLILX
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline Unforgivable
« Reply #1167 on: Mon, 30 October 2017, 18:22:35 »
Very nice! Was this place local? How much did it run you? Any pros/cons versus standard anode? :)
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1168 on: Mon, 30 October 2017, 19:58:19 »
Nice! Thanks for posting.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline megaforce
« Reply #1169 on: Mon, 30 October 2017, 21:12:07 »
Thanks! Yes it was local, ran $110 in cash (was less if I wanted one color). With cerakote you necessarily don't have to strip the original anodizating and an even result is easier to achieve than anodizing.
You're welcome!
Offline popkorn62
  • No keyboards for old men
    • Mekibo
« Reply #1170 on: Sat, 04 November 2017, 23:09:49 »
Selling Alu plate + PCB
I’m keeping the diffuser. Please pm.
http://txkeyboards.com/
Please click LOG IN on register. Bottom page is for newsletter only.
https://mekibo.com/
Offline techfresh
« Reply #1171 on: Sun, 05 November 2017, 10:33:31 »
Pm’ed
Offline DreLLin
« Reply #1172 on: Mon, 13 November 2017, 19:27:13 »
PCB S/W (JigOn)
Got my CLS and the custom brass and pc plates today. The brass plate needed some polishing but turned out nice. Paid 194€ including 19% VAT for both plates but wanted them to be produced locally.
182073-0
182075-1
182077-2
If interested, you can watch the complete build log at Imgur. https://imgur.com/a/zDHXR
Offline airs
« Reply #1173 on: Wed, 15 November 2017, 15:52:03 »
Great build log DreLLin - thanks for posting! What is the reason for this step - "Clipping the legs of the switches for the Alphas. Keeping the legs on Mods and ISO keys with larger plate cutouts"
Also wondering why you used GPL105, GPL106 and the VW lube (GPL105)? Why the spray lube in addition to the drops?
« Last Edit: Wed, 15 November 2017, 16:28:24 by airs »
Octagon v2, LZ CLS
Offline DreLLin
« Reply #1174 on: Wed, 15 November 2017, 16:44:08 »
The legs of the Zeal switches are a little bigger than the cherry ones. It's really hard to push them into the pcb and almost impossible to have them seated flush with the plate and pcb without clipping the legs.
Since the alphas have great support from the plate and alignment is no concern you can clip the legs of the switches without sacrificing anything.
On the mods and ISO keys you have larger plate cutouts and it's harder to align the switches correctly. That's why I dont't clip the legs on these keys and am not so concerned if they aren't 1000% flush with the pcb.
I used the bag before I had the spray for other switches so there was some GPL 105 left in it. From now on I'll only use 106 and the spray since it makes it a bit easier to spread out the lube in the bag and a bit less shaking is required.
Offline airs
« Reply #1175 on: Wed, 15 November 2017, 16:48:22 »
The legs of the Zeal switches are a little bigger than the cherry ones. It's really hard to push them indto the pcb and almost impossible to have them seated flush with the plate and pcb without clipping the legs.
Makes sense, thanks for the reply!
Octagon v2, LZ CLS
Offline jenggo
« Reply #1176 on: Wed, 15 November 2017, 18:10:50 »
Just Finished fixing Gadzkun's CLS.
about 3 controller feet doesn't soldered well to the pcb.
many diodes not soldered to the pcb
and polished the weight
https://i.imgur.com/b5O6iaD.jpg
 :thumb:  :thumb:
Filcos | JD40 | Planck | FJELL | Jetfire | Weaven | GON 60 | BWU | DasKeyboard | PokerII | Strafe | Octagon v2 | TX 1800 | TXCP | Realforce 104UB | KMAC 1 | TXPad | DC60 | Ergos
Offline avid
« Reply #1177 on: Wed, 15 November 2017, 18:37:39 »
Very nice! The black finish is so good. Do you have more pics but of front?
Offline Dreamre
    • kbdlife
« Reply #1178 on: Wed, 15 November 2017, 19:20:25 »
 :thumb:  :thumb:
What did you use to polish?
Offline futurecrime
  • Get Zooted
« Reply #1179 on: Thu, 16 November 2017, 08:34:41 »
PCB S/W (JigOn)
Really nice build log and great result. Thanks for taking the time to do it, I took a few tips to use on my next build.
Offline mech0nly
« Reply #1180 on: Wed, 13 December 2017, 10:20:38 »
Hmmmmmmm, I tried to desolder the USB connector and one of the metal pad that, to me, should stays on the PCB came right off is that normal  :eek: :eek: :eek:.
I'm freaking out right now, not sure if I just broke the PCB or not.
Can USB connector wired to this pad?
Currently i have GON Nerd PCB, but the connector was beneath of the PCB (instead of on top), it must be on top in order to compatible with CLS. Actually there's a pad on top, but the extras part of PCB was cut from vendor (along with the top pad). I just knew this when it arrived. Help....  :'(
Really sorry for potato pic
« Last Edit: Wed, 13 December 2017, 10:33:57 by mech0nly »
Offline mech0nly
« Reply #1181 on: Wed, 13 December 2017, 10:32:19 »
Offline alienman82
« Reply #1182 on: Wed, 13 December 2017, 14:32:39 »
removed.
« Last Edit: Thu, 01 March 2018, 00:21:28 by alienman82 »
Offline rabbitfire
« Reply #1183 on: Thu, 21 December 2017, 09:56:40 »
My connector failed out so I had to desolder everything and solder the connect to PCB. But, it doesn't work. Anyone know how to fix this issue?
184858-0
Offline Delirious
« Reply #1184 on: Tue, 06 February 2018, 17:01:20 »
A bit late because I have to wait for the Time's pcb. My latest abomination with SKCM Blues, hebrew keyset, and a circumcised penis for escape key.
Offline GeneriksGiraffe
  • Living the Rubber Life
« Reply #1185 on: Sun, 27 May 2018, 10:02:45 »
Will there every be a rerun of this? I am so sad I missed this! A custom ALPS tkl would be glorious.
SOMEONE PLEASE SELL/TRADE ME AN HHKB PRO 1
« Reply #1186 on: Sun, 27 May 2018, 10:39:08 »
probably not
