Author Topic: Opening Gateron Switches  (Read 4432 times)
Offline bmmcwhirt
    • KB9YEN
« on: Fri, 27 January 2017, 18:45:16 »
Will the MX switch opening tool work on Gateron switches? I want to swap the springs on my mod switches before installing them.
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1363
Thanks in advance.
Offline joey
Re: Opening Gateron Switches
« Reply #1 on: Fri, 27 January 2017, 18:46:11 »
Thanks in advance.
Yes it will!
Offline bmmcwhirt
    • KB9YEN
« Reply #2 on: Fri, 27 January 2017, 19:13:27 »
Thanks.
Offline Tangtawan
« Reply #3 on: Sat, 28 January 2017, 14:46:59 »
I personally never opened a Gateron before, so can i actually use the exact same method as Cherry MX?
My boards : Model F AT (6450200), Industrial M (1394950), Model M SSK (1391472), Model M13 (13H6705), Model M (1390131), Focus FK-2001 (ALPS SKCM Blue), HHKB Pro 2, Realforce 87U 55g, KBP V80 Matias Click, TADA68 (Gateron Reds), Filco Majestouch 2 TKL (67g Ergo Clears), Cherry G80-11800 (Ergo Clears), KBT One 108 (MX White), Ducky One TKL RGB (MX Black), Filco Majestouch Tenkeypad (MX Brown), Leopold FC210TP (MX Red)
« Reply #4 on: Sat, 28 January 2017, 15:58:29 »
Yes for all the gateron switches I've had it was the same.
Some of the other brands of 'MX compatible' switches are different however.
