Author Topic: [GB] MIRA SE - Custom 80% Keyboard (CLOSED)  (Read 3099670 times)
Offline loud_asian
Re: [GB] MIRA SE - Custom 80% Keyboard
« Reply #50 on: Sun, 29 January 2017, 14:05:18 »
Is this still compatible with the Winkeyless B.87 PCB? Is there an option to buy the case without PCB?
not compatible, the usb port is top left on the b.87, the case has a cutout in between the end of the f row and beginning of the navigation keys
gon's tkl pcb may be compatible though
Offline Will_26
« Reply #51 on: Sun, 29 January 2017, 14:47:58 »
Any example photos of the starlight silver colour? :)
Clear-anodized aluminum (no dye to make it lighter or darker, so just silver).
Thanks for the answer!
Offline laughatpain
« Reply #52 on: Sun, 29 January 2017, 14:50:27 »
GON tkl pcbs are interchangeable with the tx87 pcb, I used one in my tx87 instead of the tx pcb it came with
Offline flopix
    • Laur
« Reply #53 on: Sun, 29 January 2017, 15:03:35 »
Is there a pic of the black variant that I'm missing?
Offline Photoelectric
« Reply #54 on: Sun, 29 January 2017, 15:07:53 »
http://imgur.com/a/PWJdb  (from the Interest Check first post).
Offline ramnes
  • T fou, mec?
« Reply #55 on: Sun, 29 January 2017, 15:31:22 »
Crazy that we're at the GB phase. Never thought that it would work out.
Congratulations guys!
Offline eksuen
  • Ambassador of explosions.
« Reply #56 on: Sun, 29 January 2017, 15:36:24 »
WOOO I AM SO EXCITED FOR THIS!!
- Thanks to everyone for their support in this GB –
Hubble for the initial design, YukTsi for his revisions, and Asilan and EVE for the final rendition of the Mira.
Thank you to FrostyToast for keeping up with the preorders and numbers. I can’t imagine the headache that has been.
Thank you to Zeal for his support and donation of the gold stabilizer set to purchasers of the 57 numbered boards.
Thank you to Limitz for all his support and encouragement when I was ready to stop dealing with this never-ending mess of a group buy.
Thanks to zzyjayfree for finding a manufacturer and dealing with my endless questions and revisions of the Mira.
Thank you to Photoelectric for writing the GB thread and doing the order form for the Mira when I was unable to do so.
Lastly, thank you to Geek Hack and its members for their support of this GB when it seemed like it was sure to fail.
Thank you ninjadoc et al. for all your hard work in order to bring this project to fruition. I just saw Hidden Figures (keeping with the NASA and space theme too :) ) last weekend and I was reminded of a quote from it: "We all get there together or we don't get there at all."
Offline loud_asian
« Reply #57 on: Sun, 29 January 2017, 15:57:40 »
I'm so hyped for this as well
Huge thanks to ninjadoc for keeping the dream alive.
I remember sneaking my phone out in class to get the latest updates on this board. Who would have predicted the journey that this board would have gone through :')
Offline logomachy
« Reply #58 on: Sun, 29 January 2017, 16:45:35 »
Passing along numbered spot #46 - PM me
« Last Edit: Sun, 29 January 2017, 18:16:35 by logomachy »
Offline breusch91
« Reply #59 on: Sun, 29 January 2017, 17:04:18 »
Pmed
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #60 on: Sun, 29 January 2017, 17:09:11 »
sent in my form... awesome job guys! Thanks. :thumb:
-Dana
Offline poolside
« Reply #61 on: Sun, 29 January 2017, 17:20:53 »
  • Bottom of the case includes a weight insert made of either stainless steel or polished (not plated) brass
Will the SS insert be polished as well?
« Reply #62 on: Sun, 29 January 2017, 17:24:04 »
See sample photos.  Yes it will be polished.
Offline asgeirtj
« Reply #63 on: Sun, 29 January 2017, 17:26:09 »
Which is heavier the brass or the steel weight?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #64 on: Sun, 29 January 2017, 17:28:14 »
Brass has higher density, so it is heavier for the same volume.
Offline poolside
« Reply #65 on: Sun, 29 January 2017, 17:30:19 »
Great, thanks!
Offline ika
« Reply #66 on: Sun, 29 January 2017, 19:17:53 »
Won't these brass weights be prone to tarnishing? Or will there be some sort of coating? I vaguely recall someone saying they would be "naked" brass but I might be thinking about someone talking about a brass switch plate.
Offline loud_asian
« Reply #67 on: Sun, 29 January 2017, 19:19:27 »
from the OP "Bottom of the case includes a weight insert made of either polished stainless steel or polished (not plated) brass"
one of the reasons why I decided to go with stainless steel for the wiehgt
Offline iArson
« Reply #68 on: Sun, 29 January 2017, 19:19:50 »
You actually typed this up as I was going to submit my order. If the brass is subject to tarnishing, instead of opening the board up every few months to polish it I was going to consider getting the SS.
« Reply #69 on: Sun, 29 January 2017, 19:20:18 »
Yes, they will be uncoated.  Stainless steel won't be tarnishing.  Brass will tarnish, but just the very top thin layer, and it's apparently fairly easy to make it shiny again (look up brass polishing, there are various products for it or even natural ingredients).  The problem with a brass plate is that there are switches on it, which makes cleaning it difficult.  But a bottom weight is easy to remove and polish as often as you wish.  I think the tarnished brass look goes well with some colors as well, like black.
« Last Edit: Sun, 29 January 2017, 19:21:55 by Photoelectric »
Offline swimmingbird
  • keyset hoarder
« Reply #70 on: Sun, 29 January 2017, 19:24:25 »
Really struggling to pick the colour and whether to go with a brass or stainless weight
Lunar Grey looks amazing
Offline iArson
« Reply #71 on: Sun, 29 January 2017, 19:25:01 »
That Grey is amazing. The slight hint of green is whats selling me on it.
  • keyset hoarder
« Reply #72 on: Sun, 29 January 2017, 19:35:44 »
Yah definitely - it's the subtlety of the ano colour that really makes a custom board stand out
Offline Rayoui
« Reply #73 on: Sun, 29 January 2017, 20:58:19 »
I'm quite fond of the appearance of weathered brass and I think it's going to look great with the lunar gray case!
When I was in the navy, I spent a great deal of time shining brass valves and fittings on seawater systems. It only takes a few minutes to get it shined up like new, even if it's covered in verdigris. As they won't be exposed to seawater, the weights should take a great deal longer to build up a patina.
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
Offline ninjadoc
« Reply #74 on: Sun, 29 January 2017, 21:30:32 »
Compatible with the Winkeyless A.87 PCB
ninjadoc
« Last Edit: Sun, 29 January 2017, 21:35:08 by ninjadoc »
Offline ninjadoc
« Reply #75 on: Sun, 29 January 2017, 21:32:46 »
Are the prototype colors actual prototypes with the actual colors we will be seeing or are those just renders?
Kind of disappointed in the grey that was settled on as the grey from the interest check didn't seem as green. If it's really supposed to be like that might have to go with black or blue then.
Those are actual prototypes.
Offline ninjadoc
« Reply #76 on: Sun, 29 January 2017, 21:34:07 »
It should be compatible with the A series
Offline ninjadoc
« Reply #77 on: Sun, 29 January 2017, 21:38:44 »
Gon's NERD PCB with the USB on top should be compatible. Plate was made with it in mind.
Offline Heliosphere
« Reply #78 on: Sun, 29 January 2017, 22:47:08 »
I wish I could get both a gray and a blue keyboard. I'm going with that gray with green tinge, plus brass weights. Reminds me of the parkerization on some old Garand and Springfield rifles.
Offline unipsykal
  • ghostly lurker
« Reply #79 on: Sun, 29 January 2017, 23:16:46 »
Whoa what a surprise, Interstellar black with brass weight for sure! Thank you to everyone who put in an enormous amount of work!
Offline zzyjayfree
« Reply #80 on: Sun, 29 January 2017, 23:38:43 »
Whoever would like to take over number spot #29 can contact me. Thanks
GONE
« Last Edit: Mon, 30 January 2017, 11:23:43 by zzyjayfree »
OTD 360 Corsa w/ Nixdorf, OTD 356.2 DGE, Matrix 1.2, Matrix 2.0, Matrix Abel, Skog, Dolphin, EM7, Lynn Pad, Plank, LZ-RE, EqualZ, Orion v2, Octagon v2, Viper v2, Tank, Mira, Mira SE, Moon, Camp 225, Let's Split, HHKB, RealForce, Infinity Ergo, Cherry 3700, DolchPac, Nixdorf, Model M, Filcos.
Offline zzyjayfree
« Reply #81 on: Sun, 29 January 2017, 23:39:02 »
Sorry duplicate post. See above.
« Last Edit: Mon, 30 January 2017, 00:28:07 by zzyjayfree »
Offline roostrc0gburn
  • its just plastic
« Reply #82 on: Sun, 29 January 2017, 23:45:29 »
uh, is it too late to add a second plate to my order?
« Reply #83 on: Sun, 29 January 2017, 23:55:27 »
Orders close on the 12th, so you can change your mind about various parts until then!
Offline eksuen
« Reply #84 on: Sun, 29 January 2017, 23:57:51 »
Hopefully, you saved the URL of your submitted form, in which case you can use it to pull up the form and make edits to your order. Otherwise, per the OP:
****IF YOU NEED TO CHANGE YOUR ORDER AND LOST YOUR EDIT LINK, PLEASE SUBMIT A NEW ORDER (BUT ALSO CONTACT Photoelectric SO YOUR ORIGINAL ORDER GETS DELETED).  FOR ADDRESS CHANGES, YOU CAN ALSO CONTACT Photoelectric****
Offline flopix
    • Laur
« Reply #85 on: Mon, 30 January 2017, 01:36:44 »
Cool stuff! Thank you
Offline GreyAmbience
  • I can stop when ever I want
« Reply #86 on: Mon, 30 January 2017, 03:23:10 »
I actually think that tarnished metal looks great in most cases. I have a copper lamp on my house, it's a dark orange with a green pattern because it's reacting to it's environment. It just shows that the item has an age and a history. It makes the items unique and beautiful.
Sent from my microwave oven using alternating current
Offline rabbitfire
« Reply #87 on: Mon, 30 January 2017, 03:35:16 »
It's hard to decide the color now. I like silver but I just joined the GB for a silver LZ CLS. 2 silver kb at the same time is a good idea? zzz   :rolleyes:
yea I'm totally stuck on color choices
I swear unless a keyboard has a purple option Its basically impossible for me to pick a color
Ya, it's hard to know when you don't see the kb in person. Just submitted for a silver Mira with SS plate and SS weight. Hope I won't regret  :'(
Offline Gajible
« Reply #88 on: Mon, 30 January 2017, 04:07:00 »
Will you lower the value of the package to avoid customs? To like $20.
This please!
Yes. That'd be a godsend. I'm on 21% on board+shipping + processing fees  :(
I'm in if this happens. I'm in Canada, and I'd really rather not have to pay 20-25% of the cost of the board in taxes and brokerage.
Alternatively, I'd also be willing to proxy all Canadian orders if there are enough. Bulk ship to Canada! 👍
Offline rabbitfire
« Reply #89 on: Mon, 30 January 2017, 04:38:06 »
This please!
Yes, my place has 25% plus 10% VAT for imported stuff like this. I suggest to add one more section on the form like some other GB that is "the amount you want to put in the declaration form".
Offline Will_26
« Reply #90 on: Mon, 30 January 2017, 05:45:44 »
Hey guys! Is this a starlight silver prototype? http://i.imgur.com/yWl2ob5.jpg Or was that a grey Anodising? Cheers :)
**Edit ah I guess this is more like the silver? http://i.imgur.com/SQ4px0h.jpg
« Reply #91 on: Mon, 30 January 2017, 10:55:13 »
The second photo is more what silver should look like, I believe.  (That's not the final MIRA SE version for the case form, however.  It's one of the very early prototypes)
« Last Edit: Mon, 30 January 2017, 11:41:29 by Photoelectric »
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #92 on: Mon, 30 January 2017, 10:57:48 »
I'm still putting in the order and keeping my spot, just gotta decide on color and materials. This is the hardest part.
Offline Blackehart
« Reply #93 on: Mon, 30 January 2017, 11:37:59 »
before I order,
Who all are the reputable US based keyboard assemblers?
Need a bonafide, trustworthy person.
Trying to avoid another TheChemist disappearing with $800+ of my gear.
Thanks
Offline loud_asian
« Reply #94 on: Mon, 30 January 2017, 11:39:59 »
before I order,
Thanks
I'm gonna go ahead and suggest E3E. Pretty standup dude that's pretty committed to the hobby, doubt he'll just leave
« Reply #95 on: Mon, 30 January 2017, 11:47:21 »
before I order,
Thanks
Just ship that over to me I'll assemble it for free as long as I can keep it :D
Offline iArson
« Reply #96 on: Mon, 30 January 2017, 11:48:46 »
Out of curiosity, whoever has spot 19 would you consider swapping with 46? Me loves 19 <3
« Reply #97 on: Mon, 30 January 2017, 11:53:27 »
Hopefully the person who has #19 will see your post, as he's recently posted on this page  :thumb:  (Although he might have his personal reasons for wanting #19--I know many people wanted very specific numbers).
Offline iArson
« Reply #98 on: Mon, 30 January 2017, 11:56:28 »
I know, I figured it's worth a try. I'm a tower junkie, so it's been my favorite number for years. But even if I can't get it I'm happy to have gotten someone's spot!
Offline E3E
« Reply #99 on: Mon, 30 January 2017, 11:59:51 »
before I order,
Thanks
tl;dr: I've done a lot of keyboard builds for people in the past, along with my own in-depth passion projects that are kind of crazy at times. I'd be more than happy to help you with your build if you need it. Can do any kind of mod you'd like, for the most part.
I would be more than happy to work on your Mira SE for you if you'd like. I've got a lot of experience with building MX boards for others as well as passion projects of mine involving Alps. I've done restoration of vintage boards and switches/key caps, custom assemblies that involve switch tuning (stickering, lube, SIP sockets, spring swaps), stab clipping and sanding (+ bandaid mod) and lubing, etc. Pretty much everything you could ask for when it comes to custom builds. I do also make my own cables, but I'd recommend you go to others for that as it's more of a personal thing for me. There's tons of great cable makers out there.
I've also done crazy projects like hand cutting the copper weight for my Orion v2, hot swap modding Alps boards, which involves drilling the pads out before inserting the holtite sockets, and also a crazy NCR Cherry-lookalike build that's actually Alps.
So I'm pretty much down for almost anything you could ask for and will work with you for as long as you might need assistance.
Hey thanks, haha. :)
« Last Edit: Mon, 30 January 2017, 12:07:13 by E3E »
