Author Topic: My full custom built keyboard - the SHONSY buildlog  (Read 2595 times)
Offline shoneec
« on: Sun, 29 January 2017, 10:12:47 »
Picture of finished build:
So, I decided to build my own keyboard after getting cheap Ajaz AK33 keyboard off ebay. I live in a poor country, so getting anything is super expensive, and I have access to cnc and laser machines on my work, so I decided to order switches, controller and everything else off of ebay and aliexpress and read on how to handwire and make your own keyboard.
I used qmk.sized.io to make my firmware, don't know if I would be able to make this without this tool, it's perfect. Thanks to  /u/iandr0idos from reddit for making this! And thanks for answering all my questions, you're awesome mate!
I want to thank reddit user /u/TakeawayIsNiceM8 for coming up with the handwiring layout! Thanks man!
I've done many tests with plate and case, recalculated and what not, and managed to make my keyboard in the end. It feels great!
The switches are gateron blacks, with gateron greens on spacebar, esc and delete keys.
Case build log: http://imgur.com/a/cKMr1
I decided to use MDF and cnc mill it, laser engrave the front side and then powder coat it with metallic paint. Turned out great and I'm pretty satisfied. I've put a logo on the bottom, which is made of cast transparent 3mm acrylic which is laser engraved and held in place with 4 chicago screws. First plate is white cast acrylic 3mm, and top plate is 4mm white cast acrylic with UV print applied on it.
Plate instalation buildlog: https://imgur.com/a/aG0Mz
I've ordered pcb stabs by mistake, and didnt want to wait for ages for plate ones to arrive, so I tried different hole sizes until I found the perfect one for pcb stabs to be mounted from the bottom and sit tightly in the place. I do not recommend this technique, just save yourself time and order correct stabilizers. Picture of switches aligned inclued, picture is before I replaced spacebar, escape and delete with gateron greens.
Wiring schematics and keymap: https://imgur.com/a/PfmLT
Handwire buildlog: https://imgur.com/a/aM43g
I use a pro micro, and because pro micro has only 18 pins I needed to do a bit of "hacking". What you do is remove one of the bottom LED's and a resistor beneath it and you get another pin, so pro micro can have 20 pins instead of 18. So I split the rows and extended the columns so I can fit everything, and ended up with 8x11 matrix. Everything else is standard handwire stuff.
And final assembly buildlog: http://imgur.com/a/ZDxI4
Here's a video with sound!
. On video it sounds a bit highly pitched than it is in reality, my camera isnt the best.
« Last Edit: Mon, 30 January 2017, 12:31:49 by shoneec »
Offline Takeawayisnicem8
Re: My full custom built keyboard - the SHONSY buildlog
« Reply #1 on: Mon, 30 January 2017, 12:58:46 »
Yo, nice keyboard man.
How much do you think MDF affects the sound compared to like aluminium?
Offline shoneec
« Reply #2 on: Mon, 30 January 2017, 13:08:32 »
Don't really have access to full aluminum case, but I could only assume mdf makes it a bit more "thocky", while aluminum could make sound a bit higher pitched.
