Author Topic: Buying GH60 PCB on Taobao  (Read 2865 times)
Offline Ngt
« on: Mon, 30 January 2017, 18:05:22 »
Hello boys and girls,
I have everything I need to build my long desired 60% keyboard (Lustro case, b.face, Zealio switches, etc.) however I found out some time ago that the b.face is not compatible with TMK Firmware ... I didn't think to check it out prior to buy it. Some people already told me I could make it work but I would have to recompile (even reprogram not sure though). I must admit I don't find myself confident enough to do it hence I consider buying a GH60 PCB. The only unused GH60 I found so far are on Taobao. Does anyone have experience buying GH60 on it? If yes and your experience is good, do you have a link to it?
I found these : https://world.taobao.com/item/543703427453.htm?spm=a312a.7700714.0.0.wDLuKa#detail
https://world.taobao.com/item/45802760146.htm?spm=a312a.7700714.0.0.wDLuKa#detail
https://world.taobao.com/item/534128852085.htm?spm=a312a.7700714.0.0.wDLuKa#detail
and many more but I can't find which rev they are as I understood the rev C is the most up to date version so far, isn't it?
Would the easiest way to import it to Europe be going through Qtan?
Thanks for you time fellow GHers. :)
Offline TalkingTree
    • My projects
Re: Buying GH60 PCB on Taobao
« Reply #1 on: Tue, 31 January 2017, 03:40:28 »
You can buy rev. C from Falbatech which is located in Poland.
Offline Ngt
« Reply #2 on: Tue, 31 January 2017, 06:57:19 »
Alright thank you very much. Have you ever ordered through him?
Offline pomk
« Reply #3 on: Tue, 31 January 2017, 10:14:27 »
I have ordered stuff from there a couple of times without any problems. He is also active on DT if you'd like to ask something about his store etc.
Offline Ngt
« Reply #4 on: Tue, 31 January 2017, 16:05:03 »
Alright thanks for your input. I sent him an email with a couple of questions.
