Author Topic: [GB] YAS62 | Shipped 100% (EXTRAS AVAILABLE)  (Read 291461 times)
Offline ktrezzi
Re: [GB] YAS62 | 60% PCB with arrow cluster (Collecting Order)
« Reply #50 on: Mon, 13 February 2017, 14:14:05 »
Looks like a real beauty!
What else do I need? Switchtes, stabs, (any) 60% case, keycaps?
Is it possible to build it with LED? (underglow or for each switch?) The plate supports ISO?
Offline ideus
  • Björkö.
« Reply #51 on: Mon, 13 February 2017, 14:54:59 »
You will get a PCB and plate. You will require to source switches, key caps and a sixty case. I am not sure about LEDs. The kit supports an ISO layout.
Offline ktrezzi
« Reply #52 on: Mon, 13 February 2017, 15:09:51 »
Alright, thank you!
So I could use my Pok3r case for example? Would be interesting to know if I the build supports LED?
Offline ideus
  • Björkö.
« Reply #53 on: Mon, 13 February 2017, 16:07:39 »
Alright, thank you!
Yes, you can use a Pok3r case. The OP states that the PCB supports underglow leds. If they are SMD I suppose they come pre-soldered. Let the OP to confirm it. In-switch leds should be soldered along with the switches.
« Last Edit: Mon, 13 February 2017, 16:09:14 by ideus »
Offline pizza_is_a_lie
  • ISO Master Race
« Reply #54 on: Mon, 13 February 2017, 16:38:16 »
Can anyone recommend a case for this to make the most of the underglow etc?
Offline yasintahir
  • Formerly silentreader
« Reply #55 on: Mon, 13 February 2017, 16:51:38 »
Alright, thank you!
yes it support smd led for underglow and it comes with presoldered, use just need switches and cases and led if u want get backlight on switch :D
u can use tex acrylic  ;D
Offline cynviloq
« Reply #56 on: Mon, 13 February 2017, 16:53:54 »
If you're looking for cheaper side / clear, maybe a Doyu 60%? (http://shopkey.doyustudio.com/002kba0.html)
I'm probably going to pick up a 60% case from Jolimon once these arrive (https://www.jolimonkb.com/shop-online/)
Any acrylic case (white/frosted white to diffuse) would be a good way to show off the lights.
Offline beamingrobot
  • もうけい
    • monokei
« Reply #57 on: Tue, 14 February 2017, 00:14:17 »
In for this :D
http://monokei.co
Jane v2 | Jane v2 CE | Police | EXENT | KFE | KFE CE | Singa R1 | Jaguar | HHKB | Custom G80-3000 | Dalco 959mini | Haus | Kei | Hiro | Hidari | Tomo | Neko | Prophet | MXSS | TKL One | RS
Offline yasintahir
« Reply #58 on: Tue, 14 February 2017, 04:06:17 »
Offline ktrezzi
« Reply #59 on: Tue, 14 February 2017, 04:20:55 »
Alright, thank you!
Perfect! Thank you guys very much for all the information.
Last question: What option would I have to choose for a "standard" bottom row?
Offline yasintahir
« Reply #60 on: Tue, 14 February 2017, 04:26:22 »
6.25 is most standard layout
but you can use universal plate if sometimes you want change layout you dont need any plate again  ;)
Offline ktrezzi
« Reply #61 on: Tue, 14 February 2017, 04:28:24 »
Alright! That sounds all real perfect, can't wait to place my order :)
Offline geekhackuserx
« Reply #62 on: Tue, 14 February 2017, 20:09:21 »
Order form is open until the 28th still right? Does not close just because of MOQ?
Offline kenshinjeff
« Reply #63 on: Tue, 14 February 2017, 20:51:36 »
Oh this is an interesting board. May I know where is the usb located, and who is cutting the plates? It looks like it may be able to fit a duck viper. (But I may be wrong)
Offline gadzkun
« Reply #64 on: Tue, 14 February 2017, 21:09:25 »
its open until 28th :)
it will compatible with common 60% case, so usb will located exactly the same as common 60% case.
pcb and plate made by leeku and it wont fit viper unfortunately.
Offline ChitownM2
« Reply #65 on: Tue, 14 February 2017, 21:19:52 »
Filled out the form. Guess I need to find a 60% case now
Offline yasintahir
« Reply #66 on: Tue, 14 February 2017, 22:43:56 »
stick to my first plan closed on 28th or extra time if we dont get MOQ  :)
Gadzkun already answer it for me thanks gadz  :-*
Thank's bro u can find many case on aliexpress, but dont use high profile case if u wont blocked side look blank  ;)
Offline ppp
  • KappaKeepoKoopa
« Reply #67 on: Thu, 16 February 2017, 00:57:04 »
This looks so cool! I honestly think this is endgame-level-esque for me  :-X :-X :-X
Offline dyoungc
« Reply #68 on: Thu, 16 February 2017, 02:02:12 »
Please check for my PM about changing my order.
Offline yasintahir
« Reply #69 on: Thu, 16 February 2017, 03:01:13 »
 ;D
Edited  :thumb:
Offline lunr
« Reply #70 on: Thu, 16 February 2017, 09:58:53 »
I forgot to ask. Does this support pcb mount or plate mount stabiliers?
Offline yasintahir
« Reply #71 on: Thu, 16 February 2017, 10:03:40 »
yes it's supported
Offline ideus
  • Björkö.
« Reply #72 on: Thu, 16 February 2017, 10:42:03 »
yes it's supported
The plate's design implied that the kit will take PCB mount stabs, only.
Offline teamrushpntball
« Reply #73 on: Thu, 16 February 2017, 11:08:53 »
Sending you a pm about my order, changing plate design.
Offline ChitownM2
« Reply #74 on: Thu, 16 February 2017, 13:14:14 »
Just noticed that the render shows a non-standard 60% case. I understand now why you're recommending a low-profile case.....
Since the plate is going to be exposed in those two corners, do you have any photos or examples of the aluminum and stainless options? I think I saw here previously you said the plates would be silver. Is that just the aluminum one or stainless too? Also when you say silver, do you mean silver anodized or that the plate is just raw aluminum or raw stainless both of which would be described as "silver"?
I liked the idea of the heavier brass plate but since it's going to be completely exposed in the corners I think I'm going to have to re-consider going with one of the other options...
Any chance of getting another render of what this will look like with an actual low profile case? The current render is kind of misleading as the final product isn't going to look like that at all since you're showing a normal profile case with the bottom corners filled in...
« Last Edit: Thu, 16 February 2017, 13:33:41 by ChitownM2 »
Offline dyoungc
« Reply #75 on: Thu, 16 February 2017, 16:43:27 »
In the split spacebar layout, will the PCB/plate support standard 2u stabilizers in both 2.25/2.75 spacebars?
Offline yasintahir
« Reply #76 on: Thu, 16 February 2017, 16:43:49 »
yes it's supported
aw yes you are right  :rolleyes:
done
That's silver anodized alu, i dont have any sample foto when i ask leeku he said dont have any sample for plate
I will try to make render for lower case profile ASAP
« Last Edit: Thu, 16 February 2017, 20:26:42 by silentreader »
Offline yasintahir
« Reply #77 on: Thu, 16 February 2017, 16:48:08 »
yes
Offline yasintahir
« Reply #78 on: Sun, 19 February 2017, 22:51:21 »
Because this GB has hit moq, i will start invoicing this day or tommorow but dont worry payment deadline will be 7 march and order form still closed on 28 feb. If all order has paid on 28 feb i will pay order to leeku next day so it will make faster right ?  :D
  • もうけい
    • monokei
« Reply #79 on: Mon, 20 February 2017, 01:58:19 »
paid  :D
http://monokei.co
Offline menuhin
« Reply #80 on: Mon, 20 February 2017, 05:36:26 »
PM-ed for order change.
silentreader, please send me the invoice for my modified order. Thanks! :thumb:
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline yasintahir
« Reply #81 on: Mon, 20 February 2017, 05:41:36 »
paid  :D
 :thumb:
invoice modified u can check it again  ;)
Offline Daphen
« Reply #82 on: Mon, 20 February 2017, 06:15:11 »
So normal HHKB split shift is not possible? I'd like a normal HHKB but with the split spacebar layout, that would be amazing for me personally, I'm so used to HHKB arrows that I couldn't go back to dedicated arrows.
Offline yasintahir
« Reply #83 on: Mon, 20 February 2017, 06:19:54 »
is that iso hhkb with 1u shift? sadly i can't change any layout this time, it has been final layout what i got from IC thread
Sent from my 2014811 using Tapatalk
« Reply #84 on: Mon, 20 February 2017, 06:54:50 »
Just paid! Excited for this build.
Offline babyphil
« Reply #85 on: Mon, 20 February 2017, 19:07:33 »
Paid. Now I need to figure out what switches for this build.
Offline Vadurr
  • Valar Morghulis
« Reply #86 on: Mon, 20 February 2017, 19:14:45 »
Cant wait to see a more accurate render of this !
Offline tuco
« Reply #87 on: Mon, 20 February 2017, 19:29:44 »
Paid!
Offline depreshun
  • Reddit: risingremains
« Reply #88 on: Mon, 20 February 2017, 21:38:44 »
Paid. Will the plates be just alu colored?
Offline yasintahir
« Reply #89 on: Mon, 20 February 2017, 21:44:24 »
Paid!
 :thumb: :thumb: :thumb:
i'm currently make custom plate here and bought 1 acrylic case, maybe tommorow i can update picture of that. It will be better than render right?  :p
This what i got from leeku :
SS material will be mirror finish
Alu silver anodize
Brass gold shinny like TX plate
Offline DuFF
« Reply #90 on: Mon, 20 February 2017, 23:14:03 »
paid
cant wait to build my first split spacebar + brass plate board!
also nicely timed with zealios round 5 ;D
Offline nemo_gh
« Reply #91 on: Tue, 21 February 2017, 04:36:43 »
ordered
waiting for the case ;D
Offline Vadurr
  • Valar Morghulis
« Reply #92 on: Tue, 21 February 2017, 04:37:18 »
Paid!
Alu silver anodize
Looking forward to a picture update! :D
Offline yasintahir
« Reply #93 on: Tue, 21 February 2017, 08:18:49 »
I still wait for my acrylic case came home but here's i got picture of plate with keycap inserted  ;D
NOTE: YAS62 text on right corner will be blank on your order i just make it for me  :p
Offline Che.R.Ry
  • geeks
« Reply #94 on: Tue, 21 February 2017, 08:31:29 »
omg looks great with split spacebar  :eek:
on pic1, that's universal plate right? just wanna make sure
Offline yasintahir
« Reply #95 on: Tue, 21 February 2017, 08:41:02 »
u can add many key on split spacebar make it great for 60% layout  :))
yes that's universal plate
Offline ipreferpie
« Reply #96 on: Tue, 21 February 2017, 09:28:30 »
Does anyone know if the bottom corner keys would fit into the blocked corner HHKB Xondat's X60 case?
Offline yasintahir
« Reply #97 on: Tue, 21 February 2017, 09:34:08 »
no this blocker size is 0.75u, it will be ok with left blocker i think but on the right side u will lose arrow key
Offline menuhin
« Reply #98 on: Tue, 21 February 2017, 12:39:47 »
Is this a brass plate?
This is already looking great!  :thumb:
IBM M13 black
HHKB Pro 2 HasuBT
« Reply #99 on: Tue, 21 February 2017, 14:23:11 »
Just ordered a black cherry low profile case and matching wrist rest to go with this.  Unsure on Nantucket Selectric or GMK Plum for my keyset still.
That and zealios or Mod switches will finish out my build.
