Author Topic: Getting a poker style case for a diy build  (Read 3198 times)
Offline happylacquer
  • BS Apologist
    • BHOBuds
« on: Sat, 11 February 2017, 15:01:45 »
I cant seem to find anyone who just sells these kinds of cases. I do not want to buy a whole board to rip out everything and leave the case but i'd rather do that if that is the cheapest way to get one. Looking to put two Alps64 together soon.
Offline Tactile
Re: Getting a poker style case for a diy build
« Reply #1 on: Sat, 11 February 2017, 16:17:41 »
If you search for "60% case" you'll find a lot of them. Any of the 60% cases here will fit a Poker style PCB.
REΛLFORCE
Offline kiwi99
  • that's a gnarly dookie
« Reply #2 on: Sat, 11 February 2017, 18:21:37 »
Your cheapest option is on AliExpress. You can get a plastic poker style case for probably 20 dollars tops. Mind you you will be waiting a while for it but for the price it's the best you can do, just look up "gh60 case"
Offline TheNamesTy45
« Reply #3 on: Sat, 11 February 2017, 23:27:39 »
Hey there,
If you're looking exactly for the Pok3r case, I found it on MechanicalKeyboards.com. https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1002. Hope this helped you find what you're looking for.
Just checked the link by Tactile. Found the case the same exact way you showed here.
  • BS Apologist
    • BHOBuds
« Reply #4 on: Sat, 11 February 2017, 23:29:21 »
Damn i never even thought to check ali. they are great when you find a good seller. will gladly do
Offline merlin64
    • MechMerlin
« Reply #5 on: Tue, 14 February 2017, 03:45:15 »
I'd also check eBay. There's a seller called sennin or something that sells the type of cases you want.
If you check out 1upkeyboards they sell metal poker cases too.
