Author Topic: Model F AT to PS2  (Read 3998 times)
Offline happylacquer
  • BS Apologist
    • BHOBuds
Model F AT to PS2
« on: Mon, 13 February 2017, 23:16:10 »
Is this easy to do? It looks like you can get a Model F board nice and cheap on ebay at any time. Is it just wiring the 4 wires on your ps2 cable and boom?
Offline Tactile
Re: Model F AT to PS2
« Reply #1 on: Mon, 13 February 2017, 23:28:16 »
All you need is one of these:
160401-0
REΛLFORCE
  • BS Apologist
    • BHOBuds
« Reply #2 on: Mon, 13 February 2017, 23:36:23 »
I guess if a passive adapter is fine there shouldn't be any issue replacing the internal cable with a PS2 one?
Offline Tactile
« Reply #3 on: Mon, 13 February 2017, 23:36:47 »
And, yes, if you want to hand wire it's just a matter of changing the connector.
REΛLFORCE
Offline Wingklip
  • I am the one the one the one the one the one
« Reply #4 on: Tue, 14 February 2017, 03:18:28 »
Passive adapter works 100%. Don't desolder it you silly :eek:
If you 1v1 me in a cage fight I will use an AK-74 for ranged and an IBM model F 122 for melee
« Reply #5 on: Tue, 14 February 2017, 07:50:05 »
When and where? F ATs have become much more expensive and harder to find in the last couple of years.
- D Trump 2026-10-24
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #6 on: Tue, 14 February 2017, 08:07:44 »
I think he means Model Fs in general. The XT ones are much more forthcoming.
« Reply #7 on: Tue, 14 February 2017, 08:31:20 »
Without a doubt, but the thread title says "AT" and most of the discussion is around passive adapters, etc.
Any other Model F requires "conversion" of some type to USB, and PS/2 is not an option.
