Author Topic: What keyboard is this?  (Read 3088 times)
Offline lambreaux
« on: Tue, 14 February 2017, 11:54:34 »
Hello, I hope you can help me. I found this keyboard for sale in my city, I should buy it
it? It would be about 5 euros.
Thanks for the help
Offline rxc92
Re: What keyboard is this?
« Reply #1 on: Tue, 14 February 2017, 13:21:29 »
It looks like a Model F XT. Will have a RJ45 cable, a bit hard to convert but a good feeling board without the heaviness or crunch of a Model M.
Offline Parak
« Reply #2 on: Tue, 14 February 2017, 13:39:47 »
That's not an XT... and for that matter XTs don't have an RJ45 cable.
Most likely a keytronic foam and foil.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Tue, 14 February 2017, 14:19:03 »
Definitely not an F XT, but it's probably an XT board.
Not sure really, need a bit more detailed pic or a back pic or something to help out.
It looks a bit like my Hi-Tek 725, but that didn't have a 3 u + key.
Offline need
« Reply #4 on: Tue, 14 February 2017, 14:23:00 »
I'd say this is a Zenith without the badge, probably the owner took it off.
Offline zpcomstock17
« Reply #5 on: Tue, 14 February 2017, 14:37:58 »
Maybe you should buy it, if you don't like it or can't convert it then sell on it eBay, you'll probably make back what you spent.
Offline Touch_It
« Reply #6 on: Tue, 14 February 2017, 14:51:08 »
My thought is a foam and foil board as Parak said.  Even if it is, it would be worth the $5 euro to find out for sure.
Offline Keycap
« Reply #7 on: Tue, 14 February 2017, 15:29:32 »
If in doubt, assume KeyTronic Foam & Foil. Even with slight doubt, assume KeyTronic Foam & Foil. Those LEDs just look way too KeyTronic to me.
Offline Keycap
« Reply #8 on: Tue, 14 February 2017, 15:30:40 »
Then again, that font doesn't look like something KeyTronic would normally use. You could give it a shot.
Offline lambreaux
« Reply #9 on: Wed, 15 February 2017, 10:11:17 »
I had more info:in the back you can see: " PHILIPS P2812-090.Is it worth to buy it?
and it will work in a modern computer?
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #10 on: Wed, 15 February 2017, 12:10:14 »
I see Photobucket has gone down the toilet again. Why does that service still exist and why is anyone still using that garbage?
Anyway, if it's €5 for this, then it's a yes to buying it:
https://deskthority.net/wiki/Philips_P2812
You could sell it on for more than that.
Would it work? I don't know — XT can be converted to USB, but it's even more finicky than PS/2 as I understand.
Bore Awards
Offline Tactile
« Reply #11 on: Wed, 15 February 2017, 12:26:39 »
I have no idea what switches are in this.
It is not an XT only board. It has lights thus it is either an XT/AT switchable or AT only board. Assuming it is working you can put it into AT mode and then just use any PS/2 to USB converter to connect it to a computer.
IOW: if it is not broken yes, you should be able to make it work, even making it fully programmable if you want.
REΛLFORCE
Offline lambreaux
« Reply #12 on: Wed, 15 February 2017, 12:28:19 »
Yes, this is the exact keyboard.
If it´s hard to convert, i don´t think this could be good for a noob like me
Offline Tactile
« Reply #13 on: Wed, 15 February 2017, 12:41:24 »
Well, Deskthority say it's an XT board. I've never seen an XT board with lights.
Anyway, if it is working it is convertible to USB.
I don't know if you feel you're up to it but here is the info to convert it.
REΛLFORCE
Offline lambreaux
« Reply #14 on: Wed, 15 February 2017, 16:37:57 »
I think I'm going to pass from this and look for something new since I also failed to bring life back to IBM m2
  • RIP
    • Boring twaddle
« Reply #15 on: Wed, 15 February 2017, 16:40:36 »
Where did you find it? It's definitely worth someone having that — linear space invaders are highly regarded, and for that price you could even split it out for spare keycaps and spare switches, although I'd recommend letting someone buy it to convert.
Bore Awards
Offline lambreaux
« Reply #16 on: Wed, 15 February 2017, 16:47:59 »
Local seller has it. I just landed in the world of keyboards and I'm too new to the conversion, the layout of the keys is too strange for me and even a keyboard is too big.
Do you think it could be a good business?
If someone is interested, I do not have problem in doing of intermediary without cost.
  • RIP
    • Boring twaddle
« Reply #17 on: Wed, 15 February 2017, 16:50:36 »
All you can do is post it to the marketplace section and find out!
Bore Awards
