Author Topic: Thermaltake eSports Challenger Ultimate | Multimedia keys wont work  (Read 2404 times)
Offline aVco
Hey guys,
first of, let me just say what an awesome idea is to create a forum community dedicated particularly to keyboards.
now, i just got my new challenger ultimate keyboard.
i disabled the the keyboards audio jack so the volume keys will work and so they do.
my problem is that when i try to use the multimedia keys (backward, play, stop, foreword) they do not do anything.
i know they are active because whenever i try to press them, the green function icon appears.
the last version of the driver is installed.
i tried replacing the usb port.
when i enable the onboard audio jack, the multimedia keys still dont work.
i use windows 7.
any ideas?
thanks
Offline Prince Valiant
Re: Thermaltake eSports Challenger Ultimate | Multimedia keys wont work
« Reply #1 on: Wed, 22 February 2017, 09:50:28 »
Have you tested if they work with your media player as the active program (selected in the taskbar)? Foobar doesn't like to play nice with me some of the time when it's minimized.
Offline aVco
« Reply #2 on: Wed, 22 February 2017, 11:03:52 »
hey, thanks for replying!
im using Winamp... could you please clarify on the subject? what does it mean "selected in the taskbar"?
« Reply #3 on: Wed, 22 February 2017, 18:46:49 »
Like so:
http://i.imgur.com/5wc60pj.jpg
In that screenshot Foobar is the selected program in the taskbar and Firefox isn't.
Offline aVco
« Reply #4 on: Thu, 23 February 2017, 06:43:32 »
Like so:
oh, got it.
yeah, ive actually tried that and it didnt do... :\
« Reply #5 on: Thu, 23 February 2017, 21:23:08 »
Have you enabled multimedia key support in Winamp? It's off by default in the newest version.
Options->Preferences->Global Hotkeys->Enable default MM key support
Ctrl+P shortcuts to preferences.
Offline aVco
« Reply #6 on: Fri, 24 February 2017, 05:41:18 »
THANK YOU!!! you have no idea how much time im dealing with that issue!!!
youre awesome! thank you!!
« Reply #7 on: Sat, 25 February 2017, 16:14:18 »
Glad to hear that was the problem and it wasn't the board :).
