Author Topic: Help, or not....Photo added  (Read 2667 times)
Offline mniels
« on: Wed, 22 February 2017, 19:12:14 »
I am pretty sure I know the answer to this question, but....
If I have a lifted pad (the Enter key in this case,) am I totally screwed?  I am assuming that it can't be jumped like an LED, and that particular key isn't exactly a good candidate for re-mapping somewhere else.  This is on a Pok3r.
« Last Edit: Wed, 22 February 2017, 20:09:05 by mniels »
Offline happylacquer
  • BS Apologist
    • BHOBuds
Re: Help!!!
« Reply #1 on: Wed, 22 February 2017, 19:41:33 »
Replying to a topic called "Help!!!" makes me feel like a scrub, but i'll tell you what you need to know anyway. Follow the trace alllll the way to where it goes. Solder a wire between there and where you would have soldered to if the pad hadn't lifted and bob's your uncle
Offline mniels
Re: Help!!!
« Reply #2 on: Wed, 22 February 2017, 19:44:38 »
Well, I don't get the jokes or whether or not I am being made fun of, but.....thanks?
Offline Tactile
Re: Help, or not....
« Reply #3 on: Wed, 22 February 2017, 19:59:55 »
You'll get more help if you post photos but more than likely it's repairable.
REΛLFORCE
Offline mniels
« Reply #4 on: Wed, 22 February 2017, 20:08:41 »
An excellent point, so here we go....like I said previously, the Enter key:
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Help, or not....Photo added
« Reply #5 on: Wed, 22 February 2017, 20:19:49 »
Why can't you run a jumper from the ansi enter pad to iso enter pad?
Offline mniels
« Reply #6 on: Wed, 22 February 2017, 20:42:51 »
There you go, didn't even think of that, so thank you.
Is there a recommended minimum gauge for the jumper wire?  Never actually had to do this before, so please excuse the dumb question.
Offline pixelpusher
« Reply #7 on: Wed, 22 February 2017, 20:47:14 »
Just make sure you use stranded and not solid.  Solid will pull **** off if stressed
Offline mniels
« Reply #8 on: Wed, 22 February 2017, 20:50:23 »
Gotcha, thanks!
Offline mniels
« Reply #9 on: Wed, 22 February 2017, 21:06:10 »
Many thanks to you both, worked like a charm!
