Author Topic: Which text editor do you use and why?  (Read 75135 times)
Offline iLLucionist
  • Topre is Love.
Re: Which text editor do you use and why?
« Reply #150 on: Thu, 19 October 2017, 04:18:41 »
There are some rare programs that when you jump a "page" (which is smaller than a full page), draws a line indicating where the viewport's border was before the jump. But the line does not remain - it fades away after a second or two.
Interesting. The Amiga explanation is great too (oh I miss those Amiga days).
Of course in Emacs everything is configurable so any behavior can be configured. For example there's even a "smooth scrolling" option that scrolls like some old editors used to do (don't remember which one but Sublime scrolls like that): basically like when you scroll up and down in a webpage... Instead of "jumping at once", the thing "scrolls": complete with progressive acceleration and deceleration. And it's not just a fake smooth-scrolling using line by line scrolling: it's moving vertically by "pixels", not whole lines. In Emacs the package is called sublimity and sublimity-scroll.
See.. that's what I mean. Imagine the possibilities with emacs. And the configurability. Finally I could have open all temp buffers in or below the same window as opposed to at the bottom of the whole application window. I would be sooo happy if that was possible.
I like to do everything in and around the window I am looking at, which prevents me moving my covert focus with my eyes all the time.
Let's say I want to open another file (vim CtrlP). I create new window first, then in that window I want to load a file into a buffer and show it in that window. So I want to have fuzzy completing in that window or split up the same window area in 2/3 content and 1/3 for the temp buffer to show the fuzzy completion.
Likewise, when I do linting, I want the suggestions around the current window where I am already looking. Vim just has 1 place for temp buffer for ALL open buffers, which is below and above the statusbar / commandline. It can get very confusing if you have a large screen and 6 windows open.
« Reply #151 on: Thu, 19 October 2017, 20:52:50 »
I use BBEdit on Mac now since TextWrangler was discontinued.
BBEdit 12 was recently released, with a default dark theme.
I kinda like dark themes, so this sits well with me.
I used bbedit on macos 7/8. Aahh.. the nostalgia.
I didn't know it has been around for that long!
When I switched to Mac at home and eventually at work I was looking for a (free) text editor similar to ConTEXT under Windows.  TextWrangler by the same company as BBEdit was the result.  Now that has been mothballed so I switched to BBEdit.
But still use vim in a terminal because it starts quicker and I can do quite a few things quicker with vim shortcuts than the sometimes-abominable cmd-opt-shift-ctrl key combinations.
Offline _rubik
« Reply #152 on: Tue, 07 November 2017, 22:08:49 »
This thread was made for me. I know its been said before but... emacs 100%.  I could go on about its amazing uses, but instead I'll sum up my editors in one photo.
Everyone I work with thinks I'm nuts, and should switch to Sublime to net beans/jet brains/or whatever...  but I couldn't imagine developing outside of my emacs config.
Offline Altis
« Reply #153 on: Wed, 08 November 2017, 15:00:56 »
The thing that keeps me away from emacs, speaking as a novice, is that it seems like it's both complicated to learn and requires a lot of setup to make it great (though that requires learning first).
Offline _rubik
« Reply #154 on: Wed, 08 November 2017, 15:08:06 »
I would call myself a *nix ricer, so the ability to write list to customize my editor really enticed me. I started with a tiny config, taking my few preferences into consideration. But, over the years, my config has grown and grown. The reason I recommend it to folks is that it gives you the ability to start small and slow. Sure there are a few things you have to learn; but, believe it or not, there was a time in your life where you had to learn C-c and C-v also. I wouldn't say that basic usage has a steep learning curve; instead I would say that it has a steep re-learning curve. For a lot of people that's undesirable.
Offline dubious
  • 쏘쿨
« Reply #155 on: Thu, 09 November 2017, 14:11:58 »
so VIM is still the best text editor?   ;)
Offline iri
« Reply #156 on: Thu, 09 November 2017, 16:58:17 »
Of course.
-Ray Bradbury
Offline _rubik
« Reply #157 on: Thu, 09 November 2017, 17:08:18 »
Of course.
I take "basic text editor" to mean "on the fly edits in a remote environment". I would say that emacs is beyond a basic editor. But yeah, vim is hot for some good ole' config tweaks imo.
« Reply #158 on: Thu, 09 November 2017, 19:59:53 »
Of course.
Emacs can still be used as a basic text editor.
But Vim is usually installed on more out-of-the-box systems than emacs.
Offline no, the other guy
  • actually, this guy
« Reply #159 on: Sun, 05 August 2018, 13:15:41 »
I used a lot of text editors over time, including EditPad Lite, GVim and Notepad++. As I am currently owning a couple of Unix, BSD and Windows machines and one Linux laptop, I try to keep the overhead low though, so I have mostly settled to what works everywhere:
  • For development, I surely prefer GNU Emacs. I have adjusted it to my needs over the past few years and it is what I would call the perfect IDE now.
  • For note-taking, I usually use either acme2k or Notepad (resp. whatever the current system offers). I'm gradually replacing the latter by micro though.
There is nothing else to do with a text editor for me.
<armin> i have the impression the only reason the mx red switch was invented was drunk people
Unicomp PC122 (review) * IBM Model F XT * Dell AT101W
Offline haanuman
« Reply #160 on: Sun, 02 September 2018, 12:15:27 »
Mostly Notepad++
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #161 on: Mon, 04 March 2019, 11:56:57 »
The text editor that i use is notepad.
Just my thoughts
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #162 on: Mon, 04 March 2019, 12:17:55 »
Recently added nerdtree to the vim folder.  I might keep this one around for a while--referencing directory structures at a glance is a nice feature
« Reply #163 on: Mon, 04 March 2019, 12:19:43 »
Life is too short for Vim.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #164 on: Mon, 04 March 2019, 12:31:54 »
Vim: It's like multiple space themed Lego sets blended into one mega set, but it's actually a basic text editor that can sometimes be a fully fledged IDE.
Instead of ordering a pizza you take a few chemistry classes to make the perfect ingredients.  Sometimes things blow up.  It's fun.
Offline vegs
« Reply #165 on: Tue, 05 March 2019, 04:36:11 »
Vim and Sublime :thumb:
hhkb 4 life
buy less
« Reply #166 on: Tue, 05 March 2019, 11:20:15 »
I use BBSubVIMe++ :P
« Reply #167 on: Tue, 05 March 2019, 20:03:30 »
I've been evaluating Sublime Text recently (on macOS).
It seems reasonable, but suffers the two issues that most modern editors have - an overly complex multi-step find dialog, and moving to the start of the next word actually moves to the end of the current word.
The first issue is an inconvenience, the second one throws out my auto-pilot code navigation techniques nearly every time.
Often I just open iTerm2 and start vim instead.
One day I might get around to writing my own editor.  Again.
Offline dubious
  • 쏘쿨
« Reply #168 on: Wed, 06 March 2019, 11:28:43 »
Have you tried the Vintage Mode plugin for Sublime? It gives you vi commands and movement. I've only used it a little bit, but worked fairly well when I tried.
« Reply #169 on: Wed, 06 March 2019, 11:32:54 »
Spacemacs. Been using it for about a year now. I use it for all my note-taking for classes using Org mode, and then I used it for a bit during my Python class. It just werks.
Offline iri
« Reply #170 on: Wed, 06 March 2019, 17:21:18 »
try/catch in imports? what the ****
-Ray Bradbury
« Reply #171 on: Wed, 06 March 2019, 17:22:14 »
Just Pythoneers being Pythoneers.
Offline mkkeyboardvigilante
  • Location: Atlanta, GA, thocking, clicking, and clacking away depending on my mood
« Reply #172 on: Fri, 08 March 2019, 18:39:30 »
Visual Studio Code these days, though I've enjoyed using Sublime Text in the past.
Been getting back to learning to code and all and taking some classes I've been in more seriously.
Current driver: HHKB Pro 2 (BKE Ultra Lights), Wooting One w/ Flaretech Red switches and HyperX PBT keycaps.
Other keyboards I own and like: Realforce 87U Variable Weight, Realforce 87U 55g, Niz Plum, Magicforce 108 Gateron Reds w/ O-Rings.
Other keyboards I have: Magicforce 68 Cherry MX Brown, Havit Low-Profile Kailh Blue, Logitech K740,
Yeah, it's a loooooooooooot of keyboards. :P
Offline Flame
« Reply #173 on: Sun, 10 March 2019, 12:21:15 »
BBEdit on Mac & Notepad++ on Windows. I use these because they are extremely easy to use and to modify code on. They have all the features I require in a text editor as well!
Offline voight-kampff
« Reply #174 on: Sun, 10 March 2019, 12:53:05 »
I use textmate. It is not opensource, but it is fast.
Sent from my MIX using Tapatalk
« Reply #175 on: Mon, 18 March 2019, 20:58:02 »
Python 2/3 compatibility trick - try to import the Python 3 library.  if that fails, go for the Python 2 version.
Offline _rubik
« Reply #176 on: Wed, 03 April 2019, 21:39:05 »
As a long time Emacs user.... it pains me to say this, but I've fallen for the JetBrains suite (more specifically GoLand) with Vim bindings. It's feature rich but isn't in your face. It works out of the box, but lets me tweak. It's the Apple of IDEs... and I like it. They've been around a while, so I may be way behind the curve.
Offline iri
« Reply #177 on: Thu, 04 April 2019, 15:43:25 »
JetBrains are much better than Apple.
-Ray Bradbury
« Reply #178 on: Thu, 04 April 2019, 15:45:24 »
Show me the JetBrains smartphone.
Offline iri
« Reply #179 on: Thu, 04 April 2019, 15:50:57 »
I can show you my arse.
-Ray Bradbury
« Reply #180 on: Thu, 04 April 2019, 15:52:13 »
That's probably roughly similar to a hypothetical JetBrains smartphone. Including the smell.
« Reply #181 on: Sun, 07 April 2019, 21:59:14 »
+1 for spelling it "arse" and not "ass" :D
Offline 4sStylZ
« Reply #182 on: Tue, 09 April 2019, 11:02:56 »
Sublime user here with MANY custom packages and options.
Custom fonts : Profont or Firacode (with ligatures now supported)
Color highlighter
Markdown preview synchronised with the browser
Custom extension icon on the sidebar
Linters
Custom theme made with some theme editor package
Custom keymap…
I can’t find another editor fast and customisable as Sublime for « my uses ».
Also my settings are versionned here :
https://framagit.org/4sStylZ/SublimeText3Settings
So I reinstal a desktop, I clone my settings and automaticly all the packages reinstall themselves like robots who builds some others robots…
Bépo user here : AEK64 White linear dampened, XD75 Cherry Blue Jailhoused, TypeMatrix2030 black skin, Lenovo 0B47200 w/ trackpoint, G13, G512. Kensington Expert Trackball & Orbit, Magic touchpad 2.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #183 on: Tue, 09 April 2019, 11:53:13 »
emacs and eclipse   :cool:
Offline JP
« Reply #184 on: Tue, 09 April 2019, 15:08:10 »
I use vi while walking uphill, both ways in the snow.  :thumb:
About Me | The Collection
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #185 on: Tue, 09 April 2019, 15:15:23 »
Everytime I use Nano to enable wifi for a new system I leave behind at least one :wq
Sometimes echo is not enough.  Am now broken
« Reply #186 on: Tue, 09 April 2019, 22:02:23 »
Losing affection for Sublime Text due to inconsistent text selection.
If I try to select a line, sometimes it selects only up to the last character instead of the whole line (move cursor to beginning of line, hold Shift, press down arrow - should select the whole line).
Also sometimes it selects, for an unknown reason, a whole block of text instead of one line.
Plus it indents things all over the place when I do not want it to.
And the find mechanism is a pain sometimes - the number of times I search for something, look in the code where the text was found (and is highlighted) and start typing, assuming the cursor is where the highlighted text is, but no, the cursor is still in the find field, so half the time the editor suddenly jumps somewhere else where it found whatever I had started typing.
Also why do most modern text editors move to the end of the current word instead of the beginning of the next word when you ctrl-rightarrow (or opt-right arrow on Mac)?  I usually end up ctrl-rightarrow (or opt-rightarrow) again, then ctrl/opt-leftarrow to go back where I wanted, which only works as expected sometimes due to varying interpretation of what constitutes a "word".
Grrr.
Offline JP
« Reply #187 on: Wed, 10 April 2019, 07:04:11 »
Actually I like nano for quick config changes but 95% of the time I am in Windows. I really like VS Code and still use Notepad++ for certain things out of habit. I even use regular MS notepad still for taking notes although I should really be using Onenote for that kind of stuff.
Offline ollir_
« Reply #188 on: Mon, 29 April 2019, 13:14:06 »
Depends a little on what I'm doing but it's one of
  • Vim (gvim)
  • VSCode (with VsVim)
  • Emacs (with evil)
Vim is great for fast little edits - config files etc. I used it for programming, but I've mostly switched to VSCode in that front now, the editor has become quite pleasant to work with and it 'just works' most of the time. For Haskell I still prefer Emacs though.
