Author Topic: holding down WSAD keys  (Read 2001 times)
Offline devilcm3
« on: Mon, 08 February 2010, 07:33:59 »
i recently find myself to be addicted with mass effect 2...and playing with it for hours a day....
the game is nice....but i had a concern about my keyboard(cherry brown)
since that this game is FPS ...means i had to hold down WSAD keys often , so....will this do any harm to the switches? loose / weak springs because of long holding the keys for too long?
Black Cherry MX , once you bought it , it is yours , it is permanently yours , it is permanently yours till you meet your maker
1.FILCO Cherry Blue FKBN104MC/EB
2.FILCO Cherry Brown FKBN84M/EB
Offline itlnstln
« Reply #1 on: Mon, 08 February 2010, 07:43:15 »
You shouldn't have any problems.  Those keys will probably break in faster than the others, but other than that, you'll be fine.  You will probably buy another keyboard before you wear any of the switches out, though.
Offline In Stereo!
« Reply #2 on: Mon, 08 February 2010, 07:55:23 »
That >50000000 operations surely must mean something.
Offline Rajagra
« Reply #3 on: Mon, 08 February 2010, 08:22:48 »
You might wear the keycaps smooth or blank eventually, but that's all.
