Author Topic: Ducky One TKL -vs- Input Club K Type -vs- Glorious PC TKL  (Read 6030 times)
Offline dream3
« on: Wed, 08 March 2017, 00:05:13 »
Guys, need some hard core advice here.
At first, my primary reason to go after the Input Club K Type and the Glorious PC gaming mechanical key was because of their removable switches.
However, I've then noticed the Ducky One TKL is even more expensive than the full-fledged Glorious PC keyboard. That got me thinking that maybe there was a practical reason for the price difference and that the Ducky could be better in some way. Build quality perhaps?
If that is the case, I would then think about letting go of the removable switches and stick to the Ducky
If not and the Ducky is more expensive simply due to the brand, should I go with the Input Club K Type or wait for the Glorious PC TKL to become available later this year?
Offline merlin64
    • MechMerlin
Re: Ducky One TKL -vs- Input Club K Type -vs- Glorious PC TKL
« Reply #1 on: Wed, 08 March 2017, 09:14:27 »
If this is your first mechanical keyboard, then I would go for the removable switch option as it will allow you to play around with different switches as you inevitably want another keyboard.
However, if it were me I'd pick the Ducky or the Input Club Keyboard...assuming I had money.
Offline dream3
« Reply #2 on: Wed, 08 March 2017, 16:45:59 »
I already know for sure I'm going with the browns, having removable switches would just be for peace of mind knowing I can clean and replace them myself without any soldering.
Why would you say Ducky is better than the Glorious PC for instance?
Offline SpecTP
« Reply #3 on: Wed, 08 March 2017, 17:46:55 »
I think the Glorious Keyboard is probably the one for you if you can wait for a TKL version. Or there is also the XMIT hall-effect keyboard too  :p
162373-0
Offline TheNamesTy45
« Reply #4 on: Wed, 08 March 2017, 18:26:06 »
I'd wait for the K Type because it just looks glorious, it's fully programmable, and it'd be hard to find later on down the road. The Ducky One TKL comes up fairly often (I'm typing this on one now), and it's a great board, but I just couldn't say no to the K-Type.
Offline dream3
« Reply #5 on: Thu, 09 March 2017, 11:06:13 »
In terms of build quality the K-Type would not lose anything at all to the Ducky One, I imagine?
And between the K-Type and Glorious PC, K-Type is still the "clear" winner?
Offline merlin64
    • MechMerlin
« Reply #6 on: Thu, 09 March 2017, 11:49:24 »
Ducky and Input Club are generally better brands than Glorious. You'll see it in the build quality and longevity of the keyboards.
Offline dante
« Reply #7 on: Thu, 09 March 2017, 11:54:59 »
Between the K-Type and Glorious TKL there is no clear winner because neither exist.
Cherry/clone switches suck (ie: don't last); stick with a hot swap board to replace when they (will) fail.
Offline dream3
« Reply #8 on: Thu, 09 March 2017, 17:54:04 »
So I should wait for the K-type instead of going with the Ducky One now, correct?
« Reply #9 on: Thu, 09 March 2017, 20:15:50 »
Totally depends. If you're looking for something more in the timeframe of immediate, definitely go with the Ducky. If you're willing to wait and maybe shell out a little more cash, go with the K Type.
That's just my personal take on it.
« Reply #10 on: Thu, 09 March 2017, 21:19:43 »
I really like Ducky's keyboards, and the ONE is great.
Do whatever you feel is the most sensible thing, though.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #11 on: Thu, 09 March 2017, 21:52:03 »
I agree... for the price, they're pretty hard to beat.
« Reply #12 on: Thu, 09 March 2017, 22:11:31 »
Especially used. A shine 3 is like $75 and very functional.
Offline robbles
« Reply #13 on: Thu, 09 March 2017, 22:13:35 »
I've bought Ducky One's for two different friends (Cherry Brown, Cherry Blue) who were curious about mechanical keyboards and they were both instantly converted. They seem reliable (one is going on 2 years with no issues) and the look is classic. All I can really say is that the stabilizers rattle, but welcome to the world of stock mechanical keyboards  ;)
How does one become so interested in a thing like keyboards? When you realize you use a keyboard more than any other tool in your life.
Offline dream3
« Reply #14 on: Fri, 10 March 2017, 15:57:01 »
Thanks guys.
My only worry is that the K-Type, which has the removable switches I want, would be somehow inferior to the Ducky. I know it's not even released yet but I'm no expert. If that was the case, then I'd buy the Ducky One right now.
I'm going to wait a bit and see if the K-Type really happens. If not, Ducky it is then.
Offline davkol
  •  Post Editing Timeout
« Reply #15 on: Fri, 10 March 2017, 16:58:18 »
It's simple: do you want a finished product, that you won't ever customize beyond toggling a few DIP switches and replacing keycaps, or something, that can work out of the box as well, but also can be finely tuned?
For me, the answer is the latter; in fact, I have no interest in a ducky whatsoever. Why?
  • Because I don't really like modern stock MX-compatible switches. I can use them alright, but they always slightly annoy me. What I do like are vintage blacks, jailhouse blues, switches that are damped or have springs of my choice… and HaaTa's working on a new kind of tactile switch, that might turn out to be exactly what I want. This implies either soldering, or a _good_ implementation of sockets for swapping switches. There's hope, that K-Type will be done right.
  • Because I want to customize the firmware far beyond swapping a few modifiers. I want custom layers, something like SpaceFN or the ability to send Unicode to the host system. K-Type allows lots of that; the firmware is open-source after all.
