Author Topic: [IC] GMK Penumbra Accent Kit (Awaiting Pricing Tiers)  (Read 139743 times)
Offline sherryton
  • Kībōdo
    • Originative
Re: [IC] GMK Penumbra Accent Kit (Awaiting Pricing Tiers)
« Reply #250 on: Fri, 09 June 2017, 13:30:00 »
http://imgur.com/a/hcgYt
Any final thoughts?
150 MOQ
Pricing: $95
250 MOQ
Pricing: $90
« Last Edit: Fri, 09 June 2017, 13:41:35 by sherryton »
Offline roostrc0gburn
  • its just plastic
« Reply #251 on: Fri, 09 June 2017, 13:38:14 »
windowed stepped caps lock would be realllly nice ;D
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
« Reply #252 on: Fri, 09 June 2017, 13:48:02 »
I've been using and really digging the stepped control you have in the current GMK Penumbra set- another in this kit would be nice... might be able to cobble two GMK Penumbra boards together...  :cool:
Offline xondat
  • i'm not a star
« Reply #253 on: Fri, 09 June 2017, 17:25:08 »
Looks good. If you're really, really wanting to go the whole mile - R4 1u Alt Gr?
Offline rempire
« Reply #254 on: Fri, 09 June 2017, 17:36:06 »
Number row 1u |\ for the split backspace peeps?
Sent from my 2PS64 using Tapatalk
Offline xondat
  • i'm not a star
« Reply #255 on: Fri, 09 June 2017, 17:39:08 »
Oh **** I completely missed this as the yellow base is in the set, but we need the Solarized for perfection.
Offline Atredl
« Reply #256 on: Fri, 09 June 2017, 20:11:39 »
Yes, row 1 1u |\ please!
Offline poolside
« Reply #257 on: Sat, 10 June 2017, 10:25:15 »
It looks like the solarized numpad area is also missing a 1u R4 Zero keycap to support 1800 boards.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #258 on: Sat, 10 June 2017, 15:15:24 »
Can we get everyone to agree:
R1 1u \|
R4 1u Alt Gr
R4 1u 0
R3 Windowed Stepped Caps Lock
R3 Stepped Control
We are looking at an additional $7-8
Offline smittysteve
« Reply #259 on: Sat, 10 June 2017, 15:26:17 »
Woot! I'm in.
Offline rempire
« Reply #260 on: Sat, 10 June 2017, 15:26:50 »
In
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #261 on: Sat, 10 June 2017, 15:30:09 »
R1 1u \| - Yes
R4 1u Alt Gr - No
R4 1u 0 - Yes
R3 Windowed Stepped Caps Lock - No
R3 Stepped Control - No
Personal suggestion: Barred Numpad 5
(Just an opinion, so please don't take it personally.)
  • its just plastic
« Reply #262 on: Sat, 10 June 2017, 15:34:01 »
R1 1u \| - Yes
R4 1u Alt Gr - No
R4 1u 0 - Yes
what a buzzkill. lol.
i'm down for all those keys, except i question if 'AltGr' can fit on a 1u key? i cant remember if i have seen that before... if it can be done, i'm for it
Offline xondat
  • i'm not a star
« Reply #263 on: Sat, 10 June 2017, 15:38:59 »
R1 1u \|
R4 1u Alt Gr
R4 1u 0
R3 Stepped Control
Down for all of them. If we're fixing the base kit, we should go all the way.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #264 on: Sat, 10 June 2017, 15:43:56 »
My main concerns were that, as roostrc0gburn pointed out, certain legends may not fit properly. Does Alt Gr fit in 1u, and does "Control" fit on a stepped key? It would likely be "Ctrl", right?
As for the Windowed Stepped Caps, I just realized that the original  GMK Penumbra set has a non-stepped windowed Caps Lock, so I guess we might as well add the stepped one as well. Sorry about that.
  • its just plastic
« Reply #265 on: Sat, 10 June 2017, 16:21:46 »
WOO1 for windowed keys
« Reply #266 on: Sat, 10 June 2017, 18:37:44 »
windowed caps lock only caps lock
Offline Atredl
« Reply #267 on: Sat, 10 June 2017, 18:54:56 »
R1 1u \|
R4 1u Alt Gr
R4 1u 0
R3 Stepped Control
Ye
Offline sherryton
  • Kībōdo
    • Originative
« Reply #268 on: Sat, 10 June 2017, 19:16:56 »
R1 1u \|
R4 1u 0
I think I will just add these few keys.
I'll most likely start the group buy this upcoming week.
« Last Edit: Sat, 10 June 2017, 19:22:57 by sherryton »
Offline chaseyeh0721
« Reply #269 on: Sun, 11 June 2017, 02:45:08 »
R1 1u \|
R4 1u 0
It is great to add the 3 keys into this set. Will join the group buy for sure.
« Reply #270 on: Mon, 12 June 2017, 23:36:14 »
Hi Sheraton,
Should not we have the caps lock in legend instead of icon?
Thank you.
Offline eksuen
  • Ambassador of explosions.
« Reply #271 on: Tue, 20 June 2017, 12:18:17 »
Will the GB start before the end of the month?
Offline sherryton
  • Kībōdo
    • Originative
« Reply #273 on: Thu, 22 June 2017, 12:34:23 »
:D
Offline xantiema
« Reply #274 on: Thu, 22 June 2017, 13:13:29 »
Will there be a EU proxy for this ?
Offline eksuen
« Reply #275 on: Thu, 22 June 2017, 13:46:33 »
Can't seem to find a picture of BL4 anywhere. I wonder how this compares to GMK Solarized Dark's mods. Regardless, I'm in.
Offline braidn
« Reply #276 on: Sun, 25 June 2017, 06:04:57 »
Wow! Super quick here with the GB window.
Offline oatmicro
« Reply #277 on: Sun, 25 June 2017, 06:33:55 »
Oh, I thought Alpha and Modifier will be separate...
Offline chuckdee
« Reply #278 on: Sun, 25 June 2017, 10:09:19 »
Need a GB thread for this one.  I almost missed it!
Offline Troif
  • Carpe Diem!!!
    • Daniel Ferrer
« Reply #279 on: Mon, 26 June 2017, 16:31:10 »
Ok ok ok... I am in... again... ok ok... BUT BUT... Why the hell you get the Windows logo on it when the CODE text is so agnostic? I am a Mac and Linux nerd and I can't stand a Windows logo!!!  :-[
(to fix this... if I also join for GMK Solarized Dark, then the #00232c from that set is equal to the base color of this Accent kit on the mods (BL4)? this way I would have no windows logo and even I would be near to having 3 full usable keycap sets...)
« Last Edit: Mon, 26 June 2017, 16:50:25 by Troif »
Filco TKL Ninja Blues / CODE Greens / Pok3r Clears / HHKBpro2 / RF 87U 55g / Novatouch TKL / KC60 Clears / SSK and also regular Model M
Offline rawrjau
  • Stop making nice things so I can stop spending
« Reply #280 on: Mon, 26 June 2017, 16:47:43 »
Ahh I really don't want to alphas... Think it'd be possible to sell them off easily?
Offline Giorgio
« Reply #281 on: Tue, 27 June 2017, 09:16:55 »
Very interested in this :-)
Is it compatible with iso? Probably it misses one key on R3?
https://geekhack.org/index.php?topic=85593.0
Probably many would prefer the 5 with bar to the 5 with nipple?
About the yellow keys, I welcome very much the F J with bars, but I wonder if there's some demand for a 5 with bars. Or for a 6u spacebar.
Offline eksuen
« Reply #282 on: Tue, 27 June 2017, 12:55:29 »
Should make a GB thread as this is already up on the Oco site: https://originative.co/products/gmk-solarized
Ends on 6/30
Offline Atredl
« Reply #283 on: Tue, 27 June 2017, 13:43:48 »
Really does need a GB thread since many people only check that sub forum.
Offline poolside
« Reply #284 on: Sat, 01 July 2017, 04:18:22 »
Any final thoughts?
150 MOQ
Pricing: $95
250 MOQ
Pricing: $90
I am noticing too late that the 1.25u Fn R4 cap has had its legend color changed from white to blue. This might break the color balance of accented legends as the bottom row does not have any caps with blue legends.
Offline Giorgio
« Reply #285 on: Sat, 01 July 2017, 04:50:24 »
Where is Sherryton?
Offline chuckdee
« Reply #286 on: Sat, 01 July 2017, 07:01:19 »
It is a long holiday weekend in the US.
Offline Atredl
« Reply #287 on: Thu, 20 July 2017, 21:25:59 »
Any news about this set? No word from on here for quite a while.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #288 on: Thu, 20 July 2017, 22:53:56 »
Hey Atredl,
We submitted this order to GMK approximately two weeks ago. It should be ready around late September to early August.
Offline chuckdee
« Reply #289 on: Fri, 21 July 2017, 07:29:58 »
Hey Atredl,
August or October, i.e. late September to early October?
Offline jjnist
« Reply #290 on: Sun, 23 July 2017, 14:17:15 »
Hey Atredl,
Late September 2017 to early August 2018
Offline Atredl
« Reply #291 on: Sun, 24 September 2017, 22:37:00 »
Living in LA certainly has it's perks. Just got my Solarized/Fix kit today!  :-* :-* :-*
Offline w0odyallen
« Reply #292 on: Tue, 26 September 2017, 10:26:48 »
Yeaaaa
« Reply #293 on: Thu, 28 September 2017, 18:48:33 »
Yeaaaa
Okay, that's freaking beautiful.
Offline Atredl
« Reply #294 on: Thu, 28 September 2017, 23:33:47 »
Yeaaaa
The shade of dark purple that was used works a lot better with the windows logo compared to the thinner "SUPER".
Offline pixelpusher
« Reply #295 on: Fri, 29 September 2017, 07:25:16 »
were these only available as a group buy?  Any chance of extras showing up on oco?
Offline pixelpusher
« Reply #296 on: Fri, 29 September 2017, 10:38:02 »
Well that's horse****.  I see now that the only way to get the addon is to buy the set again with the addon as well.  RIP
1. Penumbra Solarized Kit
The Penumbra Solarized Kit will have all shipped out today.
These will be now be available only with the Penumbra as a full kit.
want white alphas and a windows logo?  $279
So if guess you would have to sell your original set (probably ~$30 loss), and buy the full set plus solarized for $279.
« Last Edit: Fri, 29 September 2017, 10:41:10 by reececonrad »
Offline Atredl
« Reply #297 on: Fri, 29 September 2017, 13:05:12 »
IMO it wasn't advertised very well. This thread wasn't even moved into the GB section back when it was open.
