Author Topic: Atreus Ctrl and Alt reverted?  (Read 4617 times)
Offline Narann
« on: Mon, 13 March 2017, 19:29:34 »
Hi and thanks for the Atreus, it's almost finish so big kudo to technomancy for making a such fun project for everyone! :thumb:
The official Atreus page show this layout:
I compiled the latest firmware to check the layout and realize I have the same except Ctrl and Alt are reverted.
Is this normal? I reverted them back in keymap_qwerty.c and compile again and now I have the expected layout.
BUT I still ask because maybe there is a good reason for this. Maybe it's easier? I didn't type on it yet (waiting for the keycaps)
Of course I checked my wires using multiple references:
162853-0
If anyone have some info about this?
Thanks in advance and have a good day!
« Last Edit: Mon, 13 March 2017, 19:33:58 by Narann »
Offline cribbit
Re: Atreus Ctrl and Alt reverted?
« Reply #1 on: Tue, 14 March 2017, 13:02:05 »
I can't tell what default wiring is supposed to be.
That said, if you want a fast fix just make your own firmware: http://qmk.sized.io/
I've found that choosing my own layout is much nicer than the default layout.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Offline traktor
« Reply #2 on: Sat, 18 March 2017, 01:34:13 »
It looks like you have flipped the row connections for your Crtl/Alt keys. In your picture, Alt (the left switch with the red wire going to it) has been connected to the third row and Ctrl has been connected to the fourth row. It should be the other way around.
Offline Narann
« Reply #3 on: Sat, 18 March 2017, 12:23:08 »
@cribbit:
I didn't know this website, thanks. It doesn't works for Atreus though.
@traktor
I just checked again and it looks like I've done the same than this:
And here is an image of the official assembly guide:
163318-0
So basically, from my understanding, I'm doing the same as the official assembly guide.
Any Atreus guy already having this issue?
Offline cribbit
« Reply #4 on: Sat, 18 March 2017, 15:34:14 »
You'll have to create the KLE format (http://www.keyboard-layout-editor.com/) to get it to work with an Atreus. I'll see if I can dig up my files for it.
Offline Narann
« Reply #5 on: Sat, 18 March 2017, 15:43:34 »
That could be very nice!
Offline traktor
« Reply #6 on: Sun, 19 March 2017, 02:38:46 »
I think the KEYMAP macro that you are relying on has changed since that guide was written. This change might have been unintentional by the author (i.e. a bug) but it can be fixed in multiple ways, either by switching around the keys in the keymap config as you did, or better by editing the KEYMAP_PCBUP macro in keymap_common.h so it looks like this:
Code: [Select]
#define KEYMAP_PCBUP( \
  K00, K01, K02, K03, K04, K05, K06, K07, K08, K09, \
  K10, K11, K12, K13, K14, K15, K16, K17, K18, K19, \
  K20, K21, K22, K23, K24, K25, K26, K27, K28, K29, K2A, \
  K30, K31, K32, K33, K34, K35, K36, K37, K38, K39, K3A \
  { K00, K01, K02, K03, K04, KC_NO, K05, K06, K07, K08, K09 }, \
  { K10, K11, K12, K13, K14, KC_NO, K15, K16, K17, K18, K19 }, \
  { K20, K21, K22, K23, K24, K35,   K25, K26, K27, K28, K29 }, \
  { K2A, K30, K31, K32, K33, K34,   K36, K37, K38, K39, K3A }      \
