Advanced search
it's a keyboard thing
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
NEW USERS, READ
THIS!
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Keyboards
How to remove this Stabilizer
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to remove this Stabilizer (Read 2969 times)
Xevoxz
Thread Starter
on:
Thu, 16 March 2017, 00:44:21 »
http://i.imgur.com/EhEx4o7.jpg
the right side is loose thats why its making a rattle noise how do i remove it or remove the rattle noise?
Logged
Puddsy
nice
Elated Elder
"Do you shovel to survive, or survive to shovel?"
Re: How to remove this Stabilizer
Reply #1 on:
Thu, 16 March 2017, 00:58:14 »
Make sure the white bit is in your key all the way. Check with tape.
Logged
QFR
MJ2 TKL
"Bulgogiboard" (Keycon 104)
ctrl.alt x GON 60%
TGR Alice
Mira SE #29
Mira SE #34
Revo One
z
Keycult No. 1
First CW87 prototype
Mech27v1
Camp C225
Duck Orion V1
LZ CLS sxh
Geon Frog TKL
Hiney TKL One
Geon Glare TKL
Xevoxz
Thread Starter
Reply #2 on:
Thu, 16 March 2017, 01:27:21 »
i removed it , and switched the stabilizers and now the left side is rattling meaning the Plastic stabilizers are the problem,
and btw is this compatible?
http://www.wasdkeyboards.com/index.php/cherry-mx-plate-mounted-stabilizer-clips-2pcs.html
sorry newbie here
Logged
Puddsy
nice
Elated Elder
Reply #3 on:
Thu, 16 March 2017, 01:31:45 »
Hm. Weird issue.
That's the right part. They're sometimes called costar stabilizers. You might be able to use some tape to wedge the clip into place so it stops rattling.
What model of keyboard are you using?
Logged
QFR
MJ2 TKL
ctrl.alt x GON 60%
TGR Alice
Mira SE #29
Mira SE #34
Revo One
z
Keycult No. 1
Mech27v1
Camp C225
Duck Orion V1
LZ CLS sxh
Geon Frog TKL
Hiney TKL One
Geon Glare TKL
Xevoxz
Thread Starter
Reply #4 on:
Thu, 16 March 2017, 01:32:46 »
a razer keyboard yeah, first the right rattles then i switched them and now the left rattles , guess i better buy some Stabilizers
Logged
pomk
Reply #5 on:
Thu, 16 March 2017, 02:42:26 »
Just put some clingfilm over the hole in the keycap before installing the insert and it should fit in place more snugly.
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Keyboards
