Author Topic: Fix lightweight Switch (help)  (Read 1378 times)
Offline Xevoxz
« on: Fri, 17 March 2017, 07:52:58 »
Keyboard: Razer blackwidow chroma stealth
so i didn't noticed until now my "A" key feels different
it has a tactile bump, but its kinda lightweight than all the other keys, like its smooth to press down and lighter than the other keys that's why it more noisy
any fix for this? Only letter "A", Stealth (Orange)  is equivalent to "Mx browns" btw
Offline devoi
Re: Fix lightweight Switch (help)
« Reply #1 on: Fri, 17 March 2017, 08:48:33 »
It seems like you would have to replace the switch by desoldering and swapping it with a new one. That really isn't an option though, since you can't just buy stock of these switches. If anything, just swap it with another switch from the same board that you don't use as much. I'd just recommend staying away from razer in the future - their switches tend to be terrible (as you can tell), they're incredibly overpriced for what you do actually get, and they basically force you to use their near-spyware software.
Offline Minnie2
« Reply #2 on: Fri, 17 March 2017, 09:47:07 »
You might need to replace the "A" key's spring :)
    A Bro Caps Fan
Just wanted to make sure everyone sees that information. A lot of people missed it ;)
Offline Xevoxz
« Reply #3 on: Fri, 17 March 2017, 10:34:34 »
then i'll wait for a month then lol to use the warranty :D
