Author Topic: Custom made headphones holder  (Read 6092 times)
Offline Entropia
« on: Sat, 25 March 2017, 10:41:55 »
I've just finished my Grado SR 225i headphones holder. It's made with 5 pieces of 19mm MDF, cut, glued, sanded, primed and spray painted. The "G" logo is carved in both sides.
Offline m3ll3n
Re: Custom made headphones holder
« Reply #1 on: Mon, 27 March 2017, 18:43:35 »
picture not loading  :'( I wanted to see!
Offline Entropia
« Reply #2 on: Wed, 29 March 2017, 16:40:40 »
Isn't it loading? I can see it here.
Edit: I'm attaching it to the message.
« Last Edit: Fri, 31 March 2017, 17:59:24 by Entropia »
Offline orpheo
« Reply #3 on: Thu, 30 March 2017, 02:58:38 »
Not loading m8 ^-^
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #4 on: Thu, 30 March 2017, 03:21:16 »
Download the image and attach it to your post instead of linking it
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #5 on: Fri, 31 March 2017, 21:57:12 »
http://i67.tinypic.com/2hzj1uh.jpg
Looks really good! Almost like plastic. I'm guessing you own a cnc machine? or did you do this with a router and template?
-Dana
