Author Topic: anywhere to purchase 6.0 unit Oem pbt space bars?  (Read 4447 times)
Offline Encabulator
« on: Tue, 28 March 2017, 13:51:11 »
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Re: anywhere to purchase 6.0 unit Oem pbt space bars?
« Reply #1 on: Tue, 28 March 2017, 13:57:23 »
I'm going with probably not. You also might want to specify if you want a center stem or offset stem spacebar.
 The pbt spacebars I can think of that would be 6x are not OEM profile. You *might* can find one in another profile from SP and possibly find one in cherry profile elsewhere.
But like everything else around here there is always an exception.
Also you can ask simple questions here -> https://geekhack.org/index.php?topic=40501.0
Some sources of 6 unit spacebars not necessarily to your requested specs
http://www.maxkeyboard.com/6x-spacebar-cherry-mx-keycap-1x6.0.html
http://pimpmykeyboard.com/dcs-spacebars-pack-of-1/
http://pimpmykeyboard.com/dsa-spacebars-pack-of-1/
And some previous threads for information
https://geekhack.org/index.php?topic=48939.0
https://geekhack.org/index.php?topic=75024.0
« Last Edit: Tue, 28 March 2017, 14:06:25 by SpAmRaY »
Offline Encabulator
« Reply #2 on: Tue, 28 March 2017, 15:53:12 »
Do you think a DCS spacebar would look too out of place on a keyboard using all OEM keycaps? My other option would be making my whole bottom row DCS
« Reply #3 on: Tue, 28 March 2017, 16:25:08 »
DCS is lower than OEM, but if you flip it it's hard to notice.
Offline Encabulator
« Reply #4 on: Wed, 29 March 2017, 00:00:10 »
I wend with DSA because it will look my spacebar look completely different instead of trying to "Imitate" OEM (Or I'm dumb and have no idea what I'm doing)
« Reply #5 on: Wed, 29 March 2017, 00:06:06 »
that's just life
if you don't like it you're only out a few bucks anyway
Offline Targa-TV
« Reply #6 on: Wed, 29 March 2017, 07:29:30 »
Don't know if you still want OEM profile but most keycaps in Shenzen YMD store are OEM and this should be no exception. You can always send a message to Vincent, he's very quick to reply.
https://aliexpress.com/store/product/White-Thick-PBT-Blank-Additional-Keycap-Supplement-Keycap-Special-Keycap-Set-Key-Cap-Set-7u-3u/429151_32645867417.html?spm=2114.12010612.0.0.F0cgpp
Filco MJ2 Black - MX Red | VA88M - MX Brown | Cherry G80-3000 -
  MX Blue | Cherry G80-3000 - MX Black | XD75re - MX Silent Red
[image]http://i.imgur.com/our8YUc.png[/image]
« Reply #7 on: Wed, 29 March 2017, 14:24:17 »
I was going to link that one but noticed it said this
Notes:
6u Spacebar is for Cherry old keyboard and HHKB keyboard,the middle hole is not in the center.
Offline Targa-TV
« Reply #8 on: Wed, 29 March 2017, 16:24:23 »
Notes:
WTF. Didn't see that. "Cherry old keyboard".... Um, for example?
« Last Edit: Wed, 29 March 2017, 16:26:42 by Targa-TV »
Offline Skull_Angel
« Reply #9 on: Wed, 29 March 2017, 20:26:08 »
If you flip the spacebar for comfort, you won't really notice the difference in profile any way  ;D
Edit: missed Puddsy already noting this.
« Last Edit: Wed, 29 March 2017, 20:28:25 by Skull_Angel »
