Author Topic: Vortex Core  (Read 1487 times)
Offline jcoffin1981
Vortex Core
« on: Sun, 09 April 2017, 22:47:11 »
Now that this has been out for a few months I'm curious as to peoples feelings after a learning curve.  I love the size of it. I do have some problems (I'm debating buying it).  Seems to be mixed reviews so far.
1. There are no nibs on the home row J and F keys.
2.  All the FN switches are on the right side.
3. It looks like some of the symbols have to be accessed by Fn + Shift?
4.  I'm guessing it's not possible to reprogram the left Caps key to a Fn key?  Using the arrow keys and pressing the Fn key must be really weird.
I love the split spacebar
Offline Twinguin
Re: Vortex Core
« Reply #1 on: Mon, 10 April 2017, 07:06:26 »
I've been using the Core for a while now and do love the little board. About your questions:
1) True, no nibs, but the keys are "deeper" or "rounder" (don't know how to describe best) so that you can feel those two.
2) You can move the Fn to the left side modifiers if you want.
3) True, but you can remap you most needed ones to a Fn layer, i.e. you only need to press Fn (no Shift)
4) Haven't tried that yet, but as I said, you can move Fn to the left side (including the left space bar) and use the arrow keys similar to the Pok3r. Or you can actually enable an arrow cluster on the bottom right corner.
If you get one, make sure to have the newer firmware on, before that Fn couldn't be moved and the both space bars acted as one.
There is a curse. They say: May you live in interesting times!, Terry Pratchett
Popsicle KUL ES-87 (MX Blue, DSA) | Sun Ultracomputing Pok3r (MX Brown, DSA) | Nuclear WASD 100% (MX Brown, SA) | Gulf Pok3r (MX Clear, DSA) | Granite JD45 (MX Blue, DSA) | Coffee Core (MX Red, DSA) | Lime Pok3r (MX Clear, SA) | Canvas Vibe (MX Silent Red, XDA)
