Author Topic: [IC] UK78 - 60%+Numpad Keyboard - A British Custom - GB LIVE!  (Read 106872 times)
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
Re: [IC] UK78 - 60%+Numpad Keyboard - A British Custom
« Reply #50 on: Fri, 21 April 2017, 20:59:07 »
Super cool looking case, is there any chance making a 60% case?
Offline rozakiin
  • British Custom Anyone?
    • UK Keyboards
« Reply #51 on: Sat, 22 April 2017, 06:01:40 »
Not currently but if there is enough interest I could do a group buy for a 60% case.
Offline BlackInk
    • TeamGSB
« Reply #52 on: Sat, 22 April 2017, 11:47:40 »
Thanks, i think you should make a poll later on for people to vote
Offline rozakiin
    • UK Keyboards
« Reply #53 on: Tue, 25 April 2017, 05:38:24 »
Update: 1
I am currently in contact with the manufacturer to ensure that the case can be made as inexpensive as possible without sacrificing quality or design.
Currently the costs for a set of small feet are ~$90 and the larger base is ~$160 making the overall cost of a UK78 ~$300 and ~$350.
Offline rozakiin
    • UK Keyboards
« Reply #54 on: Tue, 25 April 2017, 05:43:22 »
There could also be the option of Acrylic small feet for the same cost as the Aluminium ones.
Thoughts?
Offline LDobler
« Reply #55 on: Tue, 25 April 2017, 08:08:25 »
What do we get for the 350$?
Case with angled bottom + Plate?
How much is the PCB?
Thanks
Offline rozakiin
    • UK Keyboards
« Reply #56 on: Tue, 25 April 2017, 08:27:03 »
Thanks
Top case, Angled base, switch plate and PCB
The blank pcb is $10 with components being $20-30
Offline LDobler
« Reply #57 on: Tue, 25 April 2017, 08:35:45 »
Thanks
Is the included PCB presoldered?
350$ for the full kit is not a bad price  :thumb:
Offline rozakiin
    • UK Keyboards
« Reply #58 on: Tue, 25 April 2017, 09:03:22 »
Currently the PCB is not presoldered as they won't give me a quote for assembled until I have checked the quality of the PCBs which arrive tomorrow.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #59 on: Wed, 26 April 2017, 08:48:35 »
All of the yes!
Offline ak_xf1re
  • Daydreamer
« Reply #60 on: Wed, 26 April 2017, 12:04:59 »
This looks awesome, would love to get it depending on when the groupbuy starts so I'll keeping my eye out :thumb:
Offline kmba
  • Formerly tameone
« Reply #61 on: Wed, 26 April 2017, 21:24:44 »
Thoughts?
damn, so many options you're giving us.  I think it would be important to balance aesthetics and price.  With that said if prices are pretty similar across the board order of preference would be : fully beveled case (this is a given), full alu bottom 1st, alu feet with acrylic bottom 2nd, acrylic bottom and feet 3rd, acrylic bottom with standard screw in feet.
keyboards.
Offline LDobler
« Reply #62 on: Tue, 02 May 2017, 12:10:44 »
Any updates?  :-X
Pretty hyped for this tbh
Offline rozakiin
    • UK Keyboards
« Reply #63 on: Tue, 02 May 2017, 12:32:00 »
Any updates?  :-X
I will have a bigger update when I have quotes back from the PCBA and the case manufacturers. I have received the first prototype PCB samples and currently ensuring that they work correctly and have no flaws that need to be addressed.
Offline LDobler
« Reply #64 on: Tue, 02 May 2017, 13:18:00 »
Any updates?  :-X
Can't wait!  ;D
Offline ChitownM2
« Reply #65 on: Wed, 03 May 2017, 13:05:55 »
I'll almost certainly be in on this.
Kind of torn between full aluminum bottom and acrylic bottom with aluminum feet. I think price would be a a big factor there as of it really is $70 cheaper to go with an acrylic bottom that would likely sway my opinion.
If we go with acrylic bottom what pcb color are you considering? The tender shows green, but I think that is kind of boring of were going to have a window to view it. Thinking white, blue or red would be better, with white being the best for reflecting led underglow.
« Last Edit: Wed, 03 May 2017, 13:54:02 by ChitownM2 »
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #66 on: Wed, 03 May 2017, 15:04:52 »
ETA Of GB?
Offline ChitownM2
« Reply #67 on: Wed, 03 May 2017, 15:57:19 »
Hard to say for sure from the renders but it doesn't look like the plate sports switch top opening. Is this indeed the car or was or just a simplification for the render?
Offline ns90
« Reply #68 on: Wed, 03 May 2017, 23:15:53 »
I forgot about this IC, and now I'm rethinking the ZZ96. Hmmmm, decisions, decisions.
Offline 12on
« Reply #69 on: Thu, 04 May 2017, 01:38:08 »
For those who suggested a different look to the case, is this an improvement?
yes if you make one with the function keys i'm in.  i need the F2 for excel.
and / or if you add a key or two on the front side below the space bar like the smart 68.  i think everyone will go wild.
http://imgur.com/a/xdFDd
are the keys fully customizable?
classy!!
« Last Edit: Thu, 04 May 2017, 01:39:45 by 12on »
Offline kmba
  • Formerly tameone
« Reply #70 on: Thu, 04 May 2017, 07:19:03 »
It will be fully programmable and you can make any key f2.
keyboards.
Offline LDobler
« Reply #71 on: Thu, 04 May 2017, 07:20:18 »
Or just buy both and sell the keyboard you like the least 😛👌
Offline rozakiin
    • UK Keyboards
« Reply #72 on: Fri, 05 May 2017, 10:26:30 »
Hi everyone, I received the test PCB's and found errors that prevented them from working, I am currently improving the PCB design so it will be more reliable and asking the case manufacture for the cost of a sample case to show the quality as my original prototype case manufacturer has gone quiet.
The plate will be using the same switch holes as in LZ-GH https://dangwang.files.wordpress.com/2013/06/img_0604.jpg which support switch top removal.
ETA Of GB?
Mid to late June I hope
Here are examples of the green and blue pcb colours, colours apart from green do cost slightly but not significantly more
167708-0
Offline ChitownM2
« Reply #73 on: Fri, 05 May 2017, 12:22:55 »
Blue looks pretty good. Black or white might also look nice.
FWIW, if I'm dropping this much cash on a keyboard I'm not really concerned about a couple extra dollars to get a PCB in a color that completes the package.
« Last Edit: Fri, 05 May 2017, 12:27:00 by ChitownM2 »
« Reply #74 on: Sat, 06 May 2017, 19:42:43 »
I'd go with a white PCB, because if you put LEDs in there, they will reflect better. That said, PCB color is probably at 19 or 20 on my list of important things to consider, so it's NBD.
Speaking of which, I'd be interested in a PCB and plate for sure and *maybe* a case, depending on how it looks and price. I still use my OG Phantom on cardboard, and it's nice.
Offline SpectreiiI
  • Scribe
« Reply #75 on: Sun, 07 May 2017, 21:29:29 »
Right now my daily driver is an RS96, but I could seriously see myself switching to a solidbase UK78 if the price is in the  $300 range.
Offline ChitownM2
« Reply #76 on: Sun, 07 May 2017, 21:47:50 »
I'd agree that pcb color isn't a deal breaker, but it is also something that can be easily addressed with almost zero effort and very minimal cost. Seems worthwhile to me to at least get quotes for a color other than green.
Offline rozakiin
    • UK Keyboards
« Reply #77 on: Mon, 08 May 2017, 08:47:37 »
Colour other than green adds ~$2 to the pcb cost, What would be everyones preference between Green, Red or Blue?
« Last Edit: Mon, 08 May 2017, 09:21:37 by rozakiin »
Offline cynviloq
« Reply #78 on: Mon, 08 May 2017, 10:02:13 »
I would pay $2 extra for Blue or Black
Offline ChitownM2
« Reply #79 on: Mon, 08 May 2017, 12:44:16 »
For less than a 1% increase to the project cost I'd say anything other than green.
You should probably just create a poll, but I'd be fine with either blue or red if those are the only options. If I had to choose I'd go blue because I haven't seen too many blue boards.
Edit: I'll add that white would be at the top of my list as well.
« Last Edit: Mon, 08 May 2017, 12:54:54 by ChitownM2 »
Offline kmba
  • Formerly tameone
« Reply #80 on: Mon, 08 May 2017, 12:47:18 »
White, black, red, blue in order.
keyboards.
Offline breckstar
« Reply #81 on: Mon, 08 May 2017, 16:54:37 »
I would be interested in like silver or something out of the ordinary. Or matching to the case colors offered.
Offline rozakiin
    • UK Keyboards
« Reply #82 on: Mon, 08 May 2017, 17:11:03 »
Unfortunately only one colour can be selected due to MOQ and Silver is not a soldermask that can be achieved easily
Offline Captainbuttmonkey
« Reply #83 on: Thu, 11 May 2017, 10:31:57 »
Definitely down for this, will it be possible to be invoiced in £'s if you're from the UK? Would be nice not to get shafted by the exchange rate/paypal exchange rate for once?
Offline rozakiin
    • UK Keyboards
« Reply #84 on: Thu, 11 May 2017, 13:07:46 »
That should be no problem, I will make sure that people will get the lowest cost possible.
« Reply #85 on: Thu, 11 May 2017, 13:35:20 »
Awesome =]
Offline rozakiin
    • UK Keyboards
« Reply #86 on: Sat, 13 May 2017, 07:40:10 »
Update:
  • Sample Case has been ordered and will arrive in a week.
  • Revised PCB sample has also been ordered.
  • The manufacturer is able to try and colour match to any Pantone or RAL, plan is to have each case colour match a GMK Colour!
  • LeandreN has given to OK for the Fjell inspired case design to be produced so everyone can have the choice of Fjell style or 1800 Style.
  • Group Buy planned to start in just over a month.
Offline stoic-lemon
« Reply #87 on: Sat, 13 May 2017, 18:10:47 »
This is exciting! Hope this is a super successful GB.
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #88 on: Sat, 13 May 2017, 18:24:22 »
first time seeing this, looks fantastic
Offline rozakiin
    • UK Keyboards
« Reply #89 on: Sun, 14 May 2017, 16:40:22 »
Thanks for the support!
Offline rozakiin
    • UK Keyboards
« Reply #90 on: Sun, 14 May 2017, 17:00:11 »
Does anyone have any thoughts for the GMK colours to be matched?
Planned Colours are N9 (Skidata, >Terminal, Dolch etc.), Pantone 534 C from Nautilus, CR (WOB or 9009/Beige Legends) and Silver/Clear but I am open to suggestions
N9 fjell style
168408-0
N9 1800 style
168410-1
Silver/Clear
168412-2
Pantone 534 C
168414-3
CR
168416-4
Offline Anakey
« Reply #91 on: Sun, 14 May 2017, 18:18:30 »
hmm i will be using this with Canvas, so i think the N9 or CR would fit the best for my build at the moment
« Last Edit: Sun, 14 May 2017, 18:21:46 by Anakey »
Offline LDobler
« Reply #92 on: Sun, 14 May 2017, 18:21:46 »
Is white possible?
Offline rozakiin
    • UK Keyboards
« Reply #93 on: Sun, 14 May 2017, 18:58:33 »
Is white possible?
It is possible but only through powder coating which I believe costs slightly more, when the orders are open, feel free to see if powder coating can be done if you don't mind the increased cost of ~$10
Offline LDobler
« Reply #94 on: Sun, 14 May 2017, 19:09:54 »
Is white possible?
Not a fan of powder coating tbh... Will black anod. be an option or just the colors you posted?
Cheers
Offline rozakiin
    • UK Keyboards
« Reply #95 on: Sun, 14 May 2017, 20:12:33 »
Is white possible?
Cheers
CR is Black, sorry if that wasn't made clear.
Offline gt1989
« Reply #96 on: Sun, 14 May 2017, 20:13:37 »
Will there be any kind of cyan color option?
Sent from my Nexus 6P using Tapatalk
Offline ideus
  • Björkö.
« Reply #97 on: Sun, 14 May 2017, 20:28:15 »
Could the PCB be cut down to a 60%? If so, would it fit a standard 60% case?
Offline kmba
  • Formerly tameone
« Reply #98 on: Mon, 15 May 2017, 00:14:27 »
I think matching the modifiers on Nautilus (Pantone 533 C) is a better idea.  The darker color will allow if to work well with other sets like Yuri, etc. Lighter blues limit visual compatibility to my eye.
keyboards.
Offline Rykno
« Reply #99 on: Mon, 15 May 2017, 00:30:42 »
I really like the N9 Fjell style!
