Author Topic: Best budget 60% sleeve?  (Read 1149 times)
Offline Encabulator
« on: Fri, 14 April 2017, 17:51:27 »
I'm looking around for a 60% sleeve that isn't going to kill my wallet. I bought the cheap Allen gun sock to try it out but my main concern with it is all the lint getting in my lubed stabilizers. what sleeves can you recommend?
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline ddot
  • Master of Suspense
Re: Best budget 60% sleeve?
« Reply #1 on: Fri, 14 April 2017, 19:04:22 »
How budget are you looking for?  I picked up a Grifiti Chiton Fat 12 for my Whitefox (65%).  It's a bit of a snug fit, but I'm happy with it, especially for the price.  A 60% should fit nicely too, probably even a little better.
https://www.amazon.com/10keyless-Mechanical-Keyboards-Steelseries-Quickfire/dp/B00MRK233I/ref=sr_1_2?ie=UTF8&qid=1492214141&sr=8-2&keywords=Grifiti+Chiton+Fat
