Author Topic: Recommendations for good ps2 to usb adapter?  (Read 11377 times)
Offline dantan
« on: Sat, 15 April 2017, 00:45:21 »
I need a good ps2 to usb adapter for an old keyboard.
I've read that bluecube is the best https://geekhack.org/index.php?topic=9351.0
but I need something with a small head thanks to the tight spaces between my usb ports. Head must be as small and flat as possible otherwise I cannot stick my other usb devices.
would love to hear who has any good suggestions. I have gone through a bunch of Chinese cheap devices and they simply aren't reliable enough. Sometimes I get a bunch of keys repeated likkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkke this or else
returns endlessly.
Offline Tactile
Re: Recommendations for good ps2 to usb adapter?
« Reply #1 on: Sat, 15 April 2017, 02:38:26 »
What about a blue cube combined with something like this?
REΛLFORCE
Offline dantan
« Reply #2 on: Sat, 15 April 2017, 03:05:52 »
I do have extension cords, but really not keen. I mean, I'm already connecting an old Ps2 keyboard to a ps2 to usb converter, and now I still have to use another cable. Doesn't that just increase the chances of signals screwing up?
What horrifies me most, is if I go away from my computer, and five minutes later return to see the system messed up because the keyboard was sending trillions of keypresses in my absence.
Offline NoChance
« Reply #3 on: Fri, 30 June 2017, 16:02:48 »
I've used this one http://amznly.com/3kc with an AT101W with success.
I recommend a 1-2 inch USB extender for the fit problem.
