Author Topic: perished o-rings on my filco's keycaps.  (Read 1765 times)
Offline atarione
« on: Mon, 17 April 2017, 16:29:20 »
huh.. so this is weird.. anyone see this happen before?
the keyboard is just barely 2yrs old and these vortex keycaps I got a few months later so they are 21~mos old.. while cleaning the keyboard today I just noticed like 30~40% of the o-rings have either cracked or broken entirely..
I have never had this problem before on other keyboards.. hopefully none of the little o-ring bits fell into any of the switches.. (as far as I know they haven't as I had noticed no problems using the keyboard up to this point..)
« Last Edit: Mon, 17 April 2017, 16:34:31 by atarione »
Re: perished o-rings on my filco's keycaps.
« Reply #1 on: Mon, 17 April 2017, 16:47:35 »
Were those marketed as keyboard o-rings or did you buy a pack of cheap o-rings from the hardware store? All o-rings will dry out and crack/ age over time and they aren't designed to be used as keycap landing pads so it's possible that the extra beating just caused them to age faster.
« Reply #2 on: Mon, 17 April 2017, 16:57:24 »
the o-rings on my QFR are fine and they've been there for like 4 years
prolly just too dry in your room or something
Offline atarione
« Reply #3 on: Mon, 17 April 2017, 17:21:43 »
ah.. good point these were cheapies from amazon.. people had been putting them on keyboards but they weren't marketed for such use.. probably why the other o-rings I had used before were from WASD and they have indeed held up better.
