Author Topic: [IC] Laser GMK - 80's & Cyberpunk (LIVE)  (Read 438380 times)
Offline xondat
  • i'm not a star
Re: [IC] Laser GMK - 80's & Cyberpunk (LIVE!)
« Reply #1200 on: Wed, 22 November 2017, 13:59:47 »
Please move discussion to a proper GB thread to eliminate any confusion.
Will be updating OP with the correct child kits, etc. as I don't know how to move the discussion to a proper GB thread myself.
Create a thread in the Massdrop section of Geekhack here:
https://geekhack.org/index.php?board=184.0
Offline avid
Re: [IC] Laser GMK - 80's & Cyberpunk (SAMPLES!)
« Reply #1201 on: Wed, 22 November 2017, 14:05:08 »
I think the regular "Group buy" forum would be a better place.
Yes, its being ran by MD, but all the vendor subforums are terrible if you want visible threads with traffic.
« Reply #1202 on: Wed, 22 November 2017, 14:15:54 »
>tells people to move thread
>is the only person that can move the thread
ok
Offline xondat
  • i'm not a star
« Reply #1203 on: Wed, 22 November 2017, 14:25:12 »
ok
He's got to live up to mod of the year 2016 somehow
Offline ghostjuggernaut
Re: [IC] Laser GMK - 80's & Cyberpunk (LIVE)
« Reply #1204 on: Wed, 22 November 2017, 18:53:45 »
ok
>make a new thread.
Offline amnesia0287
  • Formerly Amnesia
« Reply #1205 on: Thu, 23 November 2017, 01:34:48 »
ok
I had to do it...
EDIT: just to be clear i just had to do it cause i thought it was funny, not cause im mad or attacking anyone :D
« Last Edit: Thu, 23 November 2017, 01:37:44 by Amnesia »
« Reply #1206 on: Mon, 27 November 2017, 12:49:31 »
The Massdrop page says that the base set includes a "non-standard center stem 6u spacebar".
Why the **** would they do that?  It should have the Cherry-stem 6u space.
Offline avid
« Reply #1207 on: Mon, 27 November 2017, 12:55:52 »
Center stem is for HHKB i think. Off-center is 1800.  Is there any other keyboards that use 6u?
« Reply #1208 on: Mon, 27 November 2017, 13:03:23 »
Some of my customs use the 1800 space. Ugh hhkb isn't even Cherry stem.
Sent from my HTC6545LVW using Tapatalk
Offline rioc
« Reply #1209 on: Mon, 27 November 2017, 14:11:23 »
The last few gmk sets had both Center and off center stems on the 6U spacebar
Sent from my DREA100 using Tapatalk
« Reply #1210 on: Mon, 27 November 2017, 14:15:33 »
Which? Honeywell was Cherry only. Only the 6.25 was multistem.
Offline avid
« Reply #1211 on: Mon, 27 November 2017, 14:23:23 »
nautilus has 4 spacebars in base-kit (!!!)
Offline rioc
« Reply #1212 on: Mon, 27 November 2017, 14:26:56 »
Carbon and yuri, however I used the spacebar from the spacebar kit...
Offline haydoselefantes
« Reply #1213 on: Mon, 27 November 2017, 15:06:32 »
My old Das Keyboard has a 6u center stem on its weird bottom row.
GMK Plum had only off-center 6U (at least in the base kit).
Offline ScottieLK
« Reply #1214 on: Tue, 28 November 2017, 17:48:24 »
So stoked for this
Varmilo VA87MR
Offline amnesia0287
  • Formerly Amnesia
« Reply #1215 on: Wed, 29 November 2017, 03:25:10 »
No they didn't lol. Unless I remember wrong, the stems are too close between the 2 types, so if you include both stems you have 1 stem in your switch and another that rubs against the side of it.
Offline ninjacore
« Reply #1216 on: Wed, 29 November 2017, 19:46:59 »
First GMK GB for me. Excited :)
Offline Konjungamo
« Reply #1217 on: Wed, 29 November 2017, 21:49:16 »
Nautilus did it with two space bars, one with centered stem, the other one off-center:
183235-0
Offline ullr
« Reply #1218 on: Wed, 29 November 2017, 23:56:16 »
Well this quarter is chock full of stuff that is costing me dearly, but I had to join if only for the novelties. A shame this set was so close to being twice as good in my esteem, but what can you do.
I think it will look stunning with a white case, but it’s going to have to fight for the spot!
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #1219 on: Thu, 30 November 2017, 00:10:29 »
I’m thinking of just novelties too, because I’m definitely going in all the way for GMK Camping.
Ideally, I’d try and get just the Laser mods from the base kit in aftermarket though (paired with OG dyesub alphas ofc)
You're a smooth smoothie, you know? ~ Gaear Grimsrud
