Author Topic: [GB] 75SQ (Acrylic 75% keyboard) [Refund]  (Read 125963 times)
Offline leeku
Re: [GB] 75SQ (Acrylic 75% keyboard)
« Reply #50 on: Thu, 27 April 2017, 09:10:57 »
Would be interested in the al version :D.
it was not good quality as much as its price, sorry
Offline midnight2903
« Reply #51 on: Thu, 27 April 2017, 11:39:48 »
Hey leeku, is it possible to do split backspace that is also compatible with normal one?
Offline fublamchu
  • ㅋㅋㅋ
« Reply #52 on: Thu, 27 April 2017, 14:30:29 »
You can you just need to specify that in the order form section for plate modifications
LZ-CE VBlacks
910-CE
Offline poolside
« Reply #53 on: Thu, 27 April 2017, 17:56:56 »
Will these Duck feet from the CPSQ GB be compatible with the 75SQ bottom?
Most likely not, woiuld need to request the bottom to be drilled/cut as so, Sorry bout that, was doing a reference for where the holes for the feet are
:) Duck feet are supported if you have any. But I don't have any Duck feet left. that's why I didn't mention about the the Duck feet.
And if you really want the other layout you will have with +$10. describe it on D. custom in the form.
Ok, thanks! Does Duck still make them?
I don't think so.. but I have 4 or 5 leftover actually.
If you want, I will add in the invoice just comment on (D. custom)
Great :) These feet look so beautiful!
I left a comment in the "D. custom" field asking for a pair of Duck feet as well as my extra custom layout plate.
Offline Belfong
« Reply #54 on: Thu, 27 April 2017, 19:25:33 »
Ah, I'm still torn between the Function row or the detached F-row. The non-detached made it look like Noppo Choc Mini... hmmm. Can we have more pictures please?
Offline leeku
« Reply #55 on: Thu, 27 April 2017, 21:04:12 »
It would look bad and not firm to switch. so I make it separately.
If you want 1u x2 for back space bar, describe at D.custom plate on the form
Offline leeku
« Reply #56 on: Thu, 27 April 2017, 21:06:15 »
Yes original is just look like NoppoChoc mini. I strongly suggest detached.!!
Offline Belfong
« Reply #57 on: Thu, 27 April 2017, 23:41:54 »
Yeah, I don't quite like Noppo Choc Mini and the only reason I chose non-detached was because in one photo, I saw the Page Up and Page Down button on the top row. And I need Page Up/Down. But I suppose your PCB is highly configurable, so I could have them even in detached.
Can I still change? I will have to look at the photos a few times.
Offline leeku
« Reply #58 on: Thu, 27 April 2017, 23:58:43 »
This is the layer holding FN key I am using currently.
I'm addicted with this.
It looks little odd but it is worthy to try :)
PgUp/Dn is accessible only left hand. I'm using H/W macro with blue keys. It is quite good for memorize with initial character. like H to "hello world!" Y to "yap!!" like this..
167146-0
Offline Belfong
« Reply #59 on: Fri, 28 April 2017, 02:40:54 »
PM'd. I am convinced. ANSI D it is then!
Offline calvinhousecat
« Reply #60 on: Sat, 29 April 2017, 14:24:22 »
Leeku for assembling options,
I am aware that the only options are Browns and Linears. But is there anyway you could include Blues?
Offline leeku
« Reply #61 on: Sat, 29 April 2017, 21:04:35 »
Possible.
Just comment at the D.custom in the form.
I will send proper invoice
thanks!
Offline poolside
« Reply #62 on: Sun, 30 April 2017, 09:06:20 »
The form has a field named "How much do you need to pay? (Include shipping 30$)". Is that for customs?
Offline leeku
« Reply #63 on: Sun, 30 April 2017, 12:07:23 »
No don't worry it's just to know how much you would pay for this.
Ignorable.
« Reply #64 on: Sun, 30 April 2017, 16:49:01 »
Possible.
thanks!
Oh okay, could you cancel my original order and save my spot for an assembly option?
I will put in another order tonight. My paypal email is: calvinhvo@yahoo.com
Offline K.Mak
« Reply #65 on: Sun, 30 April 2017, 17:14:33 »
Is this PCB using a USB mini or micro connector?
Is it possible to have a bottom row as 1.5   1   1.5   6 instead of 1.25   1.25   1.25   6.25?
Offline leeku
« Reply #66 on: Sun, 30 April 2017, 20:45:00 »
Yes possible Just put it on D.custom on the form.
Offline leeku
« Reply #67 on: Sun, 30 April 2017, 20:45:53 »
Possible.
thanks!
Yes there is some left slot for assemble. I will cancle your previous order.
Offline redbanshee
  • actually Dade Murphy
« Reply #68 on: Mon, 01 May 2017, 11:26:48 »
Hey Leeku, any plans to upgrade Jigon and make the in switch LED adjustments work?
Offline leeku
« Reply #69 on: Mon, 01 May 2017, 17:15:35 »
JigOn and FS has been upgaraded recently but if you say the invdivisual control for each LED, it not possible in this PCBs.
Offline redbanshee
« Reply #70 on: Mon, 01 May 2017, 17:24:17 »
 not individual key lighting, i meant the ability to change the in switch led brightness of ALL the keys. Right now they are either on or off but you cant dim them, so its either bright or nothing at all.
could you link the newest version of jigon here too please?
Offline meiosis
  • Time
« Reply #71 on: Mon, 01 May 2017, 17:30:50 »
http://kbdlab.co.kr/index.php?document_srl=2702787&mid=board_sw
Keyboards:
Aripeko TKL
Offline redbanshee
« Reply #72 on: Mon, 01 May 2017, 17:39:11 »
thank you!
Offline TelFiRE
« Reply #73 on: Tue, 02 May 2017, 01:27:44 »
Is the bezel plastic or aluminum? Also is the Viki one still high profile?
Looks really great just gotta pick which one
KBD75 GMK Terminal          XD84 DSA Black on GSF + Hana Matcha + Serum
Offline 12on
« Reply #74 on: Tue, 02 May 2017, 13:48:50 »
- what is the size of the split spacebar and fn key on the bottom row?
- is this pcb cherry mx switches compatible?
Offline funderburker
« Reply #75 on: Tue, 02 May 2017, 13:52:52 »
1) It looks like it's 2.25u (right shift), 1.25u (bottom row modifier) and 2.75u (left shift).
2) Yes, it's made for MX switches.
Keyboard design by Skepur
Offline 12on
« Reply #76 on: Tue, 02 May 2017, 15:36:22 »
submitted.  first time build i'm excited.  thanks!
Offline 12on
« Reply #77 on: Tue, 02 May 2017, 15:46:21 »
hi - i just submitted my order w/ the ANSI DS.  now i'm looking for keycaps.
I want to confirm the size of the bottom row
1.25, 1.25, 1.25, 2.25, 1.25, 2.75, 1.5, 1.5, 1, 1, 1
« Last Edit: Tue, 02 May 2017, 19:58:36 by 12on »
Offline leeku
« Reply #78 on: Wed, 03 May 2017, 20:47:40 »
Confirm!!
Offline 12on
« Reply #79 on: Wed, 03 May 2017, 20:50:40 »
Confirm!!
Paid!!
Offline greenbox
« Reply #80 on: Sat, 06 May 2017, 06:33:03 »
Paid :)
I ended up getting Layout D.
When is the expected shipping time?
I might need to change my shipping address depending on when the ETA is.
Offline Radlife
« Reply #81 on: Sat, 06 May 2017, 17:20:36 »
The expected shipping time is after July 15th, that's hoping there isn't any delays.
Offline leeku
« Reply #82 on: Sun, 07 May 2017, 20:56:46 »
Paid :)
In July hopefully, Just email or PM for changing the address :)
Offline lac29
« Reply #83 on: Sun, 07 May 2017, 21:19:05 »
I really can't decide between bezel and VIKI for a ANSI Detached F row + Split spacebar ... do you have a suggestion?
I'm also looking for MX Clears and assembly if possible.
« Last Edit: Sun, 07 May 2017, 21:23:58 by lac29 »
Offline leeku
« Reply #84 on: Mon, 08 May 2017, 04:09:47 »
Both look nice. :) split spacebar is worthy to try :) It's comfortable.
Offline Skull_Angel
« Reply #85 on: Mon, 08 May 2017, 05:28:10 »
Hi Leeku. Is it possible to have 1.5/1/1.5 bottom row with split spacebar?
Edit; I've estimated what I could with pictures of the PCB and it looks like key spacing would be off with 1.5/1/1.5 alternate layout and split space; 2.5/1.5/2.25 spacebar seems possible, but 2.5 is too uncommon and creates other issues with spacing. If you'd like to confirm anything, it would be appreciated.
« Last Edit: Mon, 08 May 2017, 15:07:35 by Skull_Angel »
Offline needabuildplz
« Reply #86 on: Wed, 10 May 2017, 08:10:00 »
Order submitted!
I'm still rather new to this.  If anyone could help me understand how to search for the proper keycaps, I would greatly appreciate it.
No board... yet
Offline Belfong
« Reply #87 on: Wed, 10 May 2017, 08:15:45 »
Order submitted!
There are lots of group buys running now, especially those made by GMK. Look under Group Buy and you probably can still sign up for one. Otherwise, you can buy it from Classifieds ..
Offline meiosis
  • Time
« Reply #88 on: Wed, 10 May 2017, 21:23:59 »
4 days remaining!
Keyboards:
Aripeko TKL
Offline leeku
« Reply #89 on: Thu, 11 May 2017, 02:36:21 »
It's not possible even in PCB. Sorry.
Below is the possible combination PCB supports.
http://kbdlab.co.kr/files/attach/images/6321/442/036/001/52e95428aa546d92fc1540e424d2b297.jpg
Offline lac29
« Reply #90 on: Thu, 11 May 2017, 08:29:21 »
Hey leeku I'm going to update my shipping address because I'll be moving in early June. Expect a pm!
Offline leeku
« Reply #91 on: Thu, 11 May 2017, 23:29:18 »
changed as you PMed. :)
Offline lac29
« Reply #92 on: Sat, 13 May 2017, 06:39:07 »
Hey leeku, if you have any more duck feet can you add it to my order?
Offline Radlife
« Reply #93 on: Sat, 13 May 2017, 20:50:11 »
This doesn't support alps, correct?
Offline leeku
« Reply #94 on: Sat, 13 May 2017, 22:01:40 »
No ALPs is not suppoted. sorry.
Offline leeku
« Reply #95 on: Sat, 13 May 2017, 22:02:06 »
No duck feet left now. sorry.
Offline Komatoz
  • Click Clackity Away~
    • Komatoz Kaps
« Reply #96 on: Tue, 16 May 2017, 08:32:06 »
Cant wait for this!!
I saw your invoice note~
하와이에사는 한국사람입니다 ㅋㅋㅋㅋ
한글쓰는거는좀...미국에오레 살다보니 한글을쓸 기회가없어서 잘못씁니다... ㅠㅡㅠ
Reddit: /u/Komatoz
Offline schoolbus
« Reply #97 on: Tue, 16 May 2017, 09:10:26 »
Will definitely need to update my address soon, can I just PM you on here when I know where I'm moving?
Offline Belfong
« Reply #98 on: Sun, 04 June 2017, 03:46:22 »
I am probably just jumping the gun here, what with being one and a half month in advance (production ends by 15 July, right?) , but wondering are we still on time?
Offline renzpwns
  • I didn't like money in my wallet anyways.
« Reply #99 on: Wed, 07 June 2017, 00:04:19 »
So uhh just turned in my form in, hope that I made it even though it's been three weeks since the closing date.  :-[
In for a Bezel ANSI D with split backspace and 1.25u-1.25u-1.25u-6.25u-1u-1u-1u-1u-1u-1u bottom row.
