Author Topic: Spilled Water on My Filco Majestouch Tenkeyless :(  (Read 3288 times)
Offline ogs
« on: Thu, 27 April 2017, 16:35:02 »
and now the up arrow and right arrow are flakey and the 9 key keeps triggering when I'm not pressing it. I tried searched the threads, but couldn't find much about fixing this problem. Any hope for my favorite keyboard of all time? (so far)
I tried to get all the water out of it, but it was a pretty good flooding. I left the keyboard unplugged and upside down overnight, but like I say, it's having problems nevertheless.
Any help / advice is appreciated.
Offline xondat
  • i'm not a star
Re: Spilled Water on My Filco Majestouch Tenkeyless :(
« Reply #1 on: Thu, 27 April 2017, 16:37:46 »
Did you take it apart and leave it to dry, or just leave it together overnight?
Offline ogs
« Reply #2 on: Thu, 27 April 2017, 16:38:46 »
I didn't take it apart.
Offline Leslieann
« Reply #3 on: Thu, 27 April 2017, 16:43:27 »
The easiest proper method is to get a tub of rubbing alcohol and soak the board for a few minutes (this displaces the water with fast evaporating alcohol) then let it air dry for a few hours/day.
The real proper way is to disassemble everything (including de-soldering switches) and then do an alcohol dip.
Regardless, don't use rice, that doesn't work.
If all else fails, worst case, you can always swap out the bad switches with replacements later.
« Last Edit: Thu, 27 April 2017, 16:44:59 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline xondat
  • i'm not a star
« Reply #4 on: Thu, 27 April 2017, 16:58:33 »
Yeah you'll have to take the case apart and let the parts sit for at least a few days (obviously not in the sun).
Offline ogs
« Reply #5 on: Thu, 27 April 2017, 17:00:03 »
ah, right. I should just solder in replacement blues. Anyone know if I need to buy platemount or PCB mount blues: https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=56
EDIT: I opened it up. It's a platemount.
EDIT:Looks like platemount is out of stock. Anyone know where else I can buy platemount mx blues?
EDIT: Found some on Amazon and ordered them.
« Last Edit: Thu, 27 April 2017, 17:46:14 by ogs »
Offline ogs
« Reply #6 on: Thu, 27 April 2017, 17:01:06 »
Yeah you'll have to take the case apart and let the parts sit for at least a few days...
Ah okay, I'll try that first
Offline Leslieann
« Reply #7 on: Thu, 27 April 2017, 17:21:36 »
Letting it sit is NOT the right choice with electronics.
The water will not evaporate quickly inside the switch and will just cause corrosion.
This shows why rice and letting it air dry is a bad idea.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline ogs
« Reply #8 on: Thu, 27 April 2017, 17:27:25 »
hahaahahahahahhahah. That was hilarious. Yeah I deserved that.
EDIT: but just for the record, I did not put any rice in it. However, I did not put any alcohol in it either.
« Last Edit: Thu, 27 April 2017, 18:09:36 by ogs »
Offline xondat
  • i'm not a star
« Reply #9 on: Thu, 27 April 2017, 17:31:33 »
Ah. I forgot about corrosion for some reason. Ignore everything I've said :p
« Reply #10 on: Thu, 27 April 2017, 19:33:20 »
For future reference you can use flush cutters to cut the extra legs off of PCB mount switches to turn them into plate mount.
Offline ogs
« Reply #11 on: Thu, 27 April 2017, 20:29:48 »
Ah, I canceled the Amazon order and ordered them from mechanical keyboards instead. They get better feedback reviews I think. Thanks
Offline Leslieann
« Reply #12 on: Thu, 27 April 2017, 23:21:09 »
Better to support them anyhow.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
