Author Topic: Help picking a plate  (Read 4019 times)
Offline Encabulator
« on: Thu, 27 April 2017, 17:52:53 »
I'm looking into getting a removable switch top plate for my pok3r so I don't have to solder every time I want to swap springs and everything. I m thinking that I want just a plain black aluminum plate with switch top removal. I really don't really know what plate to choose but I want it to be ANSI only and black aluminum or some other metal. I was looking at sentraq.com and they have nice carbon fiber plates but I think that it looks ugly with the ISO compatibilit
Can anyone lead me in the right direction, I try my best to find useful information online before posting here but a lot of the time the stuff I find is outdated or just confusing to me. Thank you for all the help.
« Last Edit: Thu, 27 April 2017, 18:39:38 by Encabulator »
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Re: Help picking a plate
« Reply #1 on: Thu, 27 April 2017, 19:20:50 »
Are you going to have any LEDs?
Offline Encabulator
« Reply #2 on: Thu, 27 April 2017, 22:06:14 »
Nope
Offline TalkingTree
    • My projects
« Reply #3 on: Fri, 28 April 2017, 04:48:45 »
If you're patient enough to wait a couple of months, China is your friend.
Offline Encabulator
« Reply #4 on: Fri, 28 April 2017, 08:33:39 »
I had my eyes on another plate from aliexpress. Had a lot of good reviews, just concerned about shipping damage. The nice thing about aliexpress is I can get a plate and a case with my 80 USD budget.
Plate: https://www.aliexpress.com/item/Free-Shipping-ANSI-Costar-Stabilizers-Anodized-Aluminum-Positioning-Board-Plate-Support-For-GH60-60-Keyboard-DIY/32736623172.html?spm=2114.01010208.3.19.1tFdBT&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_10068_10130_10136_10137_10060_10138_10155_10062_10156_10154_10056_10055_10054_10059_10099_10103_10102_10096_10148_10147_10052_10053_10142_10107_10050_10051_10084_10083_10119_10080_10082_10081_10178_10110_10111_10112_10113_10114_10181_10182_10078_10079_10073_10070_10123_10120_10124,searchweb201603_16,ppcSwitch_5&btsid=8b10e75b-eba1-49c4-85d4-020fe7c64317&algo_expid=4f917ab9-1c93-427a-8ba3-90bed49d84fd-2&algo_pvid=4f917ab9-1c93-427a-8ba3-90bed49d84fd
Case: https://www.aliexpress.com/item/Wholesales-GH60-Anodizing-Aluminum-Case-for-60-Mechanical-Gaming-Keyboard-Compatible-Poker2-Pok3r-Faceu-60/32540926035.html?spm=2114.01010208.3.20.DTjKcZ&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_10068_10130_10136_10137_10060_10138_10155_10062_10156_10154_10056_10055_10054_10059_10099_10103_10102_10096_10148_10147_10052_10053_10142_10107_10050_10051_10084_10083_10119_10080_10082_10081_10178_10110_10111_10112_10113_10114_10181_10182_10078_10079_10073_10070_10123_10120_10124,searchweb201603_16,ppcSwitch_5&btsid=504a7451-9d7d-4840-bf64-ef5eae39914f&algo_expid=9cbe5877-4320-4f34-8e83-100b0fcbcfa1-2&algo_pvid=9cbe5877-4320-4f34-8e83-100b0fcbcfa1
P.S. How does one replace a link with text?
P.S.S. If i were to get a costar plate could i just use costar stabilizers on my pok3r, or would it cause issues?
« Last Edit: Fri, 28 April 2017, 08:37:57 by Encabulator »
« Reply #5 on: Fri, 28 April 2017, 08:38:17 »
Code: [Select]
[url=URL.whatever]text goes here[/url]
Offline TalkingTree
    • My projects
« Reply #6 on: Fri, 28 April 2017, 08:53:24 »
I'm fairly sure you won't have any issue. Mind that you need either Costar stabilizers and Costar inserts.
Offline Encabulator
« Reply #7 on: Fri, 28 April 2017, 09:23:59 »
 Actually, I'll probably get authentic cherry stabs cause in the past I've had issues with costar stabs getting stuck on thicker keycaps. and you know I like my keycaps T H I C C
Offline TalkingTree
    • My projects
« Reply #8 on: Fri, 28 April 2017, 10:50:30 »
SA keycaps usually need Costar inserts to be glued in, if mean those, otherwise you should need no workaround at all.
Offline Encabulator
« Reply #9 on: Fri, 28 April 2017, 11:12:17 »
My issues aren't from the inserts not sticking but rather from the wire catching on the side of the keycaps
Offline TalkingTree
    • My projects
« Reply #10 on: Fri, 28 April 2017, 11:20:09 »
You're right, Costar stabilizers have this very limitation, they could be only used (effectively) if placed on the LED side of the switch.
Offline Encabulator
« Reply #11 on: Fri, 28 April 2017, 13:56:31 »
I'll just stick with clipped authentic cherry stabs then
Offline TalkingTree
    • My projects
« Reply #12 on: Fri, 28 April 2017, 13:58:06 »
Good idea.
Offline Encabulator
« Reply #13 on: Fri, 28 April 2017, 14:01:19 »
Good idea.
Sorry to bother but do you see any issues with what I plan on purchasing from aliexpress? I just want to make sure that I wont be missing anything for a plate/case swap. I have the tools and soldering/desoldering irons handy.
Offline TalkingTree
    • My projects
« Reply #14 on: Fri, 28 April 2017, 15:18:29 »
You're good to go. Those case and plate would match. Pok3r case and plate are de facto a standard, you can see the plate holes match the case mounting supports.
Sorry to bother
You don't.
