Author Topic: Need last minute help deciding Filco Linear v. Tactile Click  (Read 5591 times)
Offline nijikon5
« on: Fri, 19 February 2010, 07:27:49 »
Hi, friend and I are looking to get mechanical keyboards for gaming. We recently both got Steelseries 7Gs and tried them out. Loved how the Cherry Blacks felt for gaming ( Primarily FPS players ) but really felt awkward typing with them. Didn't really like the layout of the Steelseries, plus one of them had a defective number pad. We decided to get Filcos with NKRO to save on shipping. Was pretty much set on getting Blacks since these KBs will primarily be used for competitive ( cevo/esea ) FPS gaming ( TF2, CoD4, MW2, CS ). I know a lot of mechanical KB enthusiasts are not the most fond of blacks, but I want to know if blues are really that much of a downgrade in terms of high level gaming. Feedback from anyone/everyone is greatly appreciated, if you have experience with both these switches and you play FPS ( casual or competitive is fine ) please chime in!
I originally placed an order for the 2 Linear Force NKROs from EliteKBs, but flip flopped to Tactile Clicks last minute, and then decided back on the Linear Force. EliteKBs is rather close to where I live so they told me to E-Mail them before tomorrow to finalize my order. I was also thinking I could just pick up a Scorpius m10 in a couple of weeks as a typing KB if I decide on the Linear Force. Thanks in advance!
Also a few quick specific questions:
Cherry black users, do you ever suffer from fatigue or soreness with prolonged typing/gaming with cherry blacks?
Cherry blue users, how loud is the cherry blues at night, does it wake people in your household?
« Last Edit: Fri, 19 February 2010, 07:31:12 by nijikon5 »
Offline devilcm3
« Reply #1 on: Fri, 19 February 2010, 07:32:52 »
id say...since you already had 7G..why bother getting another blacks?
blues are good for typing
Black Cherry MX , once you bought it , it is yours , it is permanently yours , it is permanently yours till you meet your maker
1.FILCO Cherry Blue FKBN104MC/EB
2.FILCO Cherry Brown FKBN84M/EB
Offline Rajagra
« Reply #2 on: Fri, 19 February 2010, 07:54:37 »
Sorry for muddying the water, but I think Cherry browns (tactile touch) would be best. They aren't *that* much lighter than the blacks. The tactile feel is subtle - you can easily pretend it isn't there if you wish. Moving from blacks to browns is just a question of acclimatising yourself to the slightly lower force.
The trouble with the blues is that there is a definite hysteresis - the release point is higher than the make point - meaning it is fundamentally different in operation to blacks and browns.
OK, the hysteresis is only 0.5mm see here but I suspect it's enough to make a difference for competitive gaming.
Offline Xede
« Reply #3 on: Fri, 19 February 2010, 07:55:20 »
Go for topre! I still love my filco MX black though, I would definitely get that if you aren't keeping the 7g.
Realforce 87U 55g, HHKB Pro 2, Filco MX Black 104 Key, Unicomp Customizer 104 Key.
Offline Mental Hobbit
« Reply #4 on: Fri, 19 February 2010, 08:44:55 »
Browns would be the obvious choice in your case.
Typing on blues.
Offline itlnstln
« Reply #5 on: Fri, 19 February 2010, 09:07:40 »
Quote from: Mental Hobbit;159338
I was thinking the same thing.
Offline meltie
« Reply #6 on: Fri, 19 February 2010, 09:17:29 »
Quote from: itlnstln;159339
Me, too! :bounce:
Offline Laxer
« Reply #7 on: Fri, 19 February 2010, 09:38:14 »
Browns here too :) I actually switched a week ago for gaming from a 7G to a Filco browns - for me the best decision!
My System at Nethands and sysProfile
Offline nanu
    • http://T-T.be/portal
« Reply #8 on: Fri, 19 February 2010, 09:43:14 »
I don't use either, but I would still go for linear switches since you're gaming seriously. Are there any serious gamers using browns? According to popular comparisons the blues are better than browns, for gaming.
I have a fellow mech.kbd convert using linear/Cherry blacks... he can't avoid tired fingers, after months of gaming, but he still loves the keyboard. I can only imagine that fatigue would be a great regulatory mechanism to take breaks, IMO. I doubt that prolonged use of a heavy switch would lead to chronic injury for most people, unless you're using the keyboard non-stop, everyday.
Oh, and I consider ring-dampened Cherry browns to be just a bit quieter than "loud," so I would avoid blues for that reason, too.  I'm in the minority around these parts with perception of loudness, however.  If it isn't near-silent, it's loud.
« Last Edit: Fri, 19 February 2010, 09:46:47 by nanu »
Offline nijikon5
« Reply #9 on: Fri, 19 February 2010, 16:15:53 »
Quote from: ripster;159371
I like typing on the Cherry Blues to annoy people.  Usually the people on this forum.
Seriously, buying one keyboard for gaming and another for typing is the way to go if you are gaming at the competitive level.
Thanks Ripster, it looks like I'll go with the Blacks from Filco and probably a Scorpius M10 as a typing kb.
Offline itlnstln
« Reply #10 on: Fri, 19 February 2010, 16:22:25 »
Solid plan.
« Reply #11 on: Fri, 19 February 2010, 16:41:32 »
Quote from: itlnstln;159464
Solid plan.
I was thinking the same thing. Meltie?
Typing on blues.
Offline ricercar
  • mostly abides
« Reply #12 on: Fri, 19 February 2010, 16:51:30 »
You don't need Cherry blues for that. You annoy people just by clicking "Submit Reply"
Offline trievalot
« Reply #13 on: Fri, 19 February 2010, 16:59:07 »
i was using my Model M for Urban Terror for ages, the browns are so much nicer on the Filco.
[SIGPIC]
Offline dion2k
« Reply #14 on: Fri, 19 February 2010, 17:14:18 »
In my experience I've never been able to tire my left hand before my right, although that might be due to my lower mouse sensitivity. I was recently debating on getting a Black for gaming and a brown for typing, after weighting all the variables I decided to go with a Realforce 55g. The Blacks, while unmatched in games that require repetitive key presses such a WoW, seem (in my opinion) to be less important in FPS games. The Browns will have a better feel and that feel will be whats important when you're moving around and switching weapons. The Blues weren't in my choices because the sounds are too high pitched, and coming from buckling springs and white alps I'm looking to get away from that noise.
Realforce 87u 55g, Northgate Omnikey Ultra, IBM Model M
Offline kriminal
« Reply #15 on: Sat, 20 February 2010, 04:35:22 »
yep i play FPS games more than anything and my brown seems to fit the bill, however that damned spacebar on my filco felt... off...
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
