Author Topic: Material for sound dampening HHKB (Interior)  (Read 6784 times)
Offline BaconEggandCheeseBagel
« on: Sat, 29 April 2017, 16:35:16 »
Just wondering what you have all used to help add weight inside/dampen sound. Already have hypersphere, plan on getting the absorption mat from smartimports, but wanted to put something inside the case and don't know where/what to look/use.
Offline losing_ctrl
Re: Material for sound dampening HHKB (Interior)
« Reply #1 on: Sun, 30 April 2017, 11:01:38 »
Hi, having just purchased my HHKB Pro 2 I will be interested to read what other folks have done to dampen sound and vibrations.
Also, please let us know how you like the sound absorbing pad from Smart Imports when you get it - I am very tempted to get that myself.
Offline iLLucionist
  • Topre is Love.
« Reply #2 on: Mon, 01 May 2017, 15:23:24 »
There is a thread here somewhere all about dampening and foam to put inside case.
Too lazy to look it up though
Offline _rubik
« Reply #3 on: Wed, 03 May 2017, 12:41:01 »
...Already have hypersphere...
Hypersphere is a grade A ripoff...
Offline dgneo
  • Supervillain
« Reply #4 on: Wed, 03 May 2017, 12:47:51 »
https://www.reddit.com/r/MechanicalKeyboards/comments/63invd/news_hhkb_vibration_absorbing_mat/dfuo37t/
This comment chain should have some good recommendations, OfTheWilds solution definitely looks to be the best.
Offline _rubik
« Reply #5 on: Wed, 03 May 2017, 12:51:07 »
tl;dr Neoprene foam pad inside the case.
Offline DaBubbs
« Reply #6 on: Sun, 07 May 2017, 15:10:00 »
x2
When you are dead, you don't know that you are dead. It is difficult only for the others.
It is the same when you are stupid.
